Forum » Programiranje » [c#] delegat, event handler
DuleKrtola ::
Živ,
ne obvladam najbol teh delegatov, spodaj je koda. Sem probal pobrisat čimveč kode, ki je irelavantna, pa je vseeno 90 vrstic.
Če odkomentiram 34. vrstico ter zakomentiram IF/ELSE, dobim runtime error v omenjeni vrstici:
System.InvalidOperationException was unhandled
Message="Invoke or BeginInvoke cannot be called on a control until the window handle has been created."
Source="System.Windows.Forms"
Če pustim tako kot je (zakomentirane vse 3), mi CreateHandle() povzroči, da se program usuje.
Bi kdo vrgel uč na tole kodo, pls?
using System;
using System.Windows.Forms;
using WiimoteLib;
namespace joyPoll
public partial class Form1 : Form
public delegate void UpdateWiimoteStateDelegate(WiimoteChangedEventArgs args);
Dictionary<Guid, Form1> mWiimoteMap = new Dictionary<Guid, Form1>();
private Wiimote mWiimote;
WiimoteCollection mWC;
public Form1()
InitializeComponent();
public Form1(Wiimote wm) : this()
mWiimote = wm;
private void Form1_FormClosing(object sender, FormClosingEventArgs e)
foreach (Wiimote wm in mWC)
wm.Disconnect();
public void UpdateState(WiimoteChangedEventArgs args)
//BeginInvoke(new UpdateWiimoteStateDelegate(UpdateWiimoteChanged), args);
if (IsHandleCreated)
else
CreateHandle();
private void Form1_Load(object sender, EventArgs e)
mWC = new WiimoteCollection();
try
mWC.FindAllWiimotes();
Form1 wi = new Form1();
mWiimoteMap[wm.ID] = wi;
// connect it and set it up as always
wm.WiimoteChanged += wm_WiimoteChanged;
wm.Connect();
if (wm.WiimoteState.ExtensionType != ExtensionType.BalanceBoard)
wm.SetReportType(InputReport.IRExtensionAccel, IRSensitivity.Maximum, true);
wm.SetLEDs(true, true, false, true);
break;
void wm_WiimoteChanged(object sender, WiimoteChangedEventArgs e)
Form1 wi = mWiimoteMap[((Wiimote)sender).ID];
wi.UpdateState(e);
private void UpdateWiimoteChanged(WiimoteChangedEventArgs args)
WiimoteState ws = args.WiimoteState;
lblAccel.Text = ws.AccelState.Values.ToString();
// tukaj se updatejo labele in checkboxi v formu
public Wiimote Wiimote
set { mWiimote = value; }
Mitja Bonča ::
Delegati potrebujejo eno kontrolo za metodo BeginUpdate (ali katero drugo):
Tebi manjka:
poglej si čisto simple primer:
Tebi manjka:
Control.BeginUpdate(new UpdateWiimoteStateDelegate(UpdateWiimoteChanged), args);
public delegate void InvokeDelegate();
private void Invoke_Click(object sender, EventArgs e)
myTextBox.BeginInvoke(new InvokeDelegate(InvokeMethod));
public void InvokeMethod()
myTextBox.Text = "Executed the given delegate";
} Vredno ogleda ...
| » | c# formOddelek: Programiranje | 2339 (1853) | FuI2cY |
| » | [c#] Risanje z miškoOddelek: Programiranje | 1789 (1470) | japol |
| » | [c#] event, klik tipke escapeOddelek: Programiranje | 1087 (991) | japol |
| » | [c#] Vprasanje glede BackGroundWorker classa in spreminanja gui elementaOddelek: Programiranje | 1097 (1023) | Ericssony |
| » | [VB] Komunikacija s serijskimi napravamiOddelek: Programiranje | 2733 (2007) | mNeRo |
