Forum » Kaj kupiti » Katera garfična ASUS 5870 Matrix ali ASUS GeForce GTX 480
Hribi ::
Živjo kolega kupuje nov računalnik pri katerem si ni zadal večjih omejitev :) Če bi izbirali med omenjenima karticama, katero bi izbarli? Delala pa bo na 2.560 x 1.440 resoluciji. Cena je pa tako ali tako podobna.
ASUS Radeon HD 5870 2GB MATRIX
Graphics Engine ATI Radeon HD 5870
Bus Standard PCI Express 2.1
Video Memory GDDR5 2G
Engine Clock 894 MHz
Memory Clock 4800 MHz ( 1200 MHz DDR5 )
RAMDAC 400MHz
Memory Interface 256-bit
D-Sub Max Resolution 2048 x 1536
DVI Max Resolution 2560 x 1600
D-Sub Output Yes x 1 (via DVI to D-Sub adaptor x 1 )
DVI Output Yes x 2 (via HDMI to DVI adaptor x 1 )
HDMI Output Yes x 1
DisplayPort Yes
HDCP Support Yes
Adapter/Cable Bundled 1 x CrossFire cable
1 x Power cable
1 x HDMI to DVI adaptor
Software Bundled ASUS Utilities & Driver
ASUS Features Matrix Series
Note Dimension 11.5" x 5"
ASUS GeForce GTX 480 1536MB Mini-HDMI
Graphics Engine NVIDIA GeForce GTX480
Bus Standard PCI Express 2.0
Video Memory GDDR5 1536MB
Engine Clock 700 MHz
Shader Clock 1401 MHz
Memory Clock 3696 MHz ( 924 MHz DDR5 )
RAMDAC 400MHz
Memory Interface 384-bit
DVI Output Yes x 2 (DVI-I)
HDMI Output Yes x 1
HDCP Support Yes
Adapter/Cable Bundled 1 x DVI to D-Sub adaptor
Design Garage&Supersonic Sled
Note The card size is 11” x 5.5” inch
RAMDAC 400MHz
HDMI Output Yes x 1
DisplayPort Yes
HDCP Support Yes
1 x Power cable
RAMDAC 400MHz
HDMI Output Yes x 1
HDCP Support Yes
- spremenil: Hribi ()
Hribi ::
KO hvala bomo mal pogledal. Čeprov je meu kolega namen potem s leti dokupet še eno od navedenih kartic da bi mel potem v crossfire oz. SLi.
IvoJan ::
pa sej pol lahk se eno HD5850 dokup :D
Hribi ::
Sedaj imam pa jaz namen kupit novo grafiko in sicer sem se po pregledu ponudbe odloču za Ati Club 3D Radeon HD 5850 "OC Edition". Se mi zdi najboljše za price-performance. Kakšni pomisleki? Kasneji bi jo fleshau na Club 3D Radeon HD 5870 "OC Edition".
IvoJan ::
ne vem kako bi to šlo. flashalo se je samo kartice z referenčno zasnovo. ostale so se brickale.
tade911 ::
Kaj je fora tega flashanja grafične? Isto kot navijanje?
Antec-902;I7-920;CM-V8;Patriot-6GB-1600Mhz;CM-1000W;GTX275;WD-Black-1GB;Fatal1ty
IvoJan ::
jup
dovoljuje visji overclock.
- spremenil: IvoJan ()
Hribi ::
A če na asus 5850 naložim 5870 je stvar stabilna, se kaj pregreva? A so še kakšne droge prednosti razen cene?
Hvala
Hvala
| » | Katera low-med end grafična kartica?Oddelek: Kaj kupiti | 1034 (917) | D_LEONIT |
| » | Nemorm uporabljati ati display driverjevOddelek: Pomoč in nasveti | 1864 (1667) | Xserces |
| » | ATI 5870 (strani: 1 2 3 4 )Oddelek: Strojna oprema | 14040 (9213) | Shadow666 |
| » | Grafa GeForce EN5750 ali alternative?Oddelek: Kaj kupiti | 1392 (1303) | Tea Time |
| » | GeForce4 Ti4800SE DeluxeOddelek: Novice / Grafične kartice | 2591 (2591) | McHusch |
