Forum » Pomoč in nasveti » Kako vključiti 3 monitorje na eno grafično?
mrTwelveTrees ::
radeon 5850
- zaslon lcd povezan z Display port kablom
- zaslon lcd povezan z DVI kablom
- lcd tv povezan z HDMI kablom
nastavite v ATI gonilnihi mi pusti vklopiti samo 2 zaslona na ekrat
device manager mi prepozna 3 zaslone
OS: win xp SP3
To support 3 displays, one of the monitors has to support DisplayPort.
OS: win xp SP3
- spremenil: mrTwelveTrees ()
mrTwelveTrees ::
dela katerokoli kombinacija 2x monitor = ok
tretji je kao onemogočen.... glej sliko
mrTwelveTrees ::
8.723-100406a-098765C-AT
Catalyst 10.4
res na nisem nalozil driverjev iz cdja ampak najnovejse iz Sapphirjeve domače strani.
Catalyst 10.4
Racunalnik ::
Mozno da so zafrknl, oglasujejo 3 monitorje sposobna je pa furat samo 2, 3tji je opcije med 2 in 3tretjim vrjetno imas drugacne priklope in n e3 iste?
M-XXXX ::
Preko VGA/DVI/HDMI imaš lahko priklopljena le 2 monitorja na enkrat, tretji mora biti NUJNO PREKO DISPLAY PORTA!
5er--> ::
Prvi post:
radeon 5850
M-XXXX ::
Ups my bad... Je kabel aktiven ali pasiven? Oziroma bom drugače vprašal: je iz display porta v display port na monitorju ali samo pretvornik iz display porta v naprimer DVI?
krho ::
I had no luck getting 3 monitors to display using one HD 5870 in Win XP. ATI's Eyefinity web page, "What is Eyefinity", states operating system support that includes Windows 7, Windows Vista, and Linux, so that's the big clue regarding Win XP. However, it doesn't say it won't work with Win XP, so I tried even though several people in this forum have said it won't work.klik
Two screens in Win XP on one HD 5870 is easy of course - either DVI-DVI or DVI-DisplayPort works fine for me, but triple monitor DVI-DVI-DisplayPort will not work, and I have the correct Active DisplayPort to DVI adapter (the $100 variety sold by Sapphire for Eyefinity use). When attempting all three monitors on one HD 5870, Windows XP Control Panel>Display>Display Properties>Settings identifies that 3 monitors exist, but I never get an image to display on the third monitor. I can click Extend Desktop to the third monitor but no image appears. Trying to configure the 3 monitors using Catalyst Control Panel (9.11, 9.12, 9.12 Hotfix, or 10.1, I tried all of these) is not the answer, either. CCP cannot enable the third monitor.
When I boot into Win 7, the results are different. DVI-DVI-DisplayPort (using the Active adapter) works fine on one HD 5870. The 3x1 Landscape Display that I use can be easily configured using either Win 7 Control Panel>Display>Change Display Settings or CCP.
To get three monitors to work in Win XP, I have to connect the third monitor to my second HD 5870 card. The connections are Card 1: DVI-DVI. Card 2: DVI or DisplayPort, it doesn't matter, either works. I use Win XP Display Properties>Settings to configure the 3 monitors, although I could have used CCP. This works fine but Cross Fire cannot be enabled until I disable the monitor connected to the second HD 5870 card.
Note that when attempting to get 3 monitors to work with one HD 5870 in Win XP, I actually removed the second HD 5870 from the MOBO.
As a separate topic, having sunk so much money into the 5870s, I have to say I am a little disappointed with the Win XP drivers (driver 9.12 or 10.1) because of display corruption issues. I can't move a window around on a screen or from monitor to monitor very quickly or the image will become scrambled. And I'm not doing anything fancy - just excel, no games, and the GPUs are not overclocked or overheated. Thankfully, this particular problem does not seem to exist in Win 7 (driver 9.12).
Brane2 ::
Kako sej epotem končalo ?
Si na kartici zalaufal 3 monitorje in kje si dobil adapter ?
mrTwelveTrees ::
jah... 5850 radeon 1x lcd na Display Port, 1x LCD na DVI in 1x Lcd TV na HDMI
ter obvezno win 7... deluje super
samo če bi se dalo nastavit na katerem ekranu bi se mi zaganjale igrice bi bilo še bolje
Brane2 ::
Update - mi je ratalo na Linuxu.
En desktop na treh monitorjih. Delaaaa !
Oziroma, je delalo ene 20 minut, dokler ni adapter crknu.
Fora je v tem, da ima kartica samo dva sklopa za generacijo picture frameov itd in če prištekaš ne-DP monitorje, sta gor lahko hkrati samo dva.
Za vse nad tem rabiš AKTIVNI DP adapter. Pasivni so samo dva štekerja in malo žice, zato so poceni ampak aktivni so dražji. Aktivni DP--DVI je cca €100. Zato je pa veliko cenejši aktivni DP--VGA, ki je samo cca. €30.
Razni glupanderji so mi vzeli veliko časa, ko so trdili, da jim 3x setup dela brez problema samo s pasivnimi adapterji. Ne ovbstaja pasiven DP--VGA, ker DP ne zna generirat analognih signalov. Adapter mogoče zgleda kot pasiven, a v VGA štekerju je majhen a zmogljiv čip, ki dela konverzijo.
So pa ti poceni adapterji dostikrat crap. Moj prvi je crknil po 20 minutah ( "Equip", kupljen pri Techtrade ). Ker niso imeli drugega, sem ga našel v Conradu ( na žaost v nemškem skladišču) in naročil...
| » | trije monitorji na en računalnikOddelek: Zvok in slika | 8464 (7716) | Janac |
| » | priklop treh monitorjev na ATI vga (strani: 1 2 )Oddelek: Pomoč in nasveti | 10739 (9871) | frudi |
| » | crknila grafična 8800gt, rabim zamenjavoOddelek: Kaj kupiti | 6731 (5760) | Dragi |
| » | Eyefinity - Trije monitorjiOddelek: Pomoč in nasveti | 2968 (2403) | Janac |
| » | 3 ekrani na eni karticiOddelek: Zvok in slika | 1693 (1602) | romario |
