bios update
bios update
Trubadur ::
Mam ene probleme pri flešanju biosa (bios je amijev).
Ko zaženem računalnik in mi zboota z diskete mi napiše samo A:\.
  • Kako naj pridem na c disk,ker biosa ne smem flashat z diskete?
  • V navodilih piše tole:
    4. Extract the BIOS-archive that you have downloaded by double clicking to c:\test
    5. Boot your system from a Win98 or WinME boot-floppy.
    How to make boot floppy in case your don’t have it ready:
    For Win9X, You can type [C:\ format a:/s] from the DOS prompt.
    For WinMe, You can make a boot floppy from control panel--> add/remove program-->make boot floppy. Remove autoexec.bat & config.sys file if there's any.
    For Win2000, there's no way to make boot floppy, so you have to either use Win9X or WinME boot floppy.
    For WinXP, you can make a DOS boot disk. Go to Your Computer, right click drive A:, select Format, select copy system files.
    7. When you get the A:\ prompt, type the following sequence:
    C:
    cd\test
    C:\test> amifl827 BIOS file
    (to save or not to save old BIOS is the user’s decision)
    8. Reboot your system when prompted
    Matično mam MSI Kt4 Ultra Ver. 6590.Bios je amijev zadnja verzija
    Berite Thomasa!
    NTLDR is missing
    328670 (7818) kreki
    Diagnostično orodje za WD
    Oddelek: Programska oprema
    145035 (4895) clovk
    LILO Bootloader?
    Oddelek: Operacijski sistemi
    81784 (1654) ank
    Logitech MouseWare bug (?)
    272597 (2193) Swiwer
    Updateanje BIOSa
    132399 (2150) jlpktnst
