Forum » Programiranje » SQL yet again
SQL yet again
detroit ::
Naredil sm za Service broker queue, contract, service
In ko na triggerju kličem
Mi procedura zapisi_napako v errorlog zapiše
Cannot find the object "MySendingQueue" because it does not exist or you do not have permissions.
Če sm pa v triggerj queriju pa zapišem select * from MySendingQueue mi pa lepo izpiše ta queue
Ima kdo kako idejo kaj mu dogaja
Pa če koga zanima odgovor je JA: nucam broker za asinhronost:)
CREATE MESSAGE TYPE MyMessage VALIDATION = NONE; go CREATE CONTRACT MyContract(MyMessage SENT BY ANY); go CREATE QUEUE MySendingQueue WITH STATUS = ON, RETENTION = OFF ; go CREATE QUEUE MyReceivingQueue WITH STATUS = ON, RETENTION = OFF ; go ALTER QUEUE MyReceivingQueue WITH ACTIVATION ( STATUS = ON, MAX_QUEUE_READERS = 1, PROCEDURE_NAME = baza.procedura, EXECUTE AS OWNER ) CREATE SERVICE MySendingService ON QUEUE MySendingQueue(MyContract); go CREATE SERVICE MyReceivingService ON QUEUE MyReceivingQueue(MyContract); go --to sicer ni nuujno za local------------- CREATE ROUTE MyRoute WITH SERVICE_NAME = 'MyReceivingService', ADDRESS = 'LOCAL' ; go
begin try DECLARE @handler uniqueidentifier DECLARE @Message NVARCHAR(128) BEGIN DIALOG CONVERSATION @handler FROM SERVICE MySendingService TO SERVICE 'MyReceivingService' ON CONTRACT MyContract WITH ENCRYPTION = OFF -- Send messages on Dialog SET @Message = N'blabla'; SEND ON CONVERSATION @handler MESSAGE TYPE MyMessage (@Message) end try begin catch if XACT_STATE() = -1 ROLLBACK TRANSACTION exec zapisi_napako end catch
Skero
detroit ::
bom poenostavil (in pozabil na pravice)
Kako z
service brokerjem dosežeš asinhron klic stored procedure?
Imam queue
sem upal da ko bom poslal message da se bo stored procedure sam zagnal. Ali kdo ve kako je s tem
Closed
Kako z
Imam queue
ALTER QUEUE MyReceivingQueue WITH ACTIVATION ( STATUS = ON, MAX_QUEUE_READERS = 1, PROCEDURE_NAME = shema.write_history, EXECUTE AS OWNER )
Closed
Skero
- spremenilo: detroit ()
| » | [Alternatvni Firmware za router] Vprašanja in težaveOddelek: Operacijski sistemi | 2063 (1333) | BivšiUser2 |
| » | ios swift 1.2Oddelek: Programiranje | 2142 (1548) | detroit |
| » | Exchange 2010Oddelek: Operacijski sistemi | 1295 (1195) | borutzi |
| » | C/C++ Kako obvestim ostale threde, da je prispel nov podatek?Oddelek: Programiranje | 2044 (1908) | ERGY |
| » | Komunikacija med thread-iOddelek: Programiranje | 4378 (4184) | zlatko |
