eno vprasanje glede RAM-a
dmitro ::
kako vem kok hitr je RAM. 266mhz, 333mhz?? mam pa apacer ram 512mb ddr pc2100 cl2 za prenosnike.
lahko ugotovim tisto hitrost brez da ga mam prklopljenega v racunalnik? ker ga imam zunaj,ga ne uporabljam(rama seveda)
jest10 ::
PC 2100=266MHz, če imaš dober ram bo delel tudi na 333
pc2100 je 133mhz ram. oz ddr266.
dmitro ::
kaj zdej 266 al 333??
PC1600 = 100MHz = DDR200
PC2100 = 133MHz = DDR266
PC2700 = 166MHz = DDR333
PC3200 = 200MHz = DDR400
upam, da je tole dost jasno?:\ :\
dmitro ::
Sm ze nasu. hvala
"There are several types of memory.
Recent memory modules are labelled as PC2100, PC2700, PC3200. The
difference between them is the speed the system can access them using
the FSB (Front Side Bus, see Wikipedia for explation).
PC2100 is 266 Mhz
PC2700 is 333 Mhz
PC3200 is 400 Mhz.
Usually both RAM and mainboard are backward compatible, meaning, they
can work with modules fast or slower than for own speed.
For example, your system has a 266Mhz FSB, then it will support up to
266MHz modules. If you put a PC3200 module in it, it will still be
used with 266Mhz, even though it would support 400 Mhz.
Vice versa, if your board supports 333 Mhz and you put a 266 MHz
module in, it will also run at 266Mhz."
dmitro ::
zanima me kolksna bo razlika v hitrosti ce bom imel skupaj 1x 512MB 333MHz in 1x 512mb 266MHz v primerjavi z 1x 512mb 333mhz.
to sprasujem zato da vidm ce se mi splaca dodat en starejsi vendar malo pocasnejsi ram ali ne?
bistvo: kaj je boljse - 1x512mb ram pc2700 ali 1024mb ram (1x pc2100 + 1x pc2700)??
  • spremenilo: dmitro ()
OZZY ::
ram ti bo pač delal kot dela najpočasnejši ram...Ne na 333 ampak na 266.
Go with the flow.
dmitro ::
to vem. zanima me kje bo performance racunalnika boljsi. pri 1.opciji ali 2.??
Vesoljc ::
probaš?
imho, bo kvanatite boljša
Vesoljc ::
zdej ne vem, kako tvoj bios to dela, ampak moj ima tako, da lahko za vsako banko posebaj nastaviš timinge... se prav, da tud če teče na počasnejši uri, mu lahko dvigneš timimge... mrbit :)
dmitro ::
na kaj morm bit pa pozoren v biosuda bom vedu a se da to stimat al ne?
Vesoljc ::
bank 0 timing
bank 1 timing
kej tacga
Vesoljc ::
aja sam to je prenosnik...
to ne vem če je glih oc friendly
dmitro ::
no probal sem dat v prenosnik 512mb 2100 rama in potem se mi ni hotu zagnat.prizgem in lucka se takoj ugasne.ko dam ram vn pa spet dela normalno. se da kej narest da bi delal?
lambda ::
Sicer off-topic, ampak ko je ravno govora o ramu.
Doma mam čokoladico 256 MB PC2700 buffered rama. Vem, da običajna plata rabi unbuffered ram in zato meni oz. frendu, ki je lastnik tega, ne deluje ... zato pa me zanima, kdo bi kaj takega potreboval (mogoče za serverje, ???) in ali ima taka stvar kako tržno vrednost.
Problem iz Delovnim spominom!!
91903 (1622) Griffith
Vprašanje glede rama
121770 (1674) Dead_Eye
PROSIM za pomoč pri nadgradnji PC-ja
192168 (2027) Jan987
Kva porečete na tole? (strani: 1 2 )
954970 (3455) kuglvinkl
PC3200 400 MHz DDR RAM
211956 (1454) morphling1
