Oslo, teroristicno dejanje
Double_J ::
During interrogation, Breivik has claimed he is part of an "international Christian military order", that "fights" against "Islamic suppression". The order is allegedly called the "Knights Templar", and according to his manifesto has an estimated 15 to 80 "ordinated knights", and an unknown number of "civilian members".[54] The order, whose full name is the "Pauperes commilitones Christi Templique Solomonici", or PCCTS, was allegedly founded in London in April 2002, as a "re-founding" of the millenia-old crusader organisation. The organisation was supposedly founded to take politically and military control over Western Europe, with its members being armed as an "anti-Jihad crusader-organisation". The organisation was reportedly founded by nine members; two Englishmen, and one Frenchman, German, Dutchman, Greek, Russian, Norwegian and Serb. The main initiator was apparently a Serb, whom Breivik claims he visited in Liberia, and whom Breivik refered to as a "war hero". Breivik said his code name to be "Sigurd Jorsalfar", while his "mentor" was "Richard Lionheart". Breivik claimed that Norway had "4,848 traitors" who had to die
Jao pa ne bodo zopet Srbi povod za svetovno vojno...>:D
Dve šivanki...
Gavrilovič princip ftw.
donfilipo ::
Ma kaki Srbi.
Če že gledaš tako, so tudi Srbi nekako demografirani od strani Albancev. Ampak za sprožit svetovno vojno, so pa vseeno lahko samo indic, ali povod in ne vzrok.
Kakorkoli, po vsem prebranem je poleg tega, da je mož bil povsem normalen arijsko hladen škrtica, dokaj uspešen v poslih, po grobi politični svetovni orientaciji libertarec (zgleda, da pri nas tega ne poznamo in res ločimo samo partizane in domobrance:) in nič posebnega. Ni bil ne idiot, ne kreten, ne narkoman in ne kriminalec.
Do tu. Tu pa v boj nekim notranjim travmam, ki izvirajo iz pol skritega konflikta z islamom, kot tujo kulturo, prej kot zgolj religijo, kot kulturo, ki je socialna in še dosti kolektivistična, izgradi svojo namišljeno vojsko v domišljiji.
Po njegovi logiki je več kot očitno, da bo hladni libertarni, pa tudi liberalni individualistični nordijski model, lepo povožen demografsko od južnejšega, kolektivno-socialnega, avtokratskega etnocentričnega islama in da nihče pravzaprav ne ukrene nič, kot zgolj relativizira in problem pometa pod preprogo.
Zgradi si viteško križarsko vojsko, morda ima celo res še par somišljenikov, ampak to je vojska fikcije, vojska norosti. Zgrajena na polpozabljenih mitih potegnjenih iz skupne križarske preteklosti kulturne Evrope, potegnjena na obrambo kulturnega evropejstva pred islamom. Veze z pravim krščanstvom to nima, nima veze več z Kristusovim odpuščanjem, skrbjo za uboge, pomočjo revežem, ostal je le križarski meč. Izzvan z enostavno demografskim prodorom tujih evropsko navidez neavtohtonih kultur.
In? Ali je to dovolj? Je ta fikcija dovolj, da obudi križarsko AlQuedo? Pojma nimam. Najprej bi moral reči ne, ampak če povem iskreno, človeška neumnost, tudi po današnji sposobnosti prenašanja informacije, nima meja...tako da na žalost, moram reči DA. To pomeni odprto fronto med evrokulturo in islamom in na nek način vojno, kot jo imajo USA s terorizmom. Le da EU, tokrat ne stopijo kot plašna deca v okrilje velikega šerifa, ampak kot samostojna razbojniška banda iz pravljice, ki se bo tudi sama zoperstavila prodornemu turku:)
Ja, veliki spopad se bliža, ampak Srbi so že leta 1991 bili samo simptom, znak in opozorilo. Nikakor pa vzrok!
In zgleda da je na sceni nov terorist. Izklopi pa ga lahko samo in zgolj zdrav razum. Cak, z najenostavnejšim stikalom, na katerem piše butelj!
Ali pa ga bomo znali najti, ali bomo od zdaj naprej tiho pritiskali na katalizator spopadov EU-levica-islam, je pa drug problem. Se bojim da se uveljavi, kar pomeni da se seveda čaka še na polmrtvo, ali bodimo iskreni čisto mrtvo res boljševistično levico (bemti mami kam sem dal bombe in šmajser:), in potem se pa norost lahko začne.
In times of Universal Deceit, telling the truth
becomes revolutionary act. Orwell
cortez ::
Kmalu bomo imeli v Sloveniji tuji jezik...slovenščino.
Edino učinkovito orožje proti skrajnežem je še več svobode in še več demokracije.
O.
donfilipo ::
Jihad Driving School????
Pa to je isto kot Banzai Recue Unit.
Jeezus. Evo še en dokaz več, da je hudič lepo nameščen in se smeje in čaka.
Brane2 ::
Tle je problem v tem, da vse ostale aspekte življenja prepuščamo tehniki in znanosti- tu pa zaupamo vizijam politikov, ki kolektivno gledano ne izpustijo nobene priložnosti, da bi kaj zajebali. In odkorakali, brez kakršnekoli odgovornosti.
poweroff ::
Ramon dekers je izjavil:
če ne bi bilo desničarjev bi že kdaj že bila Đamija, ne ena kar v vseh mečjih mestih v Slo. Načeloma bi bilo to super saj bi verniki prišparali na benzu. Pa recimo romi bi imeli urejene hiše s kanalizacijami in vsemi priklučki, vprašanje je samo; kdo bi potem še delal v taki deželi. Vzamejo denar in ga namenijo za reševanje romske problematike. Enkratno. Naj se podmladek sd pridruži romskemu piknuku v žabjeku da bodo bolj multikulti.
Mene džamije ne motijo, če so seveda ustrezno umeščene v prostor.
Motijo me pa desničarski skrajneži, ki pobiajjo socialdemokratsko mladino. Na forumu ali v živo. Tudi tale Norvežan je bil najprej aktiven na forumih...
sudo poweroff
Pšenični ::
"Motijo me pa desničarski skrajneži, ki pobiajjo socialdemokratsko mladino. Na forumu ali v živo. Tudi tale Norvežan je bil najprej aktiven na forumih..."
Lahko da je vse posledica neumne politike, ki avtothono prebivalstvo ne vpraša, ali se strinja z priseljevanjem muslimanov.
Kot je rekel že nekdo, potem ko postane vroče, noben ni kriv, sploh ne tisti, ki to počnejo za par glasov več.
Potem so itak vsega kriv desničarji, to je najlažje, na njih prenest svoje grehe, noben pa se ne vpraša, zakaj je recimo desnica v vzponu. To pa je itak vse kar znajo levičarji, no pri nas še kradejo ko srake.
djordjevic ::
Pšenični je izjavil:
Zato ker je precej raje patološko zadrte, predvsem ekstremni desničarji, zmerni pa tudi nič kaj manj, znajo pa na (nacionalistične in po novem tudi verske) osnovne strune brenkati kot Vai. Ne rečem, da se tudi levičarji ne poslužujejo populizma, zadnje čase celo bolj kot kdaj prej !!!, beri Semolič, Kahel in podobna banda. Da priseljenci večinoma opravljajo dela, ki jih avtohtono prebivalstvo niti povoha ne, pa vsi spretno izpuščate.
Ampak hočem opozorit, da ima vsak izpad tud svoj vzrok. In na Norveškem ga zgleda ma.
Nekaj časa nazaj:
t.i. Levičar: "Tudi teroristični napadi imajo svoj vzrok."
t.i. Desničar: "Ma kakšen vzrok, bombardirat muslimansko gamad!!"
(mine nekaj časa, krščanski fundi naredi štalo na norveškem)
t.i. Desničar: "Vsak izpad ima svoj vzrok"
t.i. Desničar: "Lejte, gor je levica že sto let nepretrgoma na oblasti, ziher je to to!"
Da se še ne 14 letnim otrokom na (političnih) taborih pere možgane pa je povsem normalno...
Kaj to, pri nas komaj rojene že začnejo indoktrinirat v krščanski fundamentalizem! Bolno!
(sarcasm)
Mislim, da moramo hitro spremenit našo politiko, da se ne bo kakšnemu od soforumašev strgalo in bo šel otroke pobijat, še prej pa podstavil bombo ali dve.
(ali z drugimi besedami)
Mislim, da moramo hitro spremenit našo politiko, da se ne bo kakšnemu od soforumašev muslimanov strgalo in bo šel otroke pobijat, še prej pa podstavil bombo ali dve.
Mislim, da bi se morali glede tega vsi strinjat? Ali bodo neakteri še naprej "naše" ekstremiste opravičevali in iskali 1001 vzrok, "njihove" pa zbombardirali s tisoč bombami?
(/sarcasm)
Saj res, glede na to, da so bojda še trije/štirje "pomagači" na prostosti nekje na norveškem, boste "desničarji" pripravili tistih tisoč povračilnih bomb?
(sarcasm)
Mislim, tile Norvežani skrivajo teroriste, zagotovo so ničvredna nacija, gremo jih bombardirat, koga briga kolateralna škoda!
(/sarcasm)
hamax ::
Pravis da nimajo demokraticnih volitev?
Pšenični ::
"Zato ker je precej raje patološko zadrte, predvsem ekstremni desničarji, zmerni pa tudi nič kaj manj, znajo pa na (nacionalistične in po novem tudi verske) osnovne strune brenkati kot Vai. Ne rečem, da se tudi levičarji ne poslužujejo populizma, zadnje čase celo bolj kot kdaj prej !!!, beri Semolič, Kahel in podobna banda. Da priseljenci večinoma opravljajo dela, ki jih avtohtono prebivalstvo niti povoha ne, pa vsi spretno izpuščate."
Ma, pri nas lahko po mojem mnenju prej pride, (v tem momentu) do kakšnega maščevanja novodobnemu kapitalistu, ki je zafural več podjetij...kdo so je čisto jasno. Če sploh bo kaj iz tega, ker slovenec gre raj na štrik, kot da bi drugemu kaj naredil. No, ampak tajkunska juhca se kuha in je vedno bolj vroča.
"Pravis da nimajo demokraticnih volitev?"
V današnji dobi, ko z mediji, cenzuro interneta odločilno vplivamo na volilce, oblikujemo javno mnenje, se lahko začnemo spraševat; Kaj je to demokracija?
Demokracijo bo v vedno večji meri ustvarjal tisti, ki bo imel več denarja. No pri nas levičarjem ne bo pomagala niti gora denarja, ker so gospodarstvo tko al tko zafural doo fundamenta.
Danes smo se pri kavi spet spraševali; a bo danes spet kakšna dokapitalizacija NLB-ja?
bluefish ::
Očitno test IQ-ja posameznika. Če podležeš propagandi, hitro stran od volišč.
Gladi ::
djordjevic je izjavil:
Ti že veš...
USS Liberty ::
Nobene svetovne vojne ne bo in Srbi ne bodo povod. Ni pa nič čudno, da se je tudi ta norveški "viking" navduševal tudi nad Srbi, saj veliko zahodnjakov in severnjakov svoje narode vidi kot šibke, dekadentne, preveč liberalne in so jim bolj kot pripadniki svojega naroda vzor nepokvarjeni narodi vzhodne Evrope, predvsem Rusi in pa tudi Srbi. Že pred kakšnim letom dni sem bral komentarje na enem ameriškem forumu in se mi je zdelo neverjetno kako celo tam veliko folka ima za vzor Rusijo in obožujejo Putina in ga imajo veliko raje kot pa njihove t.i. desne republikanske politike, katere smatrajo za prodane skorumpirance, ki so uničili Ameriko.
Tega Norvežana pa mainstrem levi mediji žigosajo, da je desni nacist in podobno, v resnici pa to ni. V tistem njegovem posnetku ni niti ene same nacistične ikonografije. Prav tako ta tipo ni nek norveški nordijski nacionalist, saj nikjer ne povzdiguje svoje norveške narodnosti, nobenega povzdigovanjna vikinštva, nobenega skandinavskega neopoganstva nisem zasledil pri njem. Tipo je panevropski ekstremen antimusliman, za vzornike pa ima celo bivšega poljskega in romunskega kralja ter ruskega cesarja.
http://en.wikipedia.org/wiki/USS_Liberty_%28AGTR-5%29
BBC> The gunman was arrested an estimated 90 minutes after the massacre began. Police say he still had a lot of ammunition, and hospital sources said he had used dum-dum bullets, designed to disintegrate inside the body and cause maximum internal damage.
BBC> One of the first victims on the island was an off-duty police officer who had been hired by the camp organisers to provide security, Reuters news agency reported authorities as saying.
So there.
http://gunkies.org/blog/?p=91 se tudi splača prebrat:
I want to end this with a request to everyone who reads this, echoing a statement I read by one of my good friends and comrades: Please, don't let me see any messages of hatred, wishes for the death penalty, anything like that. If anyone should be of the belief that anything will improve by murdering this sad little person, they would be profoundly wrong. All attention now should be plowed into caring for those victims and their relatives who did not share my luck, and not giving an audience to a perpetrator who wants one.
  • spremenilo: jype ()
donfilipo ::
Ja tragedija glede na 90 minut čakanja, da bistrim tudi nekako slutiti, da se tudi na policijo, ne gre preveč zanašati. Ni samo ta dogodek, če kak James Bond, ali realneje agent notranje in celo zunanje kotrole, izvrši nad plavimi teste, ugotovi, da je tam čuda karakterjev, precej brutusov in preračunljivcev, ni pa kaj prida mehanizmov, ki bi zaustavili, da se ti z velikim rizikom, v določenih razmerah, tudi ne obnašajo preračunljivo in na čase seveda koruptivno. No za ta dogodek, bo temeljita analiza nemara potrebna, problem je le, da je norost tragedije toliko silna, da take in drugačne analize izpadejo povsem nepomembne. Ampak ne za vekomaj!
Nekaj drugega pa bi se dalo lažje ugotoviti. JJ stalno izpostavja veliko število levih mandatov Norveške. Če sem prav razumel, naj bi to imelo za posledico veliko muslimanov tam gor. Ker so pač multikulti, desni so pa kao unitarni melting itd.
Pa me zanima. Ali je kdo sploh pogledal, če države z klasično desnimi mandati v večini, s kandidati, kjer jim dejansko med brati manjkajo le še brki, priimke pa še tako imajo recimo Huettler:)), torej ali te države, imajo na koncu res kaj dosti manj muslimanov, ali pa nemara celo več?????
Me prav firbec matra.
BlueRunner ::
Seveda, seveda. Najbolje potem pobijati avtohtono mladež, da dokažeš poanto, da avtohtoni prebivalci večinsko volijo politike, ki je karkšna je.
Saj vzrok je res očiten: pobiti vse drugače misleče avtohtone prebivalce, potem bo pa mir. Jih bo potem avtohtonih kakšnih 60% manj, bo pa mir. To je pa tisto, kar nekateri hočejo, mar ne? Mir.
18zimoni ::
21 let je maksimalna zaporna kazen na Norveškem.
PaX_MaN ::
V bistvu ni:
She said the country's General Civil Penal Code gives the state prosecutor the right to seek an extension of sentences beyond the 21-year maximum for up to five years at a time, on the condition that the inmate is deemed to be a "high risk" of repeating serious offences.
Sandbye, who was fielding media calls at the Oslo Police District office Sunday, said it's therefore technically possible to keep extending a sentence indefinitely.
poweroff ::
Jih sprašujejo na volitvah že 100 let, pa vedno zmaga stranka, ki zagovarja multikulturnost.
sudo poweroff
djordjevic ::
Samo raja z opranimi glavami ne razumeš, viš. Ful jim je bed, ker imajo enega najvišjih standardov na svetu, pa od sile kar ne morejo doumeti, da je treba voliti pristno, domačijsko, nazadnjaško varianto. ;((
Double_J ::
Saj na Švedskem naj bi vladala neka desna krščanska stranka, pa vseeno izvaja politiko priseljevanja in islamizacije.
Zato pa je najhitrejše rastoča stranka za prepoved priseljevanja, čeprav jo mediji vsakodnevno obkladajo da je fašistična.
Kako pa deluje policija, pa lahko vidite na cortezovemu posnetku. Praktično jim policist pove, da jih imajo pravico napadati in pobijati.
Dve šivanki...
  • spremenil: Double_J ()
Double_J> Praktično jim policist pove, da jih imajo pravico napadati in pobijati.
Zdaj mi je popolnoma jasno, kako lahko desničarski skrajnež pobije sto nedolžnih otrok. "Nekaj je pobrkljal!"
amigo_no1 ::
Saj je povsod po Evropi tako (UK, DE, IT ,FR ; Benelux, Skandinavija), googlajte "Lepote multikulturne Evrope" 8-O.
http://www.youtube.com/view_play_list?p...
  • spremenilo: amigo_no1 ()
USS Liberty ::
Visok standard imajo tudi na Japonskem, pa Japonci niso tako neumni, da bi svojo Japonsko šli afrikanizirat kot to počno Norvežani ali Švedi. Norveška pa itak svoj zelo visok standard, podobno kot nekateri arabci, gradi predvsem na račun izvoza nafte, na pa na račun dela, ustarjalnosti in inovativnosti, kot to počno Japonci. Japonci imajo brez multikulturnosti na gospodarskem področju tisočkrat več za pokazat svetu kot pa cela zblojena rozastordeča Skandinavija z Norveško in Švedsko na čelu.
In, ja, Norvežani imajo tako kot Švedi oprane glave že od vrtca naprej. Samo načrtno programirani ljudje z opranimi možgani so lahko tako samodestruktivni in mazohistični, da jim je kul in jih ne moti, ko jim sredi nekooč njihovih mest njihove ženske poslijejo afričani in arabci, oni pa namesto, da bi svoje ženske branili, hočejo še več afrike in še več multikulturalizma v Oslu...
bluefish ::
Nekaj takega kot Ljubljančani v Fužinah torej, ko redke Slovenke posiljujejo bradati muslimani, ženske v burkah pa zastrašujejo kleno slovensko mladino.
  • spremenil: bluefish ()
kalko ::
USS Liberty je izjavil:
Oslo mayor Stang was asked whether Oslo neads greater security - "I don't think security can solve problems. We need to teach greater respect."
Ampak dvomim, da boš z desničarskim memplexom kadarkoli razumel bistvo županove izjave.
Ramon dekers ::
hmm sem se spomnil na Tajsko, kako se vsi prebivalci obrnejo proti tujcem če je karkoli narobe. Vsi držijo skupaj in so enotni, podobno je bilo na Kitajskem. Sicer včasih ni pošteno, ampak mi je všeč njihova povezanost. Tam ni Juretov podobnih osebkov, no so samo so kaj hitro odstranjeni od družbe oz. izolirani:)...Tam bodo tujce izgnali in poslali nazaj na odprto morje, sploh indijce ki bi se tako radi zatrli tako kot se afričani na jug Italije.
kalko je izjavil:
ja sedaj bodo naredili še večji ekstrem, še več demokracije in še več tujcev.
djordjevic ::
Sklepam torej, da boš v tujini zatajil, da si Slovenec? Saj veš, stop immigration, pa to. ;((
bluefish ::
Saj čudno, da še ni odbrzel na Tajsko in ostal tam, ko pa jo mora omeniti v skorajda vsaki temi. No, sedaj vemo, so ga brcnili direkt v ocean.
Double_J ::
Breivikov manifest ni avtorsko delo, temveč kopija
Norveški mediji so včeraj objavili Breivikov manifest, nato pa kasneje ugotovili, da je skoraj celoten, 1500 strani dolg, ''dnevnik'' pravzaprav kopija manifesta zloglasnega ameriškega terorists Theodorja Kaczynskega, bolje znanega pod imenom Unabomber.
Breivik je v zapisu spremenil le nekaj besed. Namesto ''levičarstvo'' je na primer zapisal ''multikulturalizem''. Unabomber je v času dvajsetih let preko pošte pošiljal bombe, ki so ubile tri ljudi, 23 pa hudi ranile.
Tole bo verjetno laž, malo težko skopiraš 50strani na 1500?
Dve šivanki...
PaX_MaN ::
Jep:
The text also copies sections of the Unabomber manifesto, without giving credit, while exchanging the words "leftists" for "cultural Marxists", and "black people" for "muslims".
Slovenski novinarčki at its best.
donfilipo ::
Je in ni laž. Ugibam, da bi lahko rekli, da gre za isti miselni konstrukt in podobno socialno psihozo. Nekako po formi. Po vsebini pa tudi jaz ugibam, da so se zajebali obilno:)
  • spremenilo: donfilipo ()
donfilipo ::
Jebaj ga. Sem začel brati Unabomber manifesto, da bi našel direkt kopirane pasaže (ali je možno, da so direkt kopirane, ali isti miselni okvir, porodi praktično identične stavke?) pa sem ugotovil da je Ted pravzaprav vsaj na začetku, kjer sem, imel v marsičem prav.8-O
Saj Thomas ima tudi v marsičem prav, pa to ne pomeni, da ni totalno nor, ko gre za politično realnost - in on se na srečo tega celo zaveda.
O, fino, sodniki so se odločili, da bo Anders svoje blodnje širil samo z njimi.
Keyser Soze ::
jype je izjavil:
To je sarkazem? Mi detektor ne dela...
OM, F, G!
Verjetno je mislil, da bo sojenje zaprto za javnost.
We are fine without wings.
Keyser Soze> To je sarkazem?
Ne. Njegov cilj je bil žalujoči državi povedati, zakaj je moral storiti, kar je storil. Da ga država ne želi poslušati, me prav nič ne moti.
Vajenc ::
Neverjetno koliko enih žaljivk je padlo v eni sami temi, predvsem od Jype-ja ...
To kar se je zgodilo je katastrofa, ki ima dva možna scenarija. Lahko se uresniči napoved blaznega morilca, ki napoveduje streznitev evropejcev in postopno ukinjanje multikulti propagande. Ali pa je s tem pokolom prestrelil obe koleni vsem evropskim skrajnim desničarjem, antiglobalistom in nasprotnikom multikulti blodnje.
Multi kulti je blodnja zato, ker multikulti na dolgi rok težko deluje v korist države gostiteljice. Dokaze za to najdemo od pravljic o Babilonskem stolpu do aktualne Švedske. Bolj po domače - burek je ok, burka pa ne spada v evropsko kulturo, ker ta po naše ponižuje ženske. V nasprotju je, da prebežniki iz slabo razvitih dežel prebežijo na Švedsko v dobri veri po boljšem življenju, potem pa to isto državo začnejo preoblikovati po svojim običajih. Skrajnež, ki je pobil 90+ ljudi v eni uri sicer ne more imeti prav nobenega izgovora za to dejanje, lahko pa s tako skrajnim dejanjem spremeni marsikaj do včeraj nepredstavljivega.
Nekdo je zapisal, da takim kot je morilec Breivik ni pomoči. Se ne strinjam. Imo se da pomagati tako takim kot je on, kot tistim z jihad blodnjo. Pravzaprav bi bilo edino smiselno takšnega pacienta držati pri življenju zato, da se nekoč iskreno pokesa in nagovori svoje sleditelje.
Strinjam se tudi s tistimi, ki govorijo o nesposobni norveški policiji. To, da niso imeli prostega helikopterja na voljo, je slaba tožba. Ali pa imeti v državi neoboroženo policijo in oboroženo nore lovce?! Čeprav bi bila Norveška na splošno lahko vzor večini sveta so ga tukaj polomili.
Woody Allen
Double_J ::
The terms; Palestine and Palestinians are Islamic imperialist phenomenon. There is no such thing as a Palestinian people. Before 1948, they were referred to as Syrians. There was only Syria. The Palestinian phenomenon was created with the intention to justify Jihad.
Creating a separate Palestinian state is as ridiculous as creating a separate state called Kosovo. There are only two rightful claimants of Kosovo. Albania and Serbia. Just like Syria and Israel in the Palestinian conflict.
282 stran.
Ali res, ali mar niso odprta družba? Odprta družba se ne boji razpravljati, kar za Norveško kot praviš očitno ne drži.
Dve šivanki...
Keyser Soze ::
jype je izjavil:
Žalujoči državi je že pokazal tisto glavno kar je imel. Mene predvsem zanima sedaj v čem je bil povod za njegovo dejanje.
Ampak, šur, državljani tega ne bodo mogli prenesti. Jih je treba zaščitit. In kdo boljše ve pred čem je treba ščitit svoje ovčiče, kot pa država. Beeee.... Ovce monaste.;((
OM, F, G!
Ramon dekers ::
hey, hoy, ni pomembno kaj govori država, pomembno je da verjamete njihovim besedam!
pecorin ::
gulfstream je izjavil:
Na ta napad na zahod je potrebno odgovoriti hitro in silovito. Poiskati krivce in poskrbeti za njih tako kot se za skrajneže spodobi.
vir: Wikipedia
Oni nam eno bombo, mi njim tisoč. Edini način, da zmagamo.
na zacetku teme so desnicarji zelo natancno vedeli kaj je treba s storilci narediti. za zacetek pobiti vse storilce, za vsak slucaj pa rukniti se nekaj tisoc ton bomb na njihove podpornike ali pa vsaj nekoga enake vere ali prepricanj.
potem se je pa kar naenkrat vse spremenilo. isti desnicarji so postali zelo miroljubni in pripravljeni na pogovore. zdaj se moramo zamisliti zakaj se je to zgodilo, vzroki morajo biti v druzbi, ki naredi take napadalce. nekaj jih je ze moralo prignati do takih akcij.
eni krivijo muslimane. to je logicno. terorizem brez muslimana? wtf??
eni opravicujejo dejanje, saj je bolje imeti poklane otroke kot pa otroke z na levo opranimi mozgani.
eni bi celo ukinili demokracijo in bi vlade nastavljali izmenicno, vsakih par let drugo. saj narod ni zadosti inteligenten, da bi na volitvah kdaj pa kdaj izbral desne. in to lahko kakega desnicarskega psihopata pripelje do take situacije, da ne more vec drugega kot pobiti kakih 100 otrok. tu je potem se potrebno dodati, da bi vlade morale kroziti tako: leva, desna, muslimanska. saj ce je narod inteligenten, ve da tudi psihopatski musliman nima neskoncnega potrpljenja in ce v nekaj letih ne bo imel vlade, bo mogoce prisiljen iti poklat kake otroke.
ok, najbolj pa me skrbi, da je tale psiho nekaterim dal ideje. na internetu in tudi na tem forumu je veliko enake retorike, kot jo je imel napadalec. tudi sam je zacel samo s pisanjem. in kaj ce bo sedaj en nadebudni fundi iz tega dogodka prebral: "hej, saj ideje imava enake, tudi zacela sva enako z goflanjem po internetu, samo on je potem tudi nekaj naredil. ne bom vec pussy in grem se jaz par 10 poklat, da potrdim svoj point!".
Pač Evropa se ne zaveda, da multikulturnost po Ameriško ne deluje v Evropi sta dva različna svetova, saj Ameriška multikulturnost ne izhaja iz starih narodov, kot se Hvalijo Evropejci. Evropejcem ni jasno, da se uvožen narod, ki so ga pripeljali zaradi poceni delovne sile noče asimilirati, in počasi avtohtoni narod postaja vedno bolj manjšina. Problem je ko je moralno sporna politika Rimokatoliške države, pride v konflikt Mentalitete, ki se ne spreminja kot piha veter, ali pa ko komu kak Žakelj z denarjem pade. Pa tako pride do spremembe mnenja. Ne gre in ne dojamejo tudi Mentalitete Kitajcev, ja kako lahko nekdo dela za pest riža, hmm pa mislite da dela zgolj za preživetje. Kot je rekel Gadafi, še ena generacija pa je zadeva končana.
Phil ::
Mene pa bolj skrbi da bi eni še bolj omejevali svobodo govora, par tule vas je zelo "trigger happy" za to idejo. Saj se pri vseh ekstremistih najprej začne z retoriko, naj bojo levi ali desni. Dokler ne gre za sovražni govor, naj bo debata kar lepo omogočena.
Še dobro da imamo na voljo dva testna poligona za multikulturalizem (Švedska in Norveška), pa upajmo da za druge države (mogoče je boljša beseda - družbe) ne bo prepozno, ko se bo tam izkazalo da je vse skupaj en velik FAIL. Pravzaprav bi bilo najbolje da še naprej tam na veliko zmaguje levica, bojo rezultati toliko prej znani.
Vajenc ::
V ZDA imajo probleme z latino priseljenci. Dokler se priseljenci porazgubijo med ostalimi državljani je vse ok, ko se novim priseljencem ni potrebno več asimilirati za delovanje v družbi pa nastane problem. Tako z mehičani na jugu ZDA, kot Turki v Nemčiji, kosovarji na Švedskem itd.
Woody Allen
guest #44 ::
Nekateri enostavno nočejo razumeti, da vsako področje ima svojo integracijsko kapaciteto. 1 musliman na 10 domačinov vrjetno ni težava, 4 ali več pa že znajo delat težave.
Še posebej če so domačini popustljive narave/politične usmerjenosti.
Sicer pa jype...če se postavljaš na stran zmernih Muslimanov se moreš postavit tudi na stran zmernih nacistov.
bluefish ::
Kdo bi si mislil: Po Breivikovem manifestu Slovenija med najmanj indoktriniranimi.
Sodeč po objavah nekaterih bi človek pričakoval, da je Breivik že slišal za muslimanski geto Fužine.
17 / 29
Posledice Manchesterskega napada? (strani: 1 2 3 4 … 17 18 19 20 )
Oddelek: Problemi človeštva
998235743 (221406) BigWhale
Posilstva v Oslu (strani: 1 2 3 )
11025824 (22487) Gandalfar
Napad v Oslu: igre niso krive, spet stare debate o nadzoru interneta
Oddelek: Novice / NWO
4013456 (12047) vidz81
