Sesuvanje računalnika
xero135 ::
Zdravo!
Imam en kr velik problem. Računalnik se mi zaradi neznanega razloga sesuva. To se mi dogaja že razmeroma dolgo, vendar se ni nikoli pojavlojalo tako pogosto kot danes. Ponavadi se mi je računalnik sesul ko sem ga prižgal (do namizja sem po navadi prišo v 2-3 poskusih) ter včasih (zelo redko) tudi medtem ko sem igral igre. Toda danes se mi ko prižgem računalnik, po približno eni minuti ko začnem nekaj delati računalnik sesuje (pojavi se mi modri ekran). Nobeden izmed delov računalnika se ne pregreva - vsi so okoli 30 - 40 stopinj. Upam da se bo našla rešitev.
Han ::
Navadno je za to kriv defekten spomin. Za boljšo diagnostiko pa napiši komponente...
xero135 ::
Procesor: Intel(R) core™2 quad CPU Q6600 @ 2.40GHz
4096 Mb RAM-a
Grafična: ATI radeon HD 4800 Series
Naložen pa mam windows 7 ultimate
Wrop ::
In kaj piše na modrem zaslonu?
Mogoče kaj omenja Memory management ali Page fault...?
xero135 ::
Problem has been detected and windows has been shut down to prevent damage
to your computer.
***L_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these stepps:
Check to make sure any new hardware or software is properly installed.
if this is a new installation, ask you hardware or software manufacturer
for any windows updates you might need
If problems continue, disable or remove any newly installed hardware or software.
Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press f8 to select Advanced Startup options, and then
select safe mode.
Technical information:
**** STOP: 0x0000000A (0xFFFFFA7FFFFFFFD0, 0x0000000000000002, 0x0000000000000001***,
****FFF80002A97AE3)
Selecting data for chrash dump...
Initializing disk for chrash dump...
**inning dump of physical memory
**ping physical memory to disk: 100
Physical memory dump complete.
Contact your system admin or technical support group for further assistance
Tiste zvezdice so mesta kjer ne morm prebrat kaj piše ker je izven ekrana.
V tem času ko se je to pojavilo nisem dodajal nobenih komponentov računalnika ter nisem inštalirov nobenega softwara. tisto v biosih pa ne vem kak se naredi :S
Pyr0Beast ::
Ram. Verjetno ti tudi kakšen program sam zapre ali pa se noče odpreti.
Mitch ::
Namesti memtest86+ na zagonski CD ali USB ključ in testiraj RAM, če je kakšen defekt. Če je z RAMom vse v redu inštaliraj tale Microsoftov Hotfix...
comgen ::
Sam sem mel enak problem, resil sem tako, da se formatiral in na novo namestil sistem (po mojem je bil kaksen virus).
ModriN96 ::
tuki nima ram niti mal veze ampak je problem u winsih oz določenem programu al pa u podprocesih k se izvajajo
k4vz0024 ::
Mitch, tistega hotfixa tam ni....
Mitch ::
Kako ni? Levo zgoraj klikni View and request hotfix downloads, potrdi z Accept in nato obkljukaj svojo verzijo Windowsov 7. Nato moraš še vnest email naslov in avtorizacijsko kodo (v okenčku)...
win 7 bsod - okvara matične ?
122385 (2214) vander
Težava z zagonom računalnika (strojna napaka?)
142215 (2008) jat2406
Run time error in podobne napake?
121607 (1514) nokia6310
Navijanje 3400+ na K8N Neo platinum
Oddelek: Navijanje
121612 (1395) Black Metalc
Plavi zaslon
72543 (2344) Border
