Oslo, teroristicno dejanje
telbanc> Ampak če ne vem tega ni tragedija
Tudi vsega ostalega ne veš.
gulfstream> Mhm. Takšnega razmerja nebi dosegli, pa če danes zravnajo Kabul z zemljo.
http://www.iraqbodycount.org/
Pšenični ::
"Politično nasilje na Norveškem tako rekoč ne obstaja, saj ni znano, da bi obstajala kakšna domača teroristična skupina."
Da bi potem, kar naenkrat zadeva izbruhnila tako silovito, je potemtakem težko verjeti.
djordjevic ::
Ramon dekers je izjavil:
djordjevic je izjavil:
Jaz pa sem mislil, da že veselo izkoriščaš bajne v priložnosti v tujini ... ;)
papir kolega, papir mi manjka:)drugače pa hvala ker skrbiš zame, si mi kot prijatelj ki ga nikoli nisem imel.
Zanimivo. Jaz ga tudi že osem let čakam, pa mi nič ne preprečuje, da ne bi ves ta čas delal v svojem poklicu. ;)
Ramon dekers ::
upam da ga v naslednjih 8 letih dočakaš, do takrat pa delaj to kar znaš oz tisto kar imaš na voljo.
djordjevic ::
Fino, bom. Tebi želim enako. :)
Ramon dekers ::
Hvala!
letmein ::
jype je izjavil:
Št. ubitih civilistov neposredno od koalicijskega ognja v Iraqu se giblje med 5k-10k ljudi, ostalo so jih pobili militanti/uporniki sami.
"In WW-II, armies did much less of the killing as civilians took it over - the French underground, Russian partisans, Serbian partisans, etc. In the Vietnam war, most of the fighting by the north was done by civilians - the Vietcong. The Iraqi army caused what, a dozen US/British casualties? After that, it was largely a conflict fought by civilians against the victorious armies waged by IEDs. The US and British tied their own hands trying to keep innocent civilian deaths to a minimum but one has to remember, that terrorists/gorillas are civilians and these civilians were targeting the Iraqi army as well as the supply carriers. The surge was fought mainly by Iraqi Sunni tribes trying to evict the invaders from other Muslim countries (who were counted as Iraqi civilians) that were trying to start a civil war and create a caliphate in the ashes of what was once Iraq and the surrounding countries.
The bottom line is, when the fighting is being done by civilians against you, ALL their casualties will be civilian which means a high percentage. It is simply not a good marker and is mainly used as a propaganda point. It only has significance when armies are doing all the fighting. What is so casually ignored is the high percentage of civilians that were spared due to precise, guided weapons and the highly restrictive rules of engagement that cause so many more military deaths to prevent non-combatant/non-combatant enablers civilian deaths."
Pšenični ::
"Št. ubitih civilistov neposredno od koalicijskega ognja v Iraqu se giblje med 5k-10k ljudi, ostalo so jih pobili militanti/uporniki sami."
http://www.rtvslo.si/svet/cena-osvobaja...
Ramon dekers ::
"The US and British tied their own hands trying to keep innocent civilian deaths to a minimum but one has to remember, that terrorists/gorillas are civilians and these civilians were targeting the Iraqi army as well as the supply carriers..."
Tale je najbolj bosa. Američani so obkolili faluyo s tanki in vsemi bojnimi sredstvi okoli mesta ko so videli da pehota ne uspe saj so bili teroristi preveč organizirani. Ko so začeli prodirati po mestu so klali vse po spisku...
Da ne govorim o šoli ki so jo američani zasedli, ali posnetkih kako specialci Blackwater enote streljajo ljudi v Iraku kot muhe in to civiliste, zraven pa se smejijo in govoririjo "glej še tam je eden"... Bolno
letmein je izjavil:
jype je izjavil:
sicer pa kje si pobral to sranje? Na kakšnem ameriškem forumu, kjer to opisuje nek neizobražen redneck, ki je poln samega seba, ti pa mu slepo verjameš. Kam gre ta svet.
Oberyn ::
gulfstream je izjavil:
Če že padajo tisti, ki niso nič krivi, je bolje da jih je čim manj. In da niso na naši strani.
Torej nedolžne civiliste, ki padajo in niso nič krivi, dalje ločimo na tiste, ki so na naši strani in na tiste, ki niso na naši strani.
Ob tej izjavi sem pa kljub vsemu rahlo dvignil levo obrv.
DeusVult ::
Oberyn je izjavil:
Če gre za vojno med suverenima državama, med različnima rasama, kulturama in religijama, je razlika jasna. Ne vidim, zakaj bi bilo tako razločevanje sporno. Tudi, če si civilist, je v tem primeru popolnoma jasno, na čigavi strani si.
http://www.rtvslo.si/blog/deusvult
Iz 26:2 "Naj vstopi zaslužen Narod, Narod, ki varuje Vero."
Brane2 ::
Update: baje imajo ime tipa.
Evo quota z B92 sitea:
Norvežanin koji je uhapšen zbog pucnjave na ostrvu Utoja kod Osla verovatno nije povezan s islamističkim terorizmom, izjavio je neimenovani zvaničnik norveške policije. Saopšteno je i da je uhapšeni napadač "etnički Norvežanin".
Predstavnik policije saopštio je da je napadač, koji se trenutno nalazi na saslušanju, "etnički Norvežanin", star 32 godine, plave kose i visokog rasta.
Kako javljaju norveški mediji, napadač je identifikovan kao 32-godišnji Anders Bering Brejvik. Britanski Dejli mejl navodi i da je Breivik viđen na mestu eksplozije u Oslu dva sata pre napada na ostrvu.
Istovremeno, norveška televizija TV2 je izvestila da je napadač povezan s ekstremno desničarskim grupama.
Ta televizija je izvestila, ne navodeći izvore, da je Norvežanin koji je uhapšen zbog napada povezan s krajnje desničarskim grupama, a da policija pretražuje jedan stan u zapadnom delu prestonice u kome je napadač živeo.
Policijski izvori navode da se stiče utisak da je napadač delovao samostalno i da se "čini da ovo (pucnjava) nije ni u kakvoj u vezi ni sa jednom međunarodnom terorističkom organizacijom".
  • spremenil: Brane2 ()
frudi ::
Menda po novem policija potrdila vsaj 80 mrtvih v streljanju...
DeusVult: Upam da ti je jasno da si ti en hud nacionalsocialist (naci, po domaće) in poleg tega še krščanski fundamentalist.
In kot tak ne vidiš več kot 2cm naprej od svojega nosa. Zaradi plašnic pa niti levo ne desno.
Na kratko... ozkogledna svinja. Tvoji komentarji so tko grozno bolni da to niti res ni. Cel svet ti govori da islamski skrajneži nimajo popolnoma nič z vsem tem, ti bi pa kar vse muslimane pobil? Sram te bilo.
Brane2 ::
Tip jim je naredu Vukovar sredi "civilizirane" Norveške...
DeusVult ::
Napad je bil torej očitno politično motiviran, glavni osumljenec pa je Norvežan Anders Breivik.
njegov twitter
kopija FB strani
One person with a belief is equal to the force of 100 000 who have only interests.
Jaz sem brez besed. Ne razumem, kako lahko nekdo, ki se ima za konzervativnega Kristjana in nacionalista v miru izvede tak pokol nad lastnim narodom. Očitna posledica degeneracije čiste ideologije in kulture v morilski bes zaradi večinsko liberalne in ateistične družbe.
Res, ni več kaj za dodat. Molimo za žrtve in njihove svojce.
DeusVult je izjavil:
Čaki malo! Prej ko so bili neki islamski ekstremisti 'krivi' je blo treba kar zradirat komplet vse muslimane s tele skale... zdej ko je en degeneriran kristjan kriv so pa dovolj molitve (k nekemu imaginarnemu bitju)?
Bodi pošten pa zahtevaj eradikacijo vseh kristjanov!
frudi ::
DeusVult, ti si pa res posebne vrste debil...
Ko se sumi islamske teroriste - so krivi vsi muslimani po vrsti in ateisti ter liberalisti, ker jih tolerirajo. Ko se izkaže, da gre menda za nacionalista in kristjana, so pa spet krivi ateisti in liberalci. Bolan si toliko, kot ta psihopat.
DeusVult ::
frudi je izjavil:
Nikakor. Moj namen ni kriviti žrtev, samo poudarjam, da so del spleta okoliščin. Ker, resnici na ljubo, "mladinski tabor" za liberalno ateistično indoktrinacijo tudi ni nekaj nedolžnega.
Ne moremo kriviti njih, tako, kot ne moremo kriviti samo ideologije osumljenca. Ker sta povezana. Ker v normalni, zdravi Krščanski družbi taka ideologija ne bi zahtevala poboja lastnega ljudstva.
DeusVult ::
Pithlit je izjavil:
Moli kamor hočeš, oziroma pač ne, če se ti ne zdi potrebno.
Krivimo lahko pa seveda vse nedolžne muslimane za zločine nekaj malega psihopatskih islamskih fundamentalistov.
Brilliant... effin brilliant!
DeusVult ::
Pithlit je izjavil:
Ja, ker muslimani to počnejo, da bi tujim državam in civilizacijam vsiljevali svoje vrednote in vero. Tole pa je bila očitno notranja politika in nič drugega. Muslimani se nej tudi zaradi mene med seboj obrezujejo in obglavljajo. Moraš ločit med obrambo lastne kulture in vsiljevanje nekomu tujo kulturo.
Čaki, čaki... pol je prav da grem pobijat kristjane ker mi vsako nedeljo vsaj dvakrat vsiljujejo svojo kulturo? Da ne omenjam tega da lokalna (pa mislim da drugje ni dosti drugače) cerkev vsake petnajst minut razbija z unimi zvonovi (in na ta način širi 'kulturo')? Kaj pa to da se ne morem znebiti vseh sort križev, ker jih praktično videvam kamorkoli se obrnem?
Dej... prid na obisk enkrat. Jaz grem pa k sosedu mačeto nabrusit.
Torej ti lahko s svojo vero in kulturo posiljuješ 'manjvredne'... oni pa tebe ne smejo? Pa kaj si mi ti za en lolek? Supreme being of leisure?
DeusVult ::
Pithlit je izjavil:
To je tudi TVOJA kultura. Pa čeprav te je naš izobraževalno-indoktrinacijski sistem uspel prepričati v nasprotno. Slovenija je Krščanska država.
Samo v glavah nacionalsocialističnih krščanskih fundijev.
T-h-o-r ::
Petkova eksplozija v norveški prestolnici in streljanje na udeležence poletnega tabora sta bila delo norveškega terorista, ki so ga že prijeli. V incidentih je umrlo najmanj 87 ljudi.
http://www.rtvslo.si/svet/foto-napada-n...
At least 80 people died when a gunman opened fire at an island youth camp in Norway, hours after a bomb attack on the capital, Oslo, police say.
Oslo police are questioning a 32-year-old Norwegian man in connection with Friday's attacks.
The BBC's Richard Galpin, north of Oslo, says that Norway has had problems with neo-Nazi groups in the past but the assumption was that such groups had been largely eliminated and did not pose a significant threat.
http://www.bbc.co.uk/news/world-europe-...
  • spremenilo: T-h-o-r ()
cortez ::
prostozidar...
Baje da sta bila dva. En se je sam pokončal.
Pšenični ::
"Al se zaveda, da je huj k ena histerična zmešana baba, ki je zjutraj pozabila na svoje tablete za dobro počutje. Taki paničarji me gredo pa res na k."
"At least 80 people died when a gunman opened fire at an island youth camp in Norway, hours after a bomb attack on the capital, Oslo, police say."
"Zelo slabo skriva, kako uživa v gledanju nasilja. "
"Glede na to, da bo mrvih tam od 40 do 50 morda še več, mislim da bojo Norvežani lepo pospravili kufre in šli ven iz vojaških operacij. Kot Španci."
Ko je že jasno, da gre za veliko zadevo, enim še zmeraj ne pride....
Seveda smo tisti, ki mislimo drugače neumni in histerični.......imamo majhne možgane in nas pošiljajo "drkat"...
Prostozidar? Od kdaj pa to?
DeusVult> To je tudi TVOJA kultura.
Ne, ni. Moja kultura je veliko bližje kulturi Norvežanov, ki nasilje prenašajo brez glasnih zahtev po maščevanju, kot to radi počnejo vseh vrst verniki. Moja kultura je kultura vseh tistih, ki bodo za storilce zahtevali povsem običajen sodni proces. Moja kultura ni krvava, tvoja pa praktično temelji na masovnih umorih, surovi indoktrinaciji, perverzni morali, diskriminaciji zoper vse žive možne skupine, od žensk preko drugačnih pa vse do vseh tistih, ki so se odločili, da ne potrebujejo imaginarnega prijatelja.
Tvoj poziv k molitvi za žrtve smatram za skrajno neokusen in žaljiv, tako do žrtev in njihovih svojcev, kot tudi do vseh nas.
telbanc> Seveda smo tisti, ki mislimo drugače neumni in histerični..
Ti raje preberi, kako si se veselil, da je Libija zadala udarec Norveški, dokler se ni izkazalo, da gre za desničarske skrajneže.
Pa nič se bat - ti nisi desničar.
  • spremenilo: jype ()
We are fine without wings.
Pšenični ::
"Ti raje preberi, kako si se veselil, da je Libija zadala udarec Norveški, dokler se ni izkazalo, da gre za desničarske skrajneže."
Spet se vidi da nimaš pojma. En sam človek tako velike operacije ne more izvesti.
Saj je ni.
PacificBlue, ampak ziher je ta tip kdaj tudi igral odbojko. A potem moramo rečt "Odbojkar!" ?
Pšenični ::
"Saj je ni"
Taki kot si ti, bodo seveda trdili, da je tipo eksploziv spedenal sam iz pecilnega praška, minija in bronze....al da je imel doma laboratorij, kjer je iz Žveplene kisline "prideloval nitroglicerin".....
Za odbojko verjetno poznas pravila, Kaj pa poznas mogoče prostozidarska pravila?
cortez ::
Napadalec je bil poučen o bio kmetovanju, zato je za domnevati, da je sam izdelal "domačo" bombo.
Bwaze6 ::
V torek grem za 11 dni na Norveško. Očitno v državo, odeto v žalovanje. Grozen zločin. Je res postrelil prek 80 ljudi, ali se jih je od tega veliko utopilo v mrzli jezerski vodi, ko so nepripravljeni bežali pred morilcem?
Me pa preseneča, kako nihče več nima najmanjšega zaupanja v poročanje novinarjev. Vsi očitno že poznajo "resnico", poročila pa služijo le za potrditev le te, ali pa gre za zaroto in prikrivanje pravih razlogov...
Se mi pa ne zdi prav, da so zdaj začeli spreminjati uradne izjave, ki so jih države ob sožalju izrekle včeraj: : World reaction to bombing and shooting. Odstranili so večino namigov na tuj terorizem... Mislim, da bi tako editiranje zgodovine želeli tudi nekateri na temle forumu...
Se hecas? Jaz sem zaupanje v novinarje prodal ze pred leti za liter zganja.;((
cortez ::
Pšenični ::
"Napadalec je bil poučen o bio kmetovanju, zato je za domnevati, da je sam izdelal "domačo" bombo."
Mediji pišejo, da je postrelil 80 otrok na otoku. Seveda sam in kot so včeraj povedali s pištolo. To je preprosto neverjetno. In nemogoče.
cortez ::
Pšenični je izjavil:
popravek : imel je avtomatsko orožje in šibrovko.
Telbanc, a si nepismen? Ni treba odgovarjat, ker očitno si:
telbanc> Mediji pišejo, da je postrelil 80 otrok na otoku. Seveda sam in kot so včeraj povedali s pištolo. To je preprosto neverjetno. In nemogoče.
BBC> The gunman is reported to have been armed with a handgun, an automatic weapon and a shotgun.
telbanc> En sam človek tako velike operacije ne more izvesti.
jype> Saj je ni.
telbanc> Taki kot si ti, bodo seveda trdili, da je tipo eksploziv spedenal sam iz pecilnega praška, minija in bronze....al da je imel doma laboratorij, kjer je iz Žveplene kisline "prideloval nitroglicerin".....
WTF?
Ene dvesto do tristo let nazaj so delali bil politični terorizem, cca 500 let nazaj pa tudi ostalo...
Pšenični ::
"BBC> The gunman is reported to have been armed with a handgun, an automatic weapon and a shotgun."
Včeraj so mediji govorili o pištoli. Seveda zdej ko je tojk mrtvih, je mel s sabo arzenal. Ki ga je sam nosil. Jutri bojo pisali, da je mel breztrzajni kanon.....
Seveda je to, tojk res kot tisto včeraj....
V Libiji se morajo streljat cel teden da je toliko mrtvih...poleg tega bi moralo biti vsaj še dvakrat toliko ranjenih. Na otoku ob takem streljanju. Vsak strel jasno ne zadane. Poleg tega mi tipo ne deluje kot pripadnik posebnih enot. Ki bi znal uporabljat orožje. En civilist toliko ljudi ne more pobit....
Ko bo to jasno, bojo začeli govoriti, da se jih je večina utopila....
Keyser Soze ::
Life is a bitch.
Sej tud če greš na safari v Kongo nisi glih preveč pretresen nad več desetletnimi genocidi, ki se dogajajo tam ali v bližini. Tule je pač zadeva malo bolj pretresljiva ker je bližje in ker so malce bolj beli in približno tako pametni kot mi.
Se pa moraš ob tem vprašat al je prav, da mi dol visi za vse tiste tam, za tele mi pa ni glih vseeno?
P.S.: Plus, da je kar nenadoma neizmeren gnev napram islamskim skrajnežem zamenjalo obžalovanje nad dejstvom, da so bli "naši"? Mal sick je tole IMO.
OM, F, G!
cortez ::
Vse je odvisno od medijev in razvitosti družbe.
Seveda, pa to ni prav. Zato pa obstajajo Tomo Križnarji in podobni.
T-h-o-r ::
keyser, a to je pa prav, da na lepe oči damo grčiji 102 milijardi eurov
500.000 otrokom v afriki pa grozi smrt, če ne dobijo hrane
telbanc> Včeraj so mediji govorili o pištoli.
Ne, včeraj so omenjali avtomatsko orožje. Verjetno ne vsi in verjetno ti bereš kaj drugega kot jaz, a tvoje pisanje je kljub temu napačno.
telbanc> Ko bo to jasno, bojo začeli govoriti, da se jih je večina utopila...
Whatever. Tvoja analiza je bila, da so islamski skrajneži maščevali vpletenost Norveške v operacijah zveze NATO. Očitno to ne drži (kar je jasno vsakomur, ki ni obseden z nasiljem - islamski skrajneži se vedno potrudijo terorizirati civilno prebivalstvo, ker jim to nalaga religija in ker ima to največji propagandni učinek, zato do danes z izjemo ambasad v tujih državah še niso napadli vladnih stavb, temveč skoraj vedno tisto infrastrukturo, ki povzroči največ civilnih žrtev). Napadalca so ujeli živega, zato je pričakovati, da se bodo reči razjasnile razmeroma hitro in kot je v navadi v državah, kjer "due process" nekaj velja, tudi pravilno, predvsem pa brez histerije, ki jo nekateri tako pogrešajo.
Vse kaže, da se je treba za zločine zahvaliti desničarskim skrajnežem, a kot rečeno si lahko brez skrbi, ker je iz tvojega pisanja zelo očitno, da si levičar.
Hkrati bi rad poudaril, da so lahko nasilni tudi levičarski skrajneži, tako da se ne prezgodaj veselit, da "tvoji" česa takšnega ne bi storili.
T-h-o-r ::
telebanc, kar trdiš, ni res
že včeraj so povedali, da je imel napadalec automatic weapon
cortez ::
V Evropi bi morali dati večji poudarek ekstremnim skrajnežem, kot so :
- salafisti
- ekstremni desničarji
- skrajni levičarji-anarhisti
T-h-o-r je izjavil:
Počakaj, da pride odzadaj še Italija, ŠPanija, Portugalska in navsezadnje še Slovenija. Uni afričani bodo ze počakali. Res zivimo v krasnem svetu, kajne?
4 / 29
Posledice Manchesterskega napada? (strani: 1 2 3 4 … 17 18 19 20 )
Oddelek: Problemi človeštva
998235691 (221354) BigWhale
Posilstva v Oslu (strani: 1 2 3 )
11025816 (22479) Gandalfar
Napad v Oslu: igre niso krive, spet stare debate o nadzoru interneta
Oddelek: Novice / NWO
4013455 (12046) vidz81
