centos - hdparam - command not found
BRBR ::
1.live cd
2.login as root
3 .su -
ne pomaga
4. /sbin/hdparm
ne pomaga, čeprav vidim da je hdparam tam
5. se premaknem na(/sbin/hdparm) & hdparam
ne pomaga
Vidim da je ifconfig v istem direktoriju, ta pa dela.
smartctl -a /dev/sdb
mi pokaže da je ta disk kao zanič, rabim izvedet njegovo serijsko.
Vem jo že ker sem jo našel z GsmartControl, samo se hočem še enkrat okol ovinka prepričat.
S fsck -c nisem prišel nikamor, obesi se nekje pri 10%.
smartctl -a /dev/sdb > bad-disk.txt
smartctl version 5.38 [i686-redhat-linux-gnu] Copyright © 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.11
Device Model: ST3500320AS
Serial Number: 9QM70Y82
Firmware Version: SD15
User Capacity: 500,107,862,016 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Tue Oct 18 06:47:54 2011 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 650) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 118) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103b) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 087 084 006 Pre-fail Always - 137893795
3 Spin_Up_Time 0x0003 098 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 129
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 1998
7 Seek_Error_Rate 0x000f 076 060 030 Pre-fail Always - 13044143173
9 Power_On_Hours 0x0032 079 079 000 Old_age Always - 19149
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 1
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 129
184 Unknown_Attribute 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 793
188 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 068 047 045 Old_age Always - 32 (Lifetime Min/Max 32/32)
194 Temperature_Celsius 0x0022 032 053 000 Old_age Always - 32 (0 14 0 0)
195 Hardware_ECC_Recovered 0x001a 044 021 000 Old_age Always - 137893795
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 49
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 49
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 1039 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 1039 occurred at disk power-on lifetime: 19135 hours (797 days + 7 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 71 04 9d 00 32 e0 Device Fault; Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
a1 00 00 00 00 00 a0 00 00:01:26.506 IDENTIFY PACKET DEVICE
ec 00 00 00 00 00 a0 00 00:01:26.502 IDENTIFY DEVICE
00 00 00 00 00 00 00 04 00:01:26.350 NOP [Abort queued commands]
00 00 00 00 00 00 00 ff 00:01:26.047 NOP [Abort queued commands]
a1 00 00 00 00 00 a0 00 00:01:21.006 IDENTIFY PACKET DEVICE
Error 1038 occurred at disk power-on lifetime: 19135 hours (797 days + 7 hours)
ec 00 00 00 00 00 a0 00 00:01:21.003 IDENTIFY DEVICE
Error 1037 occurred at disk power-on lifetime: 19135 hours (797 days + 7 hours)
00 00 00 00 00 00 00 04 00:01:20.852 NOP [Abort queued commands]
00 00 00 00 00 00 00 ff 00:01:20.550 NOP [Abort queued commands]
a1 00 00 00 00 00 a0 00 00:01:15.527 IDENTIFY PACKET DEVICE
Error 1036 occurred at disk power-on lifetime: 19135 hours (797 days + 7 hours)
ec 00 00 00 00 00 a0 00 00:01:15.488 IDENTIFY DEVICE
Error 1035 occurred at disk power-on lifetime: 19135 hours (797 days + 7 hours)
c8 00 08 77 09 27 e2 00 00:01:12.720 READ DMA
c8 00 08 77 41 0c e0 00 00:01:12.720 READ DMA
c8 00 08 17 9a 26 e2 00 00:01:12.707 READ DMA
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed: read failure 90% 19141 315590
# 2 Short offline Completed: read failure 90% 19141 315597
# 3 Short offline Completed: read failure 90% 19141 315595
# 4 Short offline Completed: read failure 90% 19132 315590
# 5 Short offline Completed: read failure 90% 19132 315597
# 6 Conveyance offline Completed: read failure 90% 19132 315590
# 7 Extended offline Completed: read failure 90% 19132 6212248
# 8 Short offline Completed: read failure 90% 19132 315597
# 9 Short offline Completed: read failure 90% 19132 315597
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
  • spremenil: BRBR ()
amigo_no1 ::
Preveri disk tem:
Diagnostična orodja in reševanje podatkov s trdih diskov
Če je (delno) zanič, naredi risk kalkulacijo ->
1. opcija ga zamenjaš
2. opcija imaš dalje in upaš da ne crkne (do konca).
BRBR ::
Nič, mam že novega.
Hvala za link, je že pod bookmarks.
Never underestimate the power of idiots in large groups.
a mi je crknu disk al ne
132088 (1529) filip007
HDD napake - uveljavitev garancije?
194375 (3614) bijoloh
Po 2 PB zapisanih podatkov tretjina SSD-jev še deluje (strani: 1 2 )
Oddelek: Novice / Diski
6535505 (29379) Laybach
Disk umira
272100 (1385) Ramon dekers
[Linux - Grub] OS se mi noče naložiti
Oddelek: Operacijski sistemi
191945 (1660) kriko1
