Forum » Omrežja in internet » mldonkey (linux) problem
borchi ::
ne uspe mi usposobit mldonkeya. ko poženem ./mldonkey mi napiše:
Your system supports 1024 file descriptors
Error loading comments.met: Sys_error("comments.met: No such file or directory")
Exc Not_found
Exc Not_found
Exc Not_found
Exc Not_found
Exc Not_found
Exc Not_found
Exception Pervasives.Exit in Options.save
Loading history file ...
Exception: bind failed: Address already in use at port 4080
Exception bind failed: Address already in use while starting HTTP interface
Exception: bind failed: Address already in use at port 4000
Exception bind failed: Address already in use while starting telnet interface
Exception: bind failed: Address already in use at port 4001
Exception bind failed: Address already in use while starting GUI interface
Exception: bind failed: Address already in use at port 4662
Error: Exception bind failed: Address already in use during startup
probal sem tako z shared kot static verzijo. to bi verjetno lahko pomenlo, da že laufa en mldonkey, ane? sam mi vedno isto nardi, tut ko resetiram linux. ideje?
a je komu uspelo skompajlirat mldonkey iz CVSja?
hvala!
Exc Not_found
Exc Not_found
Exc Not_found
Exc Not_found
Exc Not_found
Exc Not_found
hvala!
l'jga
blabla ::
borchi ::
blalbla: hvala, ta link sem že vidu in men se je zgodilo isto ko temu tipu, kr naenkrat je proradilo ;-)
i'm never going back to windows! ;-)) zdej bom pa še probal skompajlirat mldonkey iz CVSja - pol maš pa podporo za skor vse p2p networke!!! SWEET!
l'jga
| » | Dnsmasq problemOddelek: Omrežja in internet | 1481 (1108) | BlaY0 |
| » | python -slovarOddelek: Programiranje | 3789 (2768) | Valex86 |
| » | clarkconnect rabim poomoč pri inštaliranju! (strani: 1 2 3 4 5 )Oddelek: Operacijski sistemi | 18891 (10430) | Gapi |
| » | Slackware Linux (strani: 1 2 )Oddelek: Operacijski sistemi | 5305 (4222) | tx-z |
| » | problemi z zvocno v linuxuOddelek: Operacijski sistemi | 2020 (1963) | BigWhale |
