Forum » Problemi človeštva » Gene doping...genska terapija v praksi
guest #44 ::
http://www.guardian.co.uk/sport/2012/ju...
Že meni kot laiku je to izjemno sumljiv rezultat.
K temu še prispeva kitajsko poreklo tekmovalke. Znano je namreč, da kitajska na veliko raziskuje genski inženiring, moralnih zadržkov pa ima bolj malo. Perfektna kombinacija za kaj takega.
Pri vpisu na fakultete npr. kitajski mladež na veliko jemlje razne illegalne substance (poživila, hormonske inekcije ...). Ne bi se čudil, da se je "prostovoljno javila" tudi kaka 16-letna športnica.
Nekaj več na to temo
Gene doping @ Wikipedia
Primer:
http://www.wired.com/wiredscience/2010/...
Še mal pa bodo bilderji na veliko to počeli. And before you know it, bo to norma.
http://www.ratemyarms.com/research/gene...
Imate opcije:
1. Šparajte denar za morebitne augmentacije. Socialistično usmerjeni pa volite ustrezno vlado.
2. Skušajte kljubovat trendu
3. Die off (najvrjetnejši rezultat točke 2)
Ye stunned world swimming on Saturday by winning gold in the 400m individual medley in a world-record time. It was her final 100m of freestyle, in which she recorded a split time of 58.68sec, that aroused Leonard's suspicion. Over the last 50m she was quicker than the American Ryan Lochte, who won the men's 400m individual medley in the second-fastest time in history .
Primer:
If he publishes an academic paper or does a media interview, a flurry of 50 or more calls and emails usually follows, as it did 10 years ago when he first revealed his ‘mighty mice’ to the world at a meeting of the American Society for Cell Biology – laboratory mice with enormous muscles that retained their strength and regenerative ability even when the animals reached old age.
Imate opcije:
- spremenilo: guest #44 ()
guest #44 ::
Neposredne ni. Vendar je itredno sumljivo. Dokazati je težko, ker sploh še ni dobrega testa za odkrivanje tovrstnega dopinga.
Matek ::
Die off? Ne nabijaj. Od kdaj je pa uspeh v tekmovalnem športu pogoj za preživetje? Oz. od kje tvoja logika, da bo to naenkrat postalo standard za vse? Že danes lahko vsak povprečen človek za relativno majhna sredstva doseže ogromne izboljšave svoje fizične moči (od fitnes programov in prehranskih dopolnil pa do steroidov in podobnih bolj škakljivih zadev), pa se kljub temu tega poslužuje zgolj določena manjšina, ki ji je to pač hobi. Kaj bo drugače, če imamo še eno metodo za to?
- spremenil: Matek ()
Yugos ::
ja ljudje se zgražajo če nekdo na 100m vzame doping ampak hočejo vsake olimpijske nov svetovni rekord.
Pri teh totalitarnih režimih imajo pa logorje kjer te ljudi enostavno vzredijo kot živino in trenirajo do onemoglosti in tisti ki psihično zmorejo pridejo na OI.
Enostavno ne verjamem da je kdo od šprinterjev čist.
Šport je že dolgo daleč od športa, tako da... Na zapadu ništa novo.
jverne> Še mal pa bodo bilderji na veliko to počeli. And before you know it, bo to norma.
Norma za? Saj že zdaj lahko greš z mopedom v hrib, pa si prej kot kolesarji.
guest #44 ::
Kolesarji na hribovitih delih so še vedno bolj ali manj manjšina in vrjetno bo tko tud ostalo.
Sicer pa zakaj bi se temu odrekli, če lahko konkretno izboljša kvaliteto življenja?
It's inevitable IMO.
Sedaj gledamo športnike. Naslednji korak so nedvomno zdravila. Bogataši bodo svojim potomcem odstranili dedne bolezni. Temu bo sledilo izboljšanje motoričnih sposobnosti. Nato estetika.
Ko bo že vse to rutinsko, bo se vrjetno začelo igrat z možgani.
Splačalo se bo bit bogat. Vzrejali bodo zdrave in lepe potomce. Pol še pametne.
Skratka ja, zanimiva bo še ta prihodnost.
Ejsi_Disi ::
Malce po spominu kar je zadnjič rekel Stare pri komentiranju atletike. Če sem se kaj zmotil pa popravite.
V svetu dobijo na dopingu od 1,5% do 2% ljud. Dejansko naj bi se jih dopingiralo še x50. V Sloveniji naj bi do sedaj dobili 36 (ali 38)'zadrogirancev' (prosto po Staretu), dejansko pa jih je 36x50=1800. In glede na aktivne profesionalne športnike v Sloveniji, je Slovenija v samem vrhu dopinga.
Rock n' roll ain't noise pollution!
| » | Doping štorjeOddelek: Problemi človeštva | 6310 (5376) | jype |
| » | Armstrong - končno ! (strani: 1 2 )Oddelek: Loža | 21376 (18793) | thramos |
| » | Ali je še smiselna prepoved dopingiranja? (strani: 1 2 )Oddelek: Problemi človeštva | 12267 (10035) | Andreij |
| » | Bo Joli še tekla kdaj za Zdravljico ? (strani: 1 2 3 )Oddelek: Loža | 10176 (8211) | Matev |
| » | Zakaj športniki umirajo mladi?Oddelek: Problemi človeštva | 3442 (2316) | mikena |
