Forum » Omrežja in internet » how to disable auto login network share folders
kukanja ::
Na google sm pogledu vendar sem našel tutoriale samo za xp in ne za windows 7(tega uporabljam na obeh računalnikih).
Zanima me samo kako spremenim ime za se prijavit v mapo katero delim na mreži, saj sm prvič se prijavil za napačnim računom in zdaj nimam dostopa do podatkov ki so na mojem drugem računu, ter ne vem kako se prijaviti z drugim računom.
Ker slabo razlagam vam dam to za prebrat:
smswe je napisal:
Hello,
Every time when i access the folder from network computer using ip address \\192.168.1.2 it open easily.
But i want to use user name and password when i access to network share folders.
atldjrob je napisal:
I believe what the question / comment is that everytime when he accesses 192.168.1.2, it automatically opens. The first time, there was a prompt for the username and password. Now it never does that. How can he have it automatially ask for a username and password everytime. Not just the first.
Hvala!Prosim tutorial za windows 7 in ne xp.
smswe je napisal:
Hello,
axee ::
V search napiši "credential manager" in izbriši shranjen login, nato te bo ponovno vprašal za login.
| » | VPN za routerjemOddelek: Omrežja in internet | 4846 (4174) | trnvpeti |
| » | Apache virtualhostOddelek: Omrežja in internet | 2121 (1850) | pegasus |
| » | clarkconnect rabim poomoč pri inštaliranju! (strani: 1 2 3 4 5 )Oddelek: Operacijski sistemi | 18917 (10456) | Gapi |
| » | Kako nastaviti router?Oddelek: Omrežja in internet | 9096 (8122) | Miha_T |
| » | Iskra Callisto 821 -gesloOddelek: Strojna oprema | 6594 (4782) | simnov |
