Forum » Pomoč in nasveti » Black ops pomoč
Black ops pomoč
mokasin ::
Ker mi black ops slabo dela sem se odločil da pišem na activision. Prej sem igral z grafičnimi nastavitvami na extra in high zdaj pa še na low dobim največ 18 fps. To je njihov odgovor in potrebujem pomoč pri računalniškem jeziku. Z računalnikom ni nič narobe saj bad company 2 igram na high nastavitvah.
Discussion Thread
Response (Gustavo Renthel) - 08/12/2011 05:08 AM
Dear Blaž,
Thank you for your email.
For future correspondence concerning this case, please refer to the following reference number when contacting Activision Customer Support: 110809-000522
Be sure that your computer is not behind a software or hardware firewall of any kind. This includes firewalls built into routers or other equipment, as well as programs like Zone Alarm, Black Ice, and the integrated firewall in Windows XP. Activision does not support the use of our games from behind a firewall. If it is not possible to disable the firewall you will need to open the ports for Call of Duty: Black Ops. Black Ops transmits and receives network traffic on port 3074 (UDP and TCP). Additionally the Steam client transmits and receives network traffic on ports UDP: 27000-27015, 27015-27030 and TCP: 27014-27050. The exact details on opening a port is specific to your firewall. For more information check with the firewall documentation or manufacturer.
Another common cause of problems is a poorly configured router or connection sharing solution. If you are using a router, ICS, NAT or a software gateway you may have problems playing on the internet. This is because the router may not be forwarding the correct information back to your machine. It may be possible to get around this problem using port forwarding or DMZ. You can find more information on configuring shared connections for multiplayer gaming at www.practicallynetworked.com. Please be aware that like a firewall we cannot actively support using shared connections to play online.
The most common cause of problems though is usually the simplest - an overburdened network stack. By default many computers have protocols the average person doesn't use; things like VPN or NDISWAN. You may want to contact your ISP to find out exactly which protocols you can safely remove. Often times network game problems are resolved by something as simple as removing unused adapters and protocols.
The problem may also be related the the status of your ISP or that of the server. Due to the dynamic nature of the internet and the variable levels of traffic, it is impossible to completely eliminate lag. If you are having persistent problems you may wish to try a different server, or just wait and play a little while later.
Thank you for contacting Activision Customer Support Europe. If you have any further doubts or questions, please don't hesitate contacting us again.
Best regards
Gustavo
Activision Customer Support Team
UK and Ireland Support
Mon - Fri 10.00 - 20.00
Sat 12.00 - 18.00
+44 845 5280 269
+353 1 9036 586
Discussion Thread
Dear Blaž,
Best regards
Gustavo
Sat 12.00 - 18.00
+44 845 5280 269
+353 1 9036 586
- spremenilo: mokasin ()
mihec87 ::
O kakem računalniškem jeziku ti to?
Napiši še konfiguracijo računalnika ter koliko fps si imel prej z to igrico,prav tako kaj je razlika med prej ter sedaj ko dobis manj fps(kaksen nov program,update,strojna oprema itd..)...
Na hitro mail govori o tem da igrca ne deluje dobro izza firewalla zato bi ga bilo potrebno izklopit oz odpret porte...
mokasin ::
Intel core e6500 3.02 GHz
ATI Radeon HD 4650 (navita)
To je kar mam noter. Redno updatam windowse in CCC (to je za grafično). Teh požarnih zidov pa nisem nič spreminju in tudi antivirusni je NOD32 ki ga že imam 2 leti. Prej nevem natančno koliko fps sem imel vendar je igra tekla gladko brez problemov. Sem lahko dropshotu se vrtel okol vse je gladko delal. Problem ni s hardwarom, ker mi ostal igre tečejo dobro. Kot sem prej omenil bfbc2 na high pa crysis na medium.
bluefish ::
Glede na to, da se gre le za igro, je škoda živcev. Odstrani, počisti sledi iz registra, namesti ponovno. Zaženi, na novo nastavi nastavitve, igraj. Namesti popravek(ke) in spet igraj. Če se upad fps-jev pojavi tu, potem imaš krivca in lahko iščeš dalje za rešitev.
- spremenil: bluefish ()
| » | Call of Duty: Black Ops IIII [Call of duty (2018)] (strani: 1 2 )Oddelek: Igre | 20690 (15251) | oo7 |
| » | Call of Duty: Black Ops 3 (Call of Duty 12 (2015) Treyarch) (strani: 1 2 3 4 5 )Oddelek: Igre | 52054 (37696) | oo7 |
| » | VarnostOddelek: Informacijska varnost | 24990 (6691) | techfreak :) |
| » | Security AlertOddelek: Omrežja in internet | 1308 (1209) | bluefish |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2439 (2284) | jast |
