win xp , disk, header, write protected
BRBR ::
Zgleda da sem z diska zbrisal header al nekaj takega.
Vse sem uspel dobit nazaj, torej vidim ga v explorerju(pod drive letter D)in lahko berem z njega,
če pa hočem pisat pa ne pusti : "write protected"
slika
Volume 4 je problematičen.
Kaj narediti ?
  • zavaroval slike: bluefish ()
Duhec ::
Pripopaj sliko Disk Managementa.
BRBR ::
disk1 je ta ki ga kao ni. V explorerju pa ga vidim, samo da je write protected.
Ga ni bilo v eplorerju dokler ga nisem mountal z link
slika
EDIT:ok , šel sem brat FAQ od tega programa na linku zgoraj:
This is absolutely normal. Partition Find and Mount is designed to allow you to recover files from lost
partitions by temporary mounting those partitions in read-only mode, thus allowing you to use standard applications to copy files. It is not designed to be a permanent fix for a partition, since that would require altering disk partition table, which is not always safe. After you copied all data off damaged partitions, you can re-partition the original hard drive with Windows Disk Manager and copy all data back.
usb bootable image windows
82106 (2020) T-Mac
USB ključ formatiranje
163809 (3326) JernejPi
Diagnostično orodje za WD
Oddelek: Programska oprema
145036 (4896) clovk
od 160gb diska prikaže le 32, prvo mi je v partition magic prikazalo 160...
202501 (2177) sirotka
trdi disk hitachi
282526 (2161) kerrigh
