[Android] Bluetooth aplikacija
marjan_h ::
Pozdravljeni,
napisal sem aplikacijo s pomočjo android guide
pa mi crasha vedno ko jo poženem, in ne vidim napake. Prosil bi če kdo ki piše te aplikacije strokovno pogleda kodo.
public class StartActivity extends Activity{
    ArrayAdapter<String> listAdapter;
    ListView listView;
    BluetoothAdapter btAdapter;
    Set<BluetoothDevice> devicesArray;
    IntentFilter filter;
    ArrayList<String> pairedDevices;
    ArrayList<BluetoothDevice> devices;
    Button bu;
    public static final UUID MY_UUID = UUID.fromString("94A04430-0B83-11E4-9191-0800200C9A66");
    private final BroadcastReceiver mReceiver = new BroadcastReceiver() {
        public void onReceive(Context context, Intent intent) {
            String action = intent.getAction();
            if (BluetoothDevice.ACTION_FOUND.equals(action)) {
                BluetoothDevice device = intent.getParcelableExtra(BluetoothDevice.EXTRA_DEVICE);
                pairedDevices.add(device.getName());
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_start);
        // inicializacija
        init();
        if(btAdapter==null){
            Toast.makeText(getApplicationContext(), "No bluetooth detected", 0).show();
            finish();
        else{
            if(!btAdapter.isEnabled()){
                turnOnBT();
            getPairedDevices();
            startDiscovery();
    private void startDiscovery() {
        btAdapter.cancelDiscovery();
        btAdapter.startDiscovery();
        filter = new IntentFilter(BluetoothDevice.ACTION_FOUND);
        registerReceiver(mReceiver, filter);
        listAdapter= new ArrayAdapter<String>(this, android.R.layout.simple_list_item_1,pairedDevices);
        listView.setAdapter(listAdapter);
    private void turnOnBT() {
        Intent intent =new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
        startActivityForResult(intent, 1);
    private void getPairedDevices() {
        devicesArray = btAdapter.getBondedDevices();
        if(devicesArray.size()>0){
            for(BluetoothDevice device:devicesArray){
    private void init() {
        listView=(ListView)findViewById(R.id.listView1);
        bu = (Button)findViewById(R.id.go);
        bu.setOnClickListener(new View.OnClickListener(){
            public void onClick(View v) {
            	try{
   		         Intent i = new Intent(getApplicationContext(), Graph.class);
   		         startActivity(i);
   		    	catch(Exception e){e.printStackTrace();}
        listView.setOnItemClickListener(new android.widget.AdapterView.OnItemClickListener() {
        	public void onItemClick(AdapterView<?> parent, View view,int position, long id) {
        		BluetoothDevice selectedDevice = devices.get(position);
        		ConnectThread connect = new ConnectThread(selectedDevice);
                connect.start();
        btAdapter = BluetoothAdapter.getDefaultAdapter();
        pairedDevices = new ArrayList<String>();
        devices = new ArrayList<BluetoothDevice>();
    private class ConnectThread extends Thread {
        private final BluetoothSocket mmSocket;
        private final BluetoothDevice mmDevice;
        public ConnectThread(BluetoothDevice device) {
            BluetoothSocket tmp = null;
            mmDevice = device;
            try {
                tmp = device.createRfcommSocketToServiceRecord(MY_UUID);
            } catch (IOException e) { }
            mmSocket = tmp;
        public void run() {
            try {
                mmSocket.connect();
            } catch (IOException connectException) {
                try {
                    mmSocket.close();
                } catch (IOException closeException) { }
                return;
            // klici Connected thread, zakljucek
            ConnectedThread objekt = new ConnectedThread(mmSocket);
        public void cancel() {
            try {
                mmSocket.close();
    private class ConnectedThread extends Thread {
        private final InputStream mmInStream;
        private final OutputStream mmOutStream;
        public ConnectedThread(BluetoothSocket socket) {
            mmSocket = socket;
            InputStream tmpIn = null;
            OutputStream tmpOut = null;
            try {
                tmpIn = socket.getInputStream();
                tmpOut = socket.getOutputStream();
            mmInStream = tmpIn;
            mmOutStream = tmpOut;
        public void run() {
            byte[] buffer = new byte[1024];
            int bytes;
            while (true) {
                try {
                    bytes = mmInStream.read(buffer);
                    String str = new String(buffer, "UTF-8");
                    // prikazi tekst
                    Toast.makeText(getApplicationContext(), str, 0).show();
                    break;
            try {
                mmSocket.close();
Hvala za pomoč, UUID sem dobil z spletnim generatorjem. Cilj aplikacije je da prikaže tekst ki mu je bil poslan.
Mavrik ::
Joj, ti resno misliš da bo šao kdo pregledovat 200 vrstic kode in jo probavat... ko se tebi ni dalo niti loga prilepiti zraven?
marjan_h ::
log izpiše success. Problem nastane ko naložim aplikacijo na mobitel.
Oprostite ker je dolga koda, vendar je veliko skopirano z uradne strani tako da nekdo ki je že to programiral bi moral hitro opaziti kakšno napako.
Hvala.
Mavrik ::
In... loga s telefona vseeno ne bi prilepil?
marjan_h ::
Zanimivo, da danes pa se ne sesuje. Mogoče se sesuje samo takrat ko se mora povezati z oddaljeno napravo. Prejeti tekst pa ne deluje. Na strani pošiljatelja je vse vredu sem preveril.
Nisem tudi vedel da se da log iz telefona dobiti.
2014-07-15 09:09:16.910 2 3840/InputMethodManager: onWindowFocus: android.widget.ListView{414c74c8 VFED.VCL .F....ID 0,72-480,744 #7f04002a app:id/lsLog} softInputMode=272 first=true flags=#1810100
2014-07-15 09:09:16.910 2 3840/InputMethodManager: START INPUT: android.widget.ListView{414c74c8 VFED.VCL .F....ID 0,72-480,744 #7f04002a app:id/lsLog} ic=null tba=android.view.inputmethod.EditorInfo@417bffb8 controlFlags=#105
2014-07-15 09:09:16.912 2 3840/InputMethodManager: Starting input: Bind result=InputBindResult{com.android.internal.view.IInputMethodSession$Stub$Proxy@41855d68 com.cootek.smartinputv5/.TouchPalIME #63}
Lahko sedaj nekdo pogleda kodo? Tam kjer piše prikaži tekst bi moral prikazati prejeti tekst.
Najlepša hvala za pomoč.
marjan_h ::
Opazil sem da sedaj samo ko pritisnem na dotično napravo v listview mi crasha.
                connect.start();
Je to pravilno s strani listview sprogramirano?
Sry za double post. Hvala za pomoč.
C#, OBD2 in branje iz porta
Oddelek: Programiranje
192092 (1709) detroit
[Android] Thread
81614 (1391) Spura
[android] vstavljanje slike
71673 (1570) messi
[Android]Cudno obnasanje aplikacije in emulatorja
71673 (1502) KernelPanic
[JAVA] zaustavitev niti (threadov)
223696 (3696) morbo
