Forum » Omrežja in internet » Security Alert
Security Alert
razzor ::
The firewall has blocked internet access to your computer (NetBIOS session) from 217.72.66.176(TCP Port 4327) (tcp flags:S)
A mi lahk kdo pove kaj to pomeni?!?
To mi skos nabija firewall.
ZoneAlarm Pro blocked access to port 139 on your computer
No breach in your security has occurred. Your computer is safe.
What happened?
ZoneAlarm Pro prevented a remote computer from connecting to port 139 on your computer. If you are sharing files on a local network, this connection attempt was probably legitimate network traffic. Port 139 is commonly used by networked Windows computers to enable file sharing and other resource sharing. However, if the traffic that generated this alert came from the Internet rather than a local network, this may have been attack on your computer!
Kdo me napada ?
What happened?
Kdo me napada ?
- spremenilo: razzor ()
OmegaBlue ::
Nihče te ne napada, večinoma so to samo črvički, ki lazijo po internetu in iščejo kateri genij ima odprt sharing na ven.
strictom ::
Iz istega razloga kot lopov vstopi v hišo, ki ima na stežaj odprta vrata!
Ti imaš pa nasrečo zaklenjena in še zaščitena.
bluefish ::
sicer pa v večini primerov kontakti in napadi "od zunaj" ne pomenijo, da imaš nameščen spyware, trojance,... Bolj zaskrbljujoče bi bilo, če bi nek neznani program nonstop poskušal kontaktirati navzven.
In btw, OS pri tem skorajda nima veze.
- spremenil: bluefish ()
| » | Kateri firewall? (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Informacijska varnost | 136678 (26165) | Qushaak |
| » | VarnostOddelek: Informacijska varnost | 25030 (6731) | techfreak :) |
| » | e-mail naslov in SPAM problemOddelek: Omrežja in internet | 2110 (1944) | alef |
| » | ZoneAlarm in ApacheOddelek: Omrežja in internet | 1640 (1545) | govno |
| » | Kako vem da je moj PC varen pred vdori?Oddelek: Operacijski sistemi | 2319 (2026) | ABX |
