Forum » Loža » Underclocking
Underclocking
freejack ::
No ja, tale post bi po mojem verjetno bolj pasal v Ložo, pa dobr.Why does'nt anyone ever talk about underclocking? is underclocking really that bad? What are some of the advantages of underclocking?1. Underclock a 2.0GHz to 1.0Ghz, and you can throw away your CPU fan.2. Underclock to 500MHz and you can get rid of your case fan.3. Underclock to 4.77Mhz and you can run older versions of Fligh Simulator.4. Underclock to 4.0 MHz and you can pretend you are running a Z80.5. Underclock too 100KHz and you can actually watch your instructions exeecuute.
- spremenil: alien-w ()
| » | Nigerijci odgovorni za še eno življenjeOddelek: Novice / Zasebnost | 5699 (4490) | Oxford |
| » | Katere RAMe za Epox 9NPA+ SLI z AMD64 3000+ Venice?!Oddelek: Kaj kupiti | 2332 (1925) | Fizikalko |
| » | eno vprasanje glede RAM-aOddelek: Strojna oprema | 1735 (1569) | lambda |
| » | Radeon 9800pro @ 9800XTOddelek: Navijanje | 1575 (1478) | boštjan |
| » | GTA3 DodoOddelek: Igre | 3597 (3124) | burekar |
