Forum » Programiranje » [C] FTDI Enostaven primer
Voluharr ::
Sprogramirati skušam SPI komunikacijo vendar, kakor vidim se je težava pojavila že takoj na začetku.
Source: tukaj.
Problem nastane v vrstici 203. Program se ustavi / ne gre naprej.
Enkrat samkrat, mi je javilo napako FT_OTHER_ERROR stran 99: FT_STATUS.
Najlepša hvala za pomoč (če je možna).
Source: tukaj.
* \file sample-dynamic.c
* \author FTDI
* \date 20110512
* Copyright ˆ 2011 Future Technology Devices International Limited
* Company Confidential
* Project: libMPSSE
* Module: SPI Sample Application - Interfacing 94LC56B SPI EEPROM
* Rivision History:
* 0.1 - 20110512 - Initial version
* 0.2 - 20110801 - Changed LatencyTimer to 255
* Attempt to open channel only if available
* Added & modified macros
* Included stdlib.h
* 0.3 - 20111212 - Added comments
/* Include files */
/* Standard C libraries */
#include<stdio.h>
#include<stdlib.h>
/* OS specific libraries */
#ifdef _WIN32
#include<windows.h>
#endif
#ifdef __linux
#include<dlfcn.h>
#endif
/* Include D2XX header*/
#include "ftd2xx.h"
/* Include libMPSSE header */
#include "libMPSSE_spi.h"
/* Macro and type defines */
/* Helper macros */
#ifdef _WIN32
#define GET_FUN_POINTER GetProcAddress
#define CHECK_ERROR(exp) {if(exp==NULL){printf("%s:%d:%s(): NULL expression encountered \n",__FILE__, __LINE__, __FUNCTION__);exit(1);}else{;}};
#endif
#ifdef __linux
#define GET_FUN_POINTER dlsym
#define CHECK_ERROR(exp) {if(dlerror() != NULL){printf("line %d: ERROR dlsym\n",__LINE__);}}
#endif
#define APP_CHECK_STATUS(exp) {if(exp!=FT_OK){printf("%s:%d:%s(): status(0x%x) != FT_OK\n",__FILE__, __LINE__, __FUNCTION__,exp);exit(1);}else{;}};
#define CHECK_NULL(exp){if(exp==NULL){printf("%s:%d:%s(): NULL expression encountered \n",__FILE__, __LINE__, __FUNCTION__);exit(1);}else{;}};
/* Application specific macro definations */
#define SPI_DEVICE_BUFFER_SIZE 256
#define SPI_WRITE_COMPLETION_RETRY 10
#define START_ADDRESS_EEPROM 0x00
#define END_ADDRESS_EEPROM 0x10
#define RETRY_COUNT_EEPROM 10
#define CHANNEL_TO_OPEN 0 /*0 for first available channel, 1 for next... */
#define SPI_SLAVE_0 0
#define SPI_SLAVE_1 1
#define SPI_SLAVE_2 2
#define DATA_OFFSET 4
typedef FT_STATUS (*pfunc_SPI_GetNumChannels)(uint32 *numChannels);
pfunc_SPI_GetNumChannels p_SPI_GetNumChannels;
typedef FT_STATUS (*pfunc_SPI_GetChannelInfo)(uint32 index, FT_DEVICE_LIST_INFO_NODE *chanInfo);
pfunc_SPI_GetChannelInfo p_SPI_GetChannelInfo;
typedef FT_STATUS (*pfunc_SPI_OpenChannel)(uint32 index, FT_HANDLE *handle);
pfunc_SPI_OpenChannel p_SPI_OpenChannel;
typedef FT_STATUS (*pfunc_SPI_InitChannel)(FT_HANDLE handle, ChannelConfig *config);
pfunc_SPI_InitChannel p_SPI_InitChannel;
typedef FT_STATUS (*pfunc_SPI_CloseChannel)(FT_HANDLE handle);
pfunc_SPI_CloseChannel p_SPI_CloseChannel;
typedef FT_STATUS (*pfunc_SPI_Read)(FT_HANDLE handle, uint8 *buffer, uint32 sizeToTransfer, uint32 *sizeTransfered, uint32 options);
pfunc_SPI_Read p_SPI_Read;
typedef FT_STATUS (*pfunc_SPI_Write)(FT_HANDLE handle, uint8 *buffer, uint32 sizeToTransfer, uint32 *sizeTransfered, uint32 options);
pfunc_SPI_Write p_SPI_Write;
typedef FT_STATUS (*pfunc_SPI_IsBusy)(FT_HANDLE handle, bool *state);
pfunc_SPI_IsBusy p_SPI_IsBusy;
/* Global variables */
uint32 channels;
FT_HANDLE ftHandle;
ChannelConfig channelConf;
uint8 buffer[SPI_DEVICE_BUFFER_SIZE];
/* Public function definitions */
* \brief Main function / Entry point to the sample application
* This function is the entry point to the sample application. It opens the channel, writes to the
* EEPROM and reads back.
* \param[in] none
* \return Returns 0 for success
* \sa
* \note
* \warning
int main()
#ifdef _WIN32
#ifdef _MSC_VER
HMODULE h_libMPSSE;
#else
HANDLE h_libMPSSE;
#endif
#endif
#ifdef __linux
void *h_libMPSSE;
#endif
FT_STATUS status;
FT_DEVICE_LIST_INFO_NODE devList;
uint8 address=0;
uint16 data;
int i,j;
uint32 sizeToTransfer, sizeTransfered;
channelConf.ClockRate = 10000;
channelConf.LatencyTimer = 1;
channelConf.configOptions = SPI_CONFIG_OPTION_MODE0|SPI_CONFIG_OPTION_CS_DBUS3;
channelConf.Pin = 0x00000000;/*FinalVal-FinalDir-InitVal-InitDir (for dir 0=in, 1=out)*/
/* load library */
#ifdef _WIN32
#ifdef _MSC_VER
h_libMPSSE = LoadLibrary(L"libMPSSE.dll");
#else
h_libMPSSE = LoadLibrary("libMPSSE.dll");
#endif
if(NULL == h_libMPSSE)
printf("Failed loading libMPSSE.dll. \nPlease check if the file exists in the working directory\n");
exit(1);
#endif
#if __linux
h_libMPSSE = dlopen("libMPSSE.so",RTLD_LAZY);
if(!h_libMPSSE)
printf("Failed loading libMPSSE.so. Please check if the file exists in the shared library folder(/usr/lib or /usr/lib64)\n");
exit(1);
#endif
/* init function pointers */
p_SPI_GetNumChannels = (pfunc_SPI_GetNumChannels)GET_FUN_POINTER(h_libMPSSE, "SPI_GetNumChannels");
CHECK_NULL (p_SPI_GetNumChannels);
p_SPI_GetChannelInfo = (pfunc_SPI_GetChannelInfo)GET_FUN_POINTER(h_libMPSSE, "SPI_GetChannelInfo");
CHECK_NULL(p_SPI_GetChannelInfo);
p_SPI_OpenChannel = (pfunc_SPI_OpenChannel)GET_FUN_POINTER(h_libMPSSE, "SPI_OpenChannel");
CHECK_NULL(p_SPI_OpenChannel);
p_SPI_InitChannel = (pfunc_SPI_InitChannel)GET_FUN_POINTER(h_libMPSSE, "SPI_InitChannel");
CHECK_NULL(p_SPI_InitChannel);
p_SPI_Read = (pfunc_SPI_Read)GET_FUN_POINTER(h_libMPSSE, "SPI_Read");
CHECK_NULL(p_SPI_Read);
p_SPI_Write = (pfunc_SPI_Write)GET_FUN_POINTER(h_libMPSSE, "SPI_Write");
CHECK_NULL(p_SPI_Write);
p_SPI_CloseChannel = (pfunc_SPI_CloseChannel)GET_FUN_POINTER(h_libMPSSE, "SPI_CloseChannel");
CHECK_NULL(p_SPI_CloseChannel);
p_SPI_IsBusy = (pfunc_SPI_IsBusy)GET_FUN_POINTER(h_libMPSSE, "SPI_IsBusy");
CHECK_NULL(p_SPI_IsBusy);
status = p_SPI_GetNumChannels(&channels);
APP_CHECK_STATUS(status);
printf("Number of available SPI channels = %d\n",channels);
if(channels>0)
for(i=0; i<channels; i++)
status = p_SPI_GetChannelInfo(i,&devList);
printf("Information on channel number %d:\n",i);
/*print the dev info*/
printf(" Flags=0x%x\n",devList.Flags);
printf(" Type=0x%x\n",devList.Type);
printf(" ID=0x%x\n",devList.ID);
printf(" LocId=0x%x\n",devList.LocId);
printf(" SerialNumber=%s\n",devList.SerialNumber);
printf(" Description=%s\n",devList.Description);
printf(" ftHandle=0x%x\n",devList.ftHandle);/*is 0 unless open*/
/* Open the first available channel */
status = p_SPI_OpenChannel(CHANNEL_TO_OPEN,&ftHandle); //Open first channel
printf("\nhandle=0x%x status=0x%x\n",ftHandle,status);
status = p_SPI_InitChannel(ftHandle,&channelConf); //Channel init ####----TUKAJ SE USTAVI----####
status = p_SPI_Write(ftHandle, buffer, sizeToTransfer, &sizeTransfered, SPI_TRANSFER_OPTIONS_SIZE_IN_BYTES | SPI_TRANSFER_OPTIONS_CHIPSELECT_ENABLE);
status = p_SPI_CloseChannel(ftHandle);
return 0;
Backup, VPS, kolokacija: https://reavisys.si
- spremenil: Voluharr ()
lukapivk ::
Pozdravljen,
Sicer tvojega problema ne poznam, vendar imam kar nekaj izkušen s podjetjem FTDI in ti priporočam da si čim hitreje najdeš nadomestilo.
Predvsem so problemi s njihovimi VNC2L čipi, za katere so rabili pol leta po izdaji da so vsaj pribljižno uporabni.
Luka
Luka
Qcube ::
Kaj na tem delu ne rabiš nič skonfigurirat?
predvsem channelConf.Pin = 0x00000000; izgleda sumljiv.
Voluharr ::
Torej imam FT4232H mini modul. Tisti channelConf.Pin je čisto OK.
Zadeva mi sedaj deluje, problem je bil pa sledeč:
Na VCIO in reset nisem imel povezanih 3.3 V, vendar kljub temu ni vrnilo nobene napake. Sedaj zadeva deluje.
Problem je rešen in hvala za pomoč!
KernelPanic ::
Torej imam FT4232H mini modul. Tisti channelConf.Pin je čisto OK.Zgoraj prikazana koda je tvoja ali od podjetja?
| » | Arduino in luči (strani: 1 2 )Oddelek: Elektrotehnika in elektronika | 14780 (12406) | FX6300B |
| » | C in funkcije ter #defineOddelek: Programiranje | 4948 (3309) | misek |
| » | [C/C++] unsigned long lala = -1;Oddelek: Programiranje | 1616 (1575) | Vesoljc |
| » | Uporaba .dllOddelek: Programiranje | 1884 (1844) | Vesoljc |
| » | Win32 API in C++Oddelek: Programiranje | 1963 (1834) | Monster |
