Forum » Omrežja in internet » 2x router SMC in Bridge mode
mato22 ::
Živjo!
Doma imam dva brezžična routerja.
Prvi je gigabitni SMCWGBR14-n ki je povezan prek WAN v modem in prek LAN na ostale PC-je... Drugi router je 10/100 SMCWBR14-n in bi ga rad uporabil za izboljšanje signala, saj mi v zgornjem nadstropju stanovanja prvi router ne lovi več (skrit je za omaro in pritrjen na zid).
Je kakorkoli mogoče uporabiti ta drugi router, da bi postavil neko vmesno točko in s tem v zgornjem nadstropju pridobil dostop do interneta...
Routerja imata oba možnost bridge, če to kaj pomeni, a nikakor ne vem kaj in kako nastavit, da bi drugi router povezal brezžično na primarnega. Nekaj sem se igral na drugem routerju z vklopom bridge, a potem ne vem kaj in kako in če je to sploh prava zadeva.
Hvala in LP!
Hvala in LP!
krofeta ::
WDS Enable
When WDS is enabled, this access point functions as a wireless repeater and is able to wirelessly communicate with other APs via WDS links. Note that WDS is
incompatible with WPA -- both features cannot be used at the same time. A WDS
link is bidirectional; so this AP must know the MAC Address (creates the WDS link)of the other AP, and the other AP must have a WDS link back to this AP. Make sure the APs are configured with same channel number.
WDS AP MAC Address
Specifies one-half of the WDS link. The other AP must also have the MAC address
of this AP to create the WDS link back to this AP. Enter a MAC address for each of
the other APs that you want to connect with WDS.
Vir: http://www.smc.com
Na ober routerjih moraš vklopiti funkcijo WDS, s tem se routrerja postavita v repeater (ali AP dostopna točka) način. V vsakega moraš vpisati MAC naslov od drugega, da se vspostavi link. MAC naslov od routerja najdeš najbrž na nalepki pod routerjem ali pa v admin konzoli.
Več ti o konkretnem routerju ne morem povedati, ker routerja na poznam.
WDS: Wiki
WDS AP MAC Address
WDS: Wiki
markk1 ::
bom uporabil kar tole temo
zanima me če je možno med seboj povezat dva routerja preko wirelessa tako da je "glavni wan" Netgear WGR614 kot bridge pa bi imel SMC2804WBR
hvala za pomoč
hvala za pomoč
danielka84 ::
in kako lahko potem zaščitiš mrežo, če imaš med dvema routerjema WDS link, pri DD WRT se lahko še potem povežejo klienti na ta 2 routerja, WPA pa nemoreš vklopit..
ni-da-ni
- spremenil: danielka84 ()
krofeta ::
Če sta routerja v WDS načinu potem se klienti ne morejo povezevati na wireless. Wireless je uporabljen za prenos interneta na drugi router. Klienta lahko na router priključiš samo preko kabla.
Druga možnost pa je, da se iz prvega do drugega routerja potegne kabel in potem preko drugega routerja klienti dostopajo brezžično na internet.
Mislim, da je najbojša varijanta na prvi router dati boljše antene, 9db ojačanja.
| » | Težave z WIFI - routerOddelek: Pomoč in nasveti | 3294 (2714) | Cifix63 |
| » | WRT54GL RUTER(dostopna točka), povezava je omejenaOddelek: Pomoč in nasveti | 1291 (1186) | djforever |
| » | Repeater Bridge na Linksys WRT160NL??Oddelek: Pomoč in nasveti | 7235 (4503) | toncek1 |
| » | Linksys WRT54G In Tomato Firmware (strani: 1 2 )Oddelek: Omrežja in internet | 20849 (13786) | Hayabusa |
| » | povezava 2 rutarjevOddelek: Omrežja in internet | 4901 (4495) | cordoba |
