Forum » Kaj kupiti » Plazma Lg ali Panasonic?
robert1981 ::
Odločam se ob nakupu nove plazme in me zanima ali se splača odšteti dodatnih 200 evrov in kupiti Panasonicovo. Ker je po karakteristikah Lg-jova boljša.
LG plazma TV 50PK750 http://www.ceneje.si/avdio-video/televi...
PANASONIC plazma TV TX-P50S20E http://www.ceneje.si/avdio-video/televi...
Hvala za odgovor in komentarje, če kdo pozna omenjeni plazmi.
jajcar ::
bolje je da se odločiš za Panasonica,je vseeno boljša kvaliteta,pa še kakor vem imajo od 21.05.2010 dalje 5 letno garancijo na njihove modele.
robert1981 ::
Pa je bolša kvaliteta glede na to da ima lg 3.000.000:1 dinamičnega razmerja, panasonic pa 2.000.000:1? Bi moralo biti ravno obratno. Za 230 evrov pa si lahko privoščim še domači kino...
Cveto ::
Pusti tisto razmerje, to se ne pozna toliko (če se da normalno gledati LCD za 50.000:1 potem vidiš da ti miljoni ne pomenijo toliko.
Problem LG-ja je image retention in to res ni nekaj s čimer bi TV letnika 2010 smel imeti probleme:
And now to reveal that aggravating flaw mentioned right at the start of this review: image retention.
Basically, throughout the few days that I had the 50PK790, my use of it was constantly blighted by extremely distracting residual 'echoes' of bright, colourful image elements hanging around over subsequent images - sometimes for as much as an hour at a time.
And before you ask, no, I'm not talking about a phenomenon that only happens if I leave the Sky News logo playing uninterrupted for a good few hours. Even bright image content that's only been on screen for a few seconds can still be clearly, annoyingly visible on the next few frames, especially if those subsequent frames are predominantly dark.
The only time I did experimentally leave the Sky News logo running on the screen for any significant amount of time - a couple of hours, I guess - I could clearly see its ghostly outline hanging over anything else I watched afterwards for at least an hour, possibly more.
Of course, plasma TVs used to suffer quite routinely with image retention, and were renowned for falling prey to permanent screen burn if you really pushed your luck. I also know that plasma TVs are more prone to image retention during the first 100 hours or so of their life, so I'd expect - though can't guarantee - that the problem will reduce as the 50PK790 gets older.
But even so, there's simply no getting round the fact that the retention problems on the 50PK790 are troubling even by old plasma standards, and shouldn't exist to anywhere near this extent on a 2010 plasma model. And before you ask, I was so concerned about the problem that I ordered a second model from LG's new range, the step-up 50PK990, and found that this suffered with the same problem, albeit to a lesser extent.
This really is a hugely frustrating issue that for me - as someone who hates anything that distracts me from what I'm supposed to be engrossed in watching - spoils what might otherwise have been a potential 'TrustedReviews Recommended' TV. Sigh.
For the record, the audio the 50PK790 produces to accompany its nearly-great pictures is above average. There's not as much bass as I'd like, but this is a common flat TV failing, and at least the 50PK790 does better than many rivals at presenting an open, detailed, distortion-free mid-range that seldom feels underpowered.
| » | Plazma ali LED LCD (strani: 1 2 )Oddelek: Zvok in slika | 32302 (29227) | gorann |
| » | LCD LG ali PhilipsOddelek: Zvok in slika | 5631 (5111) | Dromar |
| » | LG 50PK350 PLAZMA TV - ali ima DVB-C?Oddelek: Kaj kupiti | 3326 (3052) | whatever |
| » | Panasonic 50G20 ali LG 50PK350 ali LCDOddelek: Kaj kupiti | 2576 (2067) | Priesteye |
| » | Lcd sony ali plasma panasonic (strani: 1 2 3 4 )Oddelek: Zvok in slika | 82199 (76034) | mamomu |
