Freemake Video Converter
krebs11 ::
Imam posnetek v 1080i in ko ga pretvorim s tem programom Freemake Video Converter(v3.1.1.3) v SD (720*408) se pri hitrih premikih posnetek predvaja negladko. Poskušal sem že več nastavitev, celo z drugim programom, pa je isto. Nastavil sem celo hitrost slik na 30 in 50 pa ni nič pomagalo. Še nastavitve od programa: mkv, 720*408,original, codec H.264, 25fps,bitrate 1100, audio ac3, stereo,48000,192Kbps.
Še info od videa:
General
Format : MPEG-TS
File size : 280 MiB
Duration : 3mn 45s
Overall bit rate : 10.4 Mbps
Video
Menu ID : 11903 (0x2E7F)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 3mn 45s
Bit rate : 9 696 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.187
Stream size : 260 MiB (93%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 3mn 45s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 143ms
Stream size : 5.15 MiB (2%)
Language : English
krebs11 ::
Tukaj je posnetek, če bo kdo poskusil: http://wtrns.fr/M-LVfvrT4vWkFGe
YouTube nativni video format
152377 (2006) Ijus
Občasno štekanje pri predvajanju preko HDMI
Oddelek: Zvok in slika
474220 (3176) sejmon
HD ali FULL HD KAMERA
286392 (5416) JOKER
Kupil bi Satelitsko. (strani: 1 2 )
5018973 (17433) mumbo
wmv - video in zvok nista usklajena
61509 (1454) #000000
