[C/C++] unsigned long lala = -1;
BigWhale ::
Kdaj je tole upravicno in smiselno?! narediti?
Glede na to, da compiler warninge ven pljuva... ;>
OwcA ::
Nikoli. ;)
BigWhale ::
Se mi je zdelo...
Vesoljc ::
zakja pa ne :)
const unsigned int uint32_max = -1;
so pa seveda tudi lepšejši načini
BigWhale ::
Na primer?
Vesoljc ::
zdej ne vem kako je sz standardom ampak dotične implementacije std-ja imajo razne limits, numeric_limits template (dinkumware, hp, itd...). no, devc++ inu msvc7 imata tudi limits.h, ampak guess what :)
iz devc++ (pomoje lahko objavimo?)
/* This administrivia gets added to the beginning of limits.h
   if the system has its own version of limits.h.  */
/* We use _GCC_LIMITS_H_ because we want this not to match
   any macros that the system's limits.h uses for its own purposes.  */
#ifndef _GCC_LIMITS_H_  /* Terminated in limity.h.  */
#define _GCC_LIMITS_H_
#ifndef _LIBC_LIMITS_H_
/* Use "..." so that we find syslimits.h only in this same directory.  */
#include "syslimits.h"
#endif
#ifndef _LIMITS_H___
#define _LIMITS_H___
/* Number of bits in a `char'.  */
#undef CHAR_BIT
#define CHAR_BIT __CHAR_BIT__
/* Maximum length of a multibyte character.  */
#ifndef MB_LEN_MAX
#define MB_LEN_MAX 1
#endif
/* Minimum and maximum values a `signed char' can hold.  */
#undef SCHAR_MIN
#define SCHAR_MIN (-SCHAR_MAX - 1)
#undef SCHAR_MAX
#define SCHAR_MAX __SCHAR_MAX__
/* Maximum value an `unsigned char' can hold.  (Minimum is 0).  */
#undef UCHAR_MAX
#if __SCHAR_MAX__ == __INT_MAX__
# define UCHAR_MAX (SCHAR_MAX * 2U + 1U)
#else
# define UCHAR_MAX (SCHAR_MAX * 2 + 1)
#endif
/* Minimum and maximum values a `char' can hold.  */
#ifdef __CHAR_UNSIGNED__
# undef CHAR_MIN
# if __SCHAR_MAX__ == __INT_MAX__
#  define CHAR_MIN 0U
# else
#  define CHAR_MIN 0
# endif
# undef CHAR_MAX
# define CHAR_MAX UCHAR_MAX
#else
# undef CHAR_MIN
# define CHAR_MIN SCHAR_MIN
# undef CHAR_MAX
# define CHAR_MAX SCHAR_MAX
#endif
/* Minimum and maximum values a `signed short int' can hold.  */
#undef SHRT_MIN
#define SHRT_MIN (-SHRT_MAX - 1)
#undef SHRT_MAX
#define SHRT_MAX __SHRT_MAX__
/* Maximum value an `unsigned short int' can hold.  (Minimum is 0).  */
#undef USHRT_MAX
#if __SHRT_MAX__ == __INT_MAX__
# define USHRT_MAX (SHRT_MAX * 2U + 1U)
#else
# define USHRT_MAX (SHRT_MAX * 2 + 1)
#endif
/* Minimum and maximum values a `signed int' can hold.  */
#undef INT_MIN
#define INT_MIN (-INT_MAX - 1)
#undef INT_MAX
#define INT_MAX __INT_MAX__
/* Maximum value an `unsigned int' can hold.  (Minimum is 0).  */
#undef UINT_MAX
#define UINT_MAX (INT_MAX * 2U + 1U)
/* Minimum and maximum values a `signed long int' can hold.
   (Same as `int').  */
#undef LONG_MIN
#define LONG_MIN (-LONG_MAX - 1L)
#undef LONG_MAX
#define LONG_MAX __LONG_MAX__
/* Maximum value an `unsigned long int' can hold.  (Minimum is 0).  */
#undef ULONG_MAX
#define ULONG_MAX (LONG_MAX * 2UL + 1UL)
#if defined (__STDC_VERSION__) && __STDC_VERSION__ >= 199901L
/* Minimum and maximum values a `signed long long int' can hold.  */
# undef LLONG_MIN
# define LLONG_MIN (-LLONG_MAX - 1LL)
# undef LLONG_MAX
# define LLONG_MAX __LONG_LONG_MAX__
/* Maximum value an `unsigned long long int' can hold.  (Minimum is 0).  */
# undef ULLONG_MAX
# define ULLONG_MAX (LLONG_MAX * 2ULL + 1ULL)
#endif
#if defined (__GNU_LIBRARY__) ? defined (__USE_GNU) : !defined (__STRICT_ANSI__)
# undef LONG_LONG_MIN
# define LONG_LONG_MIN (-LONG_LONG_MAX - 1LL)
# undef LONG_LONG_MAX
# define LONG_LONG_MAX __LONG_LONG_MAX__
# undef ULONG_LONG_MAX
# define ULONG_LONG_MAX (LONG_LONG_MAX * 2ULL + 1ULL)
#endif
#endif /* _LIMITS_H___ */
/* This administrivia gets added to the end of limits.h
#else /* not _GCC_LIMITS_H_ */
#ifdef _GCC_NEXT_LIMITS_H
#include_next <limits.h>		/* recurse down to the real one */
#endif
#endif /* not _GCC_LIMITS_H_ */
@sergio
ccc... ;)
  • spremenil: Vesoljc ()
Pomoc pri nalogi
Oddelek: Programiranje
152614 (2420) FuI2cY
[C] random do poljubne številke
172513 (2180) napsy
[C/C++] ifdef
101110 (1044) CCfly
[visual c++] #ifdef _DEBUG
51429 (1370) Vesoljc
Unicode
81618 (1509) Vesoljc
