Delphi in [ ???
Delphi in [ ???
CWIZO ::
Imam delphi 6.
In za boga ne vem zakaj mi [ (oglati oklepaj) ne dela, ne morem ga pritisniti na tipkovnici lahko ga samo pejstam iz kšnga drugega progija.
Med tem ko ] dela bp
Se kermu sanja kaj bi to bilo ?
hancic.info
I can't uninstall it, there seems to be some kind of "Uninstall Shield"...
mile ::
Ja, poznan problem.
Osebno imam dve rešitve.
-Med programiranjem preklopim na agleško tipkovnoco.
-V CodeInside si dodam nov vnos [] , ki je dosegljiv preko bljižnice CTRL+J
LoneWolf ::
Programerji ocitno ne berejo(-mo) Readme.txt datotek...
Iz Delphi 6 Readme.txt:
Menu Shortcut Conflicts
Menu shortcuts in the IDE may conflict with system shortcuts
and international character key combinations. If you want to
disable the Ctrl+Alt hot keys in the IDE, set this DWORD
registry key:
HKEY_CURRENT_USER\Software\Borland\Delphi\6.0\
Editor\Options\NoCtrlAltKeys
to "1".
Gandalfar ::
CWIZO ::
hvala !
hancic.info
Neoster ekran
191166 (817) carlito149
Instalacija XP ne najde diska
Oddelek: Operacijski sistemi
416604 (5467) fredyjetle
barve v process explorerju
101925 (1808) veteran
RAM problem
252234 (2011) drLinux
linux install
382097 (1680) CCfly
