[Android]Cudno obnasanje aplikacije in emulatorja
KernelPanic ::
Spostovani!
Sem zacetnik pri Androidu in danes ste mi ze pomagali resiti problem z php posiljanjem podatkov v android aplikacijo. Nastavitev projekta samega nisem nic spreminjal niti nastavitev emulatorja, vendar, ko poizkusim sedaj pognati mojo aplikacijo, se stvar ne zazene, v debug oknu pa se izpise nekaj cudnega:
Attaching to localhost:8606
User program running
Thread 9 Thread-10 stopped at Instrumentation.java:1405.
. Se prej se v emulatorju pojavi:
Sorry! The process android.process.acore has stopped unexpcetledly. Please try again.
. Kaj se dogaja?
KernelPanic ::
Torej, sedaj sem nasel napako, vendar mi ni jasno, zakaj se pojavlja. Torej, ob startu aplikacije se mi pojavi splash screen, ki nato po 3,5 sek izgine in in bi se morala pojaviti activity za pregled kategorij produktov. Tukaj je koda:
    public void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
        setContentView(R.layout.cactivitysplashscreen);
        Thread mythread=new Thread()
            @Override
            public void run()
                try
                    while(splashActive&&ms<splashTime)
                        if(!paused)
                            ms+=100;
                        sleep(100);
                catch(Exception ex)
                    Log.wtf(CActivitySplashScreen.m_strLogTag,
                    ex.getClass().getName()+":"+
                    ex.getMessage().toString());
                finally
                    try
                        Intent intent=new Intent(CActivitySplashScreen.this,
                                                 CActivityBrowseCategories.class);
                        startActivity(intent);
                    catch(Exception ex)
                    finally
                    }   // try-catch-finally
            }   // run
        mythread.start();
V vrstici startActivity pride do exceptiona "Activity not found.". Zakaj mi ne najde activity-ja?
Lp,
M.
krho ::
Ker ga nisi vpisal v manifest?
KernelPanic ::
Seveda sem dal, tukaj je manifest file:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.test.testapp"
    android:versionCode="1"
    android:versionName="1.0">
    <uses-sdk
        android:minSdkVersion="10"
    <application android:label="@string/app_name" >
        <activity android:name=".CActivitySplashScreen"
                  android:noHistory="true">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity android:name=".CActivityLoginScreen"
                  android:label="@string/label_register_si"
        </activity>
        <activity android:name=".CActivityRegisterScreen"
                  android:label="@string/label_login_screen_si"
                  android:noHistory="false">
        </activity>
        <activity android:name=".CActivityBrowseCategories">
                  android:theme="@android:style/Theme.NoTitleBar">
        </activity>
    </application>
    <uses-permission
        android:name="android.permission.INTERNET">
    </uses-permission>
</manifest>
KernelPanic ::
Katerokoli od activities podam v intent kodo:
                    try
                                                 CActivityMainScreen.class);
                    catch(Exception ex)
                    finally
mi je po splash screenu ne pozene, ampak app izvisi in nonstop se kaze splash screen. Kaj delam narobe?
Kocka ::
Domnevam, da je problem v tem, ker se startActivity() kliče iz drugega threda, kot je UI. Predlagam, da najprej poskusiš prestaviti startActivity() ven iz novega threda, če se le ta v tem primeru štarta.
Problem se reši s pomočjo Handlerja in njegove funkcije post() ki pošlje UI threadu ukaz, da naj kliče startActivity(). Primer sem našel tule: http://www.mail-archive.com/android-dev...
Elegantnejša rešitev bi pa bila uporaba asyncTask razreda.
KernelPanic ::
Samo ista koda je, preden sem zacel dodajati nove activity-je (z pripadajocimi xml GUI izgledi), delovala brez problemov. Se nekaj, mogoce offtopic: V catch stavku je log in izpis napake v zgornji kodi, kar pomeni, da se to nekam zapise. Kje je vrednost Log stavka vidna v NetBeans, ker, ko postavim breakpoint na log stavek, se tam ustavi, kar pomeni, da je prislo do exceptiona, vendar izpisa nikjer v NetBeans ne vidim. Bom pogledal kako je z temi threadi. Ta koda je narejena po vzorcnem primeru za splah screen na naslovu http://androidcookbook.com/Recipe.seam;....
KernelPanic ::
Torej, ujel sem exception:
java.lang.IllegalStateException: ArrayAdapter requires the resource ID to be a TextView
Kako naj naredim custom view za element v ListView-u. Naredil sem sledece:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
        android:orientation="horizontal"
        android:layout_width="fill_parent"
        android:layout_height="fill_parent">
        <TextView android:id="@+id/item_mainscreen_text"
            android:gravity="center"
            android:textSize="22dip"
            android:textColor="#ffffff"
            android:textStyle="bold"
            android:layout_height="wrap_content"
</LinearLayout>
To je file citemmainscreen.xml. Kaj moram dati v vrstico:
            setListAdapter(new ArrayAdapter<String>(this,
                                                    R.layout.citemmainscreen,
                                                    items));
? Ali R.layout.citemmainscreen (ne dela), probal sem R.id.item_mainscreen_text pa tudi ne dela. Mi lahko kdo pomaga?
[Android] Bluetooth aplikacija
Oddelek: Programiranje
51501 (1364) marjan_h
[android] java.lang.RuntimeException
141406 (1098) piki12
[android] vstavljanje slike
71673 (1570) messi
[Android]Vrnitev v "parent" activity
102226 (2099) KernelPanic
[Android]Upper Banner vprasanje
113195 (3101) KernelPanic
