Forum » Programiranje » [Android]InflateException
KernelPanic ::
Spostovani!
Ko hocem pognati nek activity v svoji aplikaciji:
Lp,
M.
@Override
public void onCreate(Bundle icicle)
super.onCreate(icicle);
try
setContentView(R.layout.cactivityregisterscreen);
this.setEditTextBirthDate((EditText)findViewById(R.id.birthdate));
catch(Exception ex)
Log.e(CActivityRegisterScreen.m_strLogTag,
ex.getClass().getName()+":"+
ex.getMessage().toString());
finally
} // try-catch-false
} // onCreate, mi v vrstici setContentView.. pride do sledecega exceptiona:"android.view.InflateException:Binary XML file line #30: Error inflating class unknown"Kaj ta exception pomeni in kako se ga resim?
Lp,
M.
FrEaKmAn ::
glede na podano bi ocenu, da je v cactivityregisterscreen.xml napaka. Lahko še to objaviš?
KernelPanic ::
Evo ga:
Lp,
M.
Nihce ne ve?
<?xml version="1.0" encoding="utf-8"?>
<ScrollView
xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:fillViewport="true">
<RelativeLayout
android:layout_height="wrap_content"
android:background="#000000">
<!-- Logo Start-->
<ImageView android:src="@drawable/logo"
android:layout_width="wrap_content"
android:layout_marginLeft="10dip"
<!-- Logo Ends -->
<!-- Registration form -->
<LinearLayout
android:orientation="vertical"
android:layout_width="match_parent"
android:padding="10dip"
<!-- Surname Field -->
<EditText android:id="@+id/field_surname"
android:layout_marginTop="5dip"
android:layout_marginBottom="20dip"
android:hint="@string/label_lastname_si"
android:inputMethod="textCapSentences"
android:singleLine="true"/>
<!-- Name Field -->
<EditText android:id="@+id/field_name"
android:hint="@string/label_name_si"
<!-- Email Field -->
<EditText android:id="@+id/field_email"
android:inputType="textEmailAddress"
android:hint="@string/label_email_si"
<!-- Gender Selector Radio Group -->
<RadioGroup android:id="@+id/group_genderselection"
android:orientation="horizontal"
android:text="@string/label_gender_si">
<RadioButton android:id="@+id/item_male"
android:text="@string/label_gender_male_si"
android:checked="true"
<RadioButton android:id="@+id/item_female"
android:text="@string/label_gender_female_si"
android:checked="false"
</RadioGroup>
<!-- Bithdate Entry Field - invokes DatePicker dialog -->
<EditText android:id="@+id/birthdate"
android:password="false"
android:hint="@string/label_birthdate_si"
android:editable="false"
android:onClick="onDateSelectClick"
<!-- Password Label -->
<EditText android:id="@+id/field_password"
android:password="true"
android:hint="@string/label_password_si"
<!-- Button "Register" - adds new user to database -->
<Button android:id="@+id/btnRegisterNewUser"
android:layout_marginTop="10dip"
android:text="@string/label_registernewuser_si"
android:onClick="onBtnRegisterNewUserClick"
</LinearLayout>
<!-- Register Form Ends -->
</RelativeLayout>
</ScrollView>Pa glede na to, da je to prva aplikacija, lahko tudi skritiziras ta moj registration acitvity, za registracijo uporabvnika v sistem (dodajanje le tega v bazo). Ali se to tako dela z fieldi ali obstaja kak drugacna androidova filozofija?Lp,
M.
Nihce ne ve?
- spremenil: KernelPanic ()
| » | [Android] Bluetooth aplikacijaOddelek: Programiranje | 1491 (1354) | marjan_h |
| » | Android - ZačetnikOddelek: Programiranje | 2218 (1543) | hurlimannxt |
| » | [Android] setText iz AsyncTaskOddelek: Programiranje | 1152 (1069) | golobich |
| » | android črtaOddelek: Programiranje | 2970 (2241) | g333kk |
| » | [Android]Cudno obnasanje aplikacije in emulatorjaOddelek: Programiranje | 1666 (1495) | KernelPanic |
