Forum » Programska oprema » Office 2013
Office 2013
bluefish ::
Na voljo je Microsoft Office 2013 Customer Preview: http://www.microsoft.com/office/preview...
http://www.theverge.com/2012/7/16/31566...
Microsoft's Office 2013 reaches its public Consumer Preview milestone today, available for end users to test on Windows 7 and Windows 8 PCs. Microsoft is calling its Office 2013 suite, codenamed Office 15, a "modern" version of the software that is used on a billion PCs worldwide. Cloud-connected and designed to work well on Windows 8 tablets, Office 2013 signals a shift to document collaboration and anywhere any device access. Notably, Microsoft is introducing an on-demand subscription version of Office 2013 that can be streamed from any Windows 7 or Windows 8 PC, with the ability to sync settings and documents. With strong competition from Google Apps and Apple’s iCloud storage and iPad hardware, how does Microsoft plan to keep Office 2013 desktop software and its cloud offerings relevant in a multi device era? Read on to find out.
dronyx ::
Vem, samo pri Office se mi pa res zdi, da tu ni več kaj dosti za povedat in dodat. Mogoče kvečjemu Metro style (manj je več in čez cel ekran), samo potem smo pa spet pri Wordpadu.
lmorgh ::
kako je z offici in licenco za en računalnik?
če se mi sesuje sistem/ crkne kakšna komponenta... moram kupiti nov office?
jamiroq ::
naceloma ne. na isti racunalnik lahko ponovno namestis, na novega ne. vprasanje je, kaj microsoft smatra za nov racunalnik, kako to preverja in kako vsiljuje nov nakup.
vaniilly ::
Tudi mene zanima, če slučajno kdo ve, kako je kaj z SLO verzijo Office 2013?
Hvala!
Vedno več bo piratskih verzij, če bo tak način vsiljevanja...
Hvala!
- spremenil: vaniilly ()
Enterprise ::
se je kdo soočal s takim problemom slučajno?
sveža namestitev Windows 7 Home Premium (originalni, priloženi prenosniku), potem pa probam naložiti še Office (spet original trial iz microsoftove strani) pa tole:
nato pa še tole:
sem pregledal po netu že čuda potencialnih rešitev, pa nič ...
nato pa še tole:
- spremenil: Enterprise ()
jonystar ::
Bom kr tuki vprašou, da nebom odpiral nove teme.
Mel sem naložen Office 2010(Word, PP, Excel in Outlook) in se te office zbrisou in vse .pst file, ki spadajo k Outlooku potem sem pa naložu Office 2013 ampak se pojavi problem, da mi Outlooka ne zažene, ker ne najde .pst filea, ki je bil v starem Outlooku. Jest pa nočem, da bi se stari .pst-ji in mail računi karkol vmešaval v nov Office.
- spremenil: jonystar ()
solatko ::
S katerim programom si brisal Office 2010? Pobrisat bi moral vse faile od outlook-a 2010 in na novo nastavit račun. Dokler boš imel še kakšne podatke v mapah, o starem računu, se 2013 outlook ne bo zagnal.
Delo krepa človeka
solatko ::
Kako če mu ga ne zažene? Naredil je napako, ker ni naredil upgrade, sedaj mu pa zazna, kot, da ima outlook še vedno gor.
Delo krepa človeka
jonystar ::
@solatko, pobrisou sem ga iz nadzorne ploče, potem sem z total commanderjam preiskou cel računalnik za .pst file in zbrisov vse mape ki so te file vsebovale. Pol sem restartov računalnik in se lotu nalaganja office 2013.
@ZIga Dolhar, v Control Panelu je isto, javi mi, da ni .pst filea.
Mogoče so pa outlookove datoteke še kje drugje, kokr pa samo v C:\Users\Janez\Documents\Outlookove datoteke in v C:\Users\Janez\AppData\Local\Microsoft\Outlook in jest zgleda nevem zanje.
Hayabusa ::
http://www.tomshardware.com/answers/id-...
Where does Microsoft Outlook 2010 save my information and configurations?
http://office.microsoft.com/en-us/outlo...
http://www.howtogeek.com/howto/21384/wh...
Outlook 2010: HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Outlook\
- spremenilo: Hayabusa ()
Qushaak ::
A se kaj ve kakšna je prihodnost "ne-oblačnega" Microsoft Office-a? Bodo še naredili novo verzijo ali mislijo sedaj samo cloud (Office 365) furat?
bluefish ::
Nekaj se je ugibalo, da naj bi nova verzija prišla na trg pozno pomladi - kodno ime Gemini. Bomo videli, če bo kaka omemba aprila na konferenci BUILD.
Duhec ::
Roadmap 2014:
http://rcpmag.com/articles/2011/02/01/t...
Gemini naj bi bila integriracija metro stajla v core Office 2013.
mk766321 ::
Mogoče kdo ve zakaj mi javi outlook da imam neveljavno digitalno potrdilo?
potrdilo je veljavno, sem uvozil, le pri pošiljanju mi javi da ne morem uporabit za ta račun.
Kaj je pogojeno s katerega računa lahko pošiljam? Ne najdem kvake
Res noben ne ve?
Res noben ne ve?
- spremenil: mk766321 ()
MisoBer ::
Zdravo. V word-u 2013 me zanima kje spreminjam nabor slogov dokumenta npr na osenčeno. Hvala za odgovor
| » | Pretvorba Thunderbird v OutlookOddelek: Pomoč in nasveti | 2875 (2113) | markhenry |
| » | outlook 2016Oddelek: Operacijski sistemi | 2603 (1167) | PH03N1X |
| » | Microsoft Office 2019 Home&Business SloOddelek: Programska oprema | 9807 (8386) | Han |
| » | MS Office 4 freeOddelek: Programska oprema | 7719 (7050) | 111111111111 |
| » | Kaj tole serje Outlook?Oddelek: Pomoč in nasveti | 1644 (1443) | kmetek |
