Forum » Strojna oprema » ASUS Sabertooth X79 Windows XP ?
Spc ::
Zanima me če je možno na to plato inštalirati Windows XP (32bit) oz Windows XP (64bit).
Je že kdo probal ? in ja vem tisti ki bo inštaliral 32bitne xpje gor bi vstran vrgel RAM.
Zanima me zaradi kompatibilnosti nekaterih programov.
Kolko vidim ima ASUS driverje za 32bit in 64bit XPje na njihovi spletni strani
http://www.asus.com/Motherboards/Intel_...
kot prvo zakaj bi na X79 sploh nameščal zastareli os kot je windows xp?
wiki pravi tako:
Partial support for Windows XP
The X79 chipset does not support installing Windows XP in AHCI mode for Intel's Serial ATA controllers as Intel won't release AHCI drivers for 32-bit Windows XP. Windows XP can be installed in IDE mode but without SATA features enabled. For users that dual boot Windows XP with another operating system installed in AHCI mode, this means changing to IDE mode every time to boot into Windows XP or install the other OS also in IDE mode. For X79 motherboards with third party SATA disk controllers, Windows XP AHCI drivers may still be supported by the disk controller vendor.
wiki pravi tako:
Spc ::
Še enkrat.
Gre se za kompatibilnost.
Torej če imam sata disk in nastavim na native IDE mode (ne AHCI mode) potem bi vbistvu moralo delovati?
- spremenil: Spc ()
očitno da,če sata porti na matični niso od intel lahko mogoče še dobiš ACHI drvje za Xpje (For X79 motherboards with third party SATA disk controllers, Windows XP AHCI drivers may still be supported by the disk controller vendor)
ta plata ima še 2 marvell sata porta.idi na marvellovo stran in poglej,če imajo driverje za AHCI
- spremenil: mtosev ()
Spc ::
Sem pogledal UEFI "BIOS"
Ta plata ima možnosti:
Sata Mode:
Disabled
IDE Mode
+Compatible
+Enhanced Mode
AHCI Mode
Raid Mode
Torej bi moralo hardwaresko supportat 32bitne ali 64bitne xpje.
Sata Mode:
Disabled
IDE Mode
+Compatible
+Enhanced Mode
AHCI Mode
Raid Mode
- spremenil: Spc ()
| » | SSD in AHCI modeOddelek: Strojna oprema | 7382 (5373) | AC_DC |
| » | Kako dodati XP k že naloženi visti z AHCI v biosuOddelek: Operacijski sistemi | 3656 (2633) | Gutjerez |
| » | Kako nastaviti RAID1 ???Oddelek: Pomoč in nasveti | 2261 (2173) | t3hn0 |
| » | Win XP - problemi z SATA/RAID driverjiOddelek: Pomoč in nasveti | 1395 (1299) | SkyMan666 |
| » | sata/ide nepravilno razumevanje pojma!Oddelek: Strojna oprema | 3718 (3391) | Icematxyz |
