Forum » Pomoč in nasveti » rar,zip
rar,zip
Gray_Warden ::
What is the difference between ZIP and RAR encryption?
ZIP format uses a proprietary encryption algorithm.
RAR archives are encrypted by the much stronger AES-128
standard. If you need to encrypt important information,
it is better to select the RAR archive format.
ZIP:
The Zip 2.0 encryption format is known to be relatively weak,
and cannot be expected to provide protection from individuals with
access to specialized password recovery tools.
If you have important security requirements for your data,
you should look into more robust cryptography solutions.
RAR:
RAR archives are encrypted by the much stronger AES-128 standard.
If you need to encrypt important information, it is better to
For real security use passwords of at least 8 characters in length.
Do not use words of any language as passwords.
It is better to choose a random combination of
characters and digits.
Note that passwords are case sensitive.
Remember that if you lose your password,
you will unable to retrieve the encrypted files.
Not even the WinRAR author is able to extract encrypted files.
(see the chapter Encryption in the WinRAR help file)
vir: http://www.win-rar.com/index.php?id=24&...
ZIP:
RAR:
- spremenilo: Gray_Warden ()
OmegaBlue ::
To je enkripcija kar si ti nalimal, ne kompresija.
Gray_Warden ::
vem. ampak to je za splošnega uporabnika še največja razlika med zip in rar. če bi človek rad boljšo razlago pa je na googlu več kot preveč opisov.
| » | Kim Dotcom zagnal kriptografsko oblačno storitev Mega (strani: 1 2 )Oddelek: Novice / Omrežja / internet | 49784 (44559) | snezak |
| » | Unencrypt...Oddelek: Pomoč in nasveti | 1647 (1540) | solatko |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2451 (2296) | jast |
| » | Izšel TrueCrypt 4.0Oddelek: Novice / Ostala programska oprema | 5843 (4984) | poweroff |
| » | winRAR error - CRC failed in the encrypted file fajl.md0 (wrong password ?)Oddelek: Programska oprema | 2054 (2011) | Xplicit |
