Forum » Pomoč in nasveti » Stabilnost Comp
Stabilnost Comp
AnWar ::
Zdravo!
Mene namrec zanima, ali lahko to smatram da je racunlanik ( procesor) stabilen, ce je bil pod testom Prime 95, 13 ur nato je pa navedlo error za eno jedro. Imam namrec 4 jedrni procesor.
Hvala, za odgovore.
Hvala, za odgovore.
[PC AMD7800X3D 5.2GHZ ,7900XT,32GB G.SKILL CL30 6400MHZ,ASROCK X670E]
- spremenil: AnWar ()
AnWar ::
Ok, se eno vprasanje koliko casa pa pustim, da vem ce je racunlanik stabilen?
Sm ze nasel odgovor hvala :)
24 hours' testing is recommended to be sure, as errors may show up after 16 or more hours of testing (compared to, say, just 4 hours of testing).[5] Moreover, a large proportion of system overclockers and enthusiasts favor Prime95 over other benchmarking suites because Prime95 pushes the CPU's floating point units extremely hard, causing the CPU to become extremely hot.
| » | Windows zamrzne med stress testom s Prime95Oddelek: Pomoč in nasveti | 2268 (2092) | Nagi Bator |
| » | Navijanje (strani: 1 2 )Oddelek: Navijanje | 13771 (12483) | wate |
| » | Nenadni restart v igrahOddelek: Strojna oprema | 3329 (2912) | Sami |
| » | prenosnik za igre do 1200EOddelek: Kaj kupiti | 9491 (8863) | iloveboobz |
| » | Program, ki segreje procesor q6600Oddelek: Navijanje | 2622 (2398) | Dr_M |
