3d shader model
3d shader model
miha121 ::
Pozdravljeni,
mi je uspelo uštimat prejšen problem z računalnikom, zdaj pa me zanima, če moram nujno zamenjati grafično, ali je kaj drugega. Rad bi igral igro landwirtschafts simulator 2011.
Grafična je pa:intel dtc-aat06 intel core duo delta. Grafična pa nvidia sli.
Pa hvala za odgovore. Se pa tudi zahvaljujem, ker ste mi v prejšnjem postu pomagali.
  • polepsal: Mavrik ()
69charger ::
Prenesi si programček CPUID CPU-Z pa nam povej točno ime procesorja in grafične kartice.
miha121 ::
Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
DMI BIOS
vendor American Megatrends Inc.
version 080014
date 04/10/2009
DMI System Information
manufacturer BIOSTAR Group
product G31-M7 TE
version unknown
serial None
UUID {03000200-0400-0500-0006-000700080009}
DMI Baseboard
vendor BIOSTAR Group
model G31-M7 TE
revision unknown
serial None
DMI System Enclosure
chassis type Desktop
chassis serial None
DMI Processor
manufacturer Intel
model Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
clock speed 2600.0 MHz
FSB speed 200.0 MHz
multiplier 13.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation DIMM0
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY1
Name Intel(R) G33/G31 Express Chipset Family
Memory size 256 MB
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1565)
Model ID 0x29C2 (0x3103)
Performance Level 0
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 10.0
Isotropic ::
tle ti pise, da mas graficno onboard maticne - intel g33.
prestavi konektorje na nv graficno.
http://slo-tech.com/forum/t490013/zacet...
lol, tak racunalnik si kupil? kuk si pa dal zanj?
Mesar ::
Ja mogoče je kdo po pomoti resetiral za BIOS.
Your turn to burn!
miha121 ::
Ne,to je družinski rač.za šolo,itd.Tistega pa nisem kupil.Cene ne vem,predvidevam da je slab računalnik?
Kam moram prestavit konektorje?
Kako pa vem za BIOSE.
Hvala za odgovore.
Mesar ::
ja BIOSE se na novo nastavi...
Your turn to burn!
miha121 ::
Koliko pa to stane na servisu,tako povprečno +,-€?
Isotropic ::
poglej zadaj, k so tiste reze vodoravne, ce mas kaksne izhode za prikljucek za monitor. poj pa sam odvij ta prikljucek z maticne plosce pa ga privij tam. na servisu ti dobesedno nimajo kaj delat, ker to moras itak zunaj kiste doma naredit.
miha121 ::
In potem bi moralo delati,mislim landwirtschafts simulator 2011,2009?
Če lahko samo še to obrazložiš,kam ga privijem?Če sem razumel,najprej odprem kišto,tisti priključek na katerem je kabel za ekran odvijem,in ga priključim na grafično?
Pa hvala za odg.
  • spremenilo: miha121 ()
miha121 ::
Senitel ::
Nič ne rabiš odpirat kište. Zadaj imaš trenutno kabel za monitor na matično pritrjen, sedaj ga pa prestavi nižje dol na grafično.
miha121 ::
Ampak nižje je le neka mrežica,tam kjer bi moralo to biti.Se jo pa da odstranit.
Ampak ni ničesar.Tudi ko sem že odprl računalnik je bila grafična drugje priklopjena,ni v bližini ohišja.
Janac ::
Slikaj zadnji del racunalnika
Kako ni v blizini ohisja?
  • spremenil: Janac ()
Senitel ::
Od kje si sploh potegnil: "Grafična pa nvidia sli."
miha121 ::
Janac ::
haha
nimas nobene druge grafe
nvidia sli je nalepka na ramu
miha121 ::
Ja oprosti če ne vem.kaj se spravlate na neizkušnga človeka.
Kje pa je grafična kartica?
Senitel ::
Je ni. Grafična logika je integrirana v chipset na matični.
miha121 ::
Pa se da useeno nekak uštimat,da mi ne bo napisalo:Shader model 3.0 is required?
Janac ::
kupi kako graficno
miha121 ::
Mah,grafične so drage kot pes.Res ni drugega načina?
Senitel ::
Ma saj ne rabiš nevem kakšne krave. Tole ali pa tole bo že dovolj.
miha121 ::
Janac ::
a sploh mas pcie vodilo
miha121 ::
Kako pa to zgleda?
Je to tisti nosilec?
Koliko pa stane?
Senitel ::
G31-M7 TE ima PCI-Ex ja. Pač nabavi grafično, vtakni v kišto, preklopi kabl za monitor na grafično in inštaliraj driverje. Če ti pride na pamet kaj žagat, potem si na napačni poti.
Janac ::
kater napajalnik pa mas?
miha121 ::
Kako si mislil žagat?
Grafična bo tista tadruga dobra?
Janac ::
jaz ti predlagam rabljeno 5770
miha121 ::
hkc sz-430-lpdr
miha121 ::
Samo še tole bi rad uprašal.Če bo tale grafična pasala na moj računalnik,glede teh vodil,itd? http://www.mlacom.si/zotac-zt-50604-10l...
Senitel ::
da
Janac ::
Zakaj ne kupis rabljene 5770 je bolsa!!!!!!
miha121 ::
Kje jo čem pa dobit?
Pa saj ta ima shader model 5.0,jaz pa 3.0 rabim.Bo kar vredi.
Janac ::
Na bolhi
Je hitrejsa od te
Isotropic ::
miha121 je izjavil:
problem je, k bo lw simulator 2012 rabil pa shader model 4.0 ane
miha121 ::
Sem probal in deluje.
Pa hvala vsem za odgovore.
navijanje E7500
Oddelek: Navijanje
433291 (2174) grobar
ugašanje in restartanje računalnika
236716 (6369) Cold1
Ali je tale računalnik dober ali bi za takšen denar dobil kaj boljšega?
61967 (1780) IVo
Kateri ram kupiti?
101095 (1095) tom13
Procesor ko žerjavica?
112081 (1847) T0RN4D0
