Forum » Na cesti » Avtoradio
Avtoradio
start123 ::
Pozdravljeni!
Nikjer ne najdem spletne trgovine kjer bi ponujali avtoradije v starinski obliki. Torej da bi na zunaj zgledal star "retro" radio, v notrajnosti pa bi se skrival CD predvajalnik ter ostalo..
Nekaj takega:
KLIK ZA SLIKO
Nikjer ne najdem nič, gre pa za v starinskega herbija.
Upam da kdo kaj ve.. Hvala!
Nekaj takega:
KLIK ZA SLIKO
Bias ::
za naše trgovinice nebi vedel...nekaj malega na eBayu, tam boš z malo truda še kakšnega našel. Drugače ti pa predlagam obisk forumov s tematiko: starodobniki, vw itd. vem da sem tam že bral teme o teh radiih tako da ti bodo najbolje svetovali. LP
http://cgi.ebay.ie/VW-Porsche-Fiat-Merc...
http://cgi.ebay.com/ebaymotors/CUSTOM-A...
http://cgi.ebay.com/ebaymotors/VW-Ghia-...
zolja ::
primozzzz ::
Neki me zanima moja punca ma tale avtoradio LG LCS510IR.. Predvaja USB-je.. Zdej pa je kupla nov usb ključek v comshopu 8GB (take ms) pa v avtoradiu napiše usb error.. Kaj nej bi to pomenil, zakaj ne dela? Ostali enake kapacitete delajo ta pa ne. Je nesla že ključek nazaj pa ga nočjo zamenat, ker na računalniku dela.
NI PODPISA
kalko ::
Preformatiraj v FAT32, lahko, da je tovarniško formatiran v NTFS, ki pa ga avtoradio ne bere.
Vikking ::
V navodilih ti piše:
Playable USB device
Requirement
? Do not extract the USB device during operation
(play, etc.).
? An USB device which requires additional
programme installation when you have
connected it to a computer, is not supported.
? Regular back up is recommended to prevent
data loss.
? If you use a USB extension cable, USB HUB, USB
Multi-reader, or external HDD, the USB device
may not be recognized.
? When you connect a partitioned USB device into
the unit, only the fi rst partition is recognized on
it.
? Some USB device may not work with this unit.
? Digital camera and mobile phone are not
supported.
? USB Port of the unit cannot be connected to PC.
The unit cannot be used as a storage device.
? Using NTFS file system is not supported.
(Only FAT (16/ 32) file system is supported.
Playable USB device
Requirement
(play, etc.).
data loss.
it.
supported.
- spremenilo: Vikking ()
primozzzz ::
Sej se mi je kr zdel.. je** nej se pol prodajalc, ki ji je tist ključek priporočal.. sm ji točn reku kakšnega nej kupi, pa jo je prodajalc zavedu, kao da je boljši in cenejši pa da 100% dela povsod
NI PODPISA
miranpozar ::
Ali pa je mogoče kupila napačni avtoradio ;)
Z mojim Alpine ni nobenih podobnih težav.
Miran Požar, Portorož, http://sites.google.com/site/miranpozar/
| » | BattleTechOddelek: Igre | 2830 (1014) | BigWhale |
| » | Zelo Kratek USB (mini) kabelOddelek: Strojna oprema | 2452 (1506) | solatko |
| » | nakup preko eBay-ja (strani: 1 2 3 )Oddelek: Kaj kupiti | 29227 (17298) | St235 |
| » | USB ključ NE dela !Oddelek: Pomoč in nasveti | 4388 (4149) | Lukael |
| » | HP prenosnik- USB težavaOddelek: Strojna oprema | 2502 (2114) | dj71 |
