Forum » Operacijski sistemi » win xp , disk, header, write protected
BRBR ::
Zgleda da sem z diska zbrisal header al nekaj takega.
Vse sem uspel dobit nazaj, torej vidim ga v explorerju(pod drive letter D)in lahko berem z njega,
če pa hočem pisat pa ne pusti : "write protected"
Volume 4 je problematičen.
Kaj narediti ?
Kaj narediti ?
- zavaroval slike: bluefish ()
BRBR ::
disk1 je ta ki ga kao ni. V explorerju pa ga vidim, samo da je write protected.
Ga ni bilo v eplorerju dokler ga nisem mountal z link
EDIT:ok , šel sem brat FAQ od tega programa na linku zgoraj:
This is absolutely normal. Partition Find and Mount is designed to allow you to recover files from lost
partitions by temporary mounting those partitions in read-only mode, thus allowing you to use standard applications to copy files. It is not designed to be a permanent fix for a partition, since that would require altering disk partition table, which is not always safe. After you copied all data off damaged partitions, you can re-partition the original hard drive with Windows Disk Manager and copy all data back.
| » | usb bootable image windowsOddelek: Pomoč in nasveti | 2106 (2020) | T-Mac |
| » | USB ključ formatiranjeOddelek: Pomoč in nasveti | 3809 (3326) | JernejPi |
| » | Diagnostično orodje za WDOddelek: Programska oprema | 5036 (4896) | clovk |
| » | od 160gb diska prikaže le 32, prvo mi je v partition magic prikazalo 160...Oddelek: Strojna oprema | 2501 (2177) | sirotka |
| » | trdi disk hitachiOddelek: Strojna oprema | 2526 (2161) | kerrigh |
