Kopija sistema iz SSD na SSD
TOP ::
Imam sistem gor na SSD in sedaj sem nabavu drugega in me zanima s katerim programom lahko tole prenesem na drugega,ker ne bi rad še enkrat gor dajal na novo sistem in če je to sploh pametno,ali bolše na novo.Hvala
Janac ::
copy|paste!
TOP ::
Tole sigurno ne.bi potem delalo,ker vseh datotek ne bi preneslo.
Janac ::
clone disk?
TOP ::
Kateri pa je najbolši program za tole.
blue ::
norton ghost je ok
krneki0001 ::
clonezila - pa še zastonj je.
Zheegec ::
večina ssdjev ima takšen program že zraven - Intelov ima recimo software, ki vse naredi sam. Izbereš samo izvor pa tarčo... Edino novi disk mora biti enak ali večji. 60GB iz vertexa na intela mi je prekopiralo v 5min :)
TOP ::
Ja ta stari disk je 120gb ta novi je Samsung 128 gb.Tukaj ne bi smelo biti problemov,sedaj edino če ma Samsung takšen program.
Anney ::
Samsung ima Norton Ghost, maš aplikacijo disc clone v SSD Magician, katerega dobiš poleg.
TOP ::
Hvala ti,zdej sem videl ko sem odprl škatlo.
Anney ::
krneki0001 je izjavil:
Se strinjam.
Če imaš težave pri kloniranju iz večjega izvornega diska na manjšega novega, potem napravi te korake:
https://www.ubackup.com/articles/clonez...
Why use Clonezilla to clone larger disk to smaller disk?
As an open source free software, Clonezilla can be used to clone or backup hard drive. Since it works with most of the operating systems largely used in company or home, many people love to use Clonezilla, especially when they want to upgrade hard drive with a new one. In this case, you can use Clonezilla disk to disk clone feature to clone a hard drive to another without reinstalling Windows and programs.
However, the destination drive to replace the old one is not generally the same size or larger than the source drive. Since the excellent performance of SSDs and they have become increasingly cheaper recently, many users want to clone larger HDD to smaller SSD using Clonezilla. If you happen to in this situation, you can make some extra efforts to get this done.
Make Clonezilla clone to smaller drive possible
Officially, Clonezilla requires the destination partition to receive the clone to be equal or larger than the source one. Therefore, the only way to get this done is to shrink the source partition to fit the destination partition.
Clonezilla clone to smaller disk:
Step 1. Open Disk Management in Windows 10/8/7. If you are running Linux system, you can boot your computer from GParted media.
Step 2. Right click the source partition and click “Shrink Volume” and follow the wizard to shrink the partition.
Step 3. When you get that done, reboot to Clonezilla.
Step 4. Select the source disk and destination disk.
Step 5. Choose EXPERT mode and enable the “-icds” option. You need to also choose the option"Resize partitional table proportionally" in one of the following menus.
Extra Parameters
Step 6. Configure other Clonezilla options if needed and then type in “y” to confirm and start the clone.
In this way, you should be able to clone larger drive to smaller drive without receiving the error like Clonezilla failed to create a partition table on this disk.
Valvoline ::
Acronis true image bootcd je preverjeno najboljsi za kloniranje. V win okolju lahko z programom macrium reflect.
Varnostna kopija sistemskega diska
203426 (2575) nicksonn
Izvoz digitalnih potrdil iz nedelujočega računalnika (strani: 1 2 )
6610328 (8724) solatko
težave z zagonom računalnika po kloniranju diskov
477952 (6958) gruntfürmich
Diagnostično orodje za WD
Oddelek: Programska oprema
145036 (4896) clovk
kloniranje diska
355268 (4398) solatko
