Forum » Pomoč in nasveti » 1719 error
1719 error
tuned ::
Ko hočem inštalerat kakšno novejšo igro mi tole napiše:"error 1719. The windows installer service could not be accessed. You may be running in safe mode or windows installer may not be correctly installed. "
Se da to kako popravit?
Hvala in lp.
Hvala in lp.
- polepsal: KoMar- ()
Xserces ::
komponente in pa ker windows sploh uporablas pa katere igre itd... potem ti lahko sele pomagamo
tuned ::
WINDOWS XP SP3 32BIT
Processor: Intel core2 duo E6850 3.00GHZ
Memory: OCZ Gold 4.00GB
Hard Drive: WD 1500ADFD 150 GB, WD 1001FALS 1TB
Video Card: ATI Radeon 4870 512MB
Motherboard:Gigabyte P35C-DS3R
Xserces ::
Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you're still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you'll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you'll need to select Search Hidden Files And Folders under More Advanced Options. When you've found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you've renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
| » | Skype problemOddelek: Programska oprema | 1826 (1231) | tv6865 |
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3668 (3058) | fr!Xy |
| » | windows installerOddelek: Pomoč in nasveti | 1450 (1408) | whiteghosted |
| » | windows media player 10 mi ne dela !?!?Oddelek: Pomoč in nasveti | 1916 (1864) | bunnyrabit |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2496 (2462) | Mercier |
