Forum » Pomoč in nasveti » Winsxs direktorij v w7
xandros ::
Imam intel procesor.
V tem direktortiju so amd64 direktoriji datoteke.
Ali lahko to brisem?
Ali lahko stisnem ntfs compression winsxs direktorij?
bluefish ::
Ne, vsebine direktorija ni priporočeno brisati. Več si preberi: http://www.winvistaclub.com/f16.html
"The Winsxs folder, stores multiple copies of dll's in order to let multiple applications run in Windows without any compatibility problem. If you browse inside, you will see what look like a lot of duplicate dlls, each having the same name. These are actually, different versions of the same files which are being stored; as different programs may require different versions. In short, Winsxs, which stands for 'Windows Side By Side', is Vista's native assembly cache. Libraries which are being by multiple applications are stored there. This feature was first introduced, in Windows ME and was considered as Microsoft's solution to the so-called 'dll hell' issues that plagued Windows 9x."
trnvpeti ::
tam se datotek ne da brisati
pa kar rece ms, da se ne da, ni glih za verjet :)
zbrisi, pa povej, kaj se zgodi :)
darkolord ::
Lahko jest povem, kaj se zgodi, brez da bi mu blo treba brisat - kup stvari bo nehalo delovat. Pol bo pa treba slučajno formatirat.
- spremenilo: darkolord ()
bluefish ::
trnvpeti ::
Re: Can I remove C:\Windows\winsxs
Quote Quote: Originally Posted by Simba49 View Post
I never said i didnt like the effects or anything, i only stated what i used it for. I have deleted the folder and nothing has happened except give me space (not that i need it).
dej naj nekdo pove navodila, kako se brise tam
se proba na eni virtualni masini :)
- spremenil: trnvpeti ()
darkolord ::
Jaz sem to probal v VM pa tudi že reševal situacijo, ko je nekdo to pobrisal. Resnično ne priporočam. Na prvi pogled sicer zadeve delujejo, v resnici pa kar veliko servisov potem ne deluje, kot bi moralo.
ender ::
Z brisanjem WinSxS mape se pridobi izredno malo prostora, ker so praktično vse datoteke od tam hardlinkane še kam drugam na disku (kar pomeni, da če zbrišeš datoteko iz WinSxS si zbrisal samo eno od njenih imen).
trnvpeti ::
ce je samo hardlinkano, potem verjetno ni problem zbrisat
ce recimo pogledas same datoteke, potem vidis da je krepko preko 6G(minimalno) prostora v teh direktorijih
naj kaksen win strokovnjak napise postopek brisanja posamezne datoteke, da probamo
amigo_no1 ::
Kaj dela winsxs mapa:
kratko in jedrnato:
kratko in jedrnato:
Mavrik ::
Kratko in jedrnato: če boš šao sem brisat datoteke, ti bodo stvari začele hitro crkovat in to tak na tiho. Potem bo pa spet vse drugo krivo.
trnvpeti ::
kot vidim, se nihce to ni probal
drugace bi videli, koliko je to veliko, da se ne da brisat, ...
se pravi, teoretiki...
darkolord ::
kot vidimCel jasnovidec
drugace bi videli, koliko je to veliko, da se ne da brisat, ...Kaj si pa s tem mislil povedat? Da je preveč fajlov in jih zaradi tega ne bi mogel izbrisat?
| » | Win 7 - rabim prostor na SSDOddelek: Pomoč in nasveti | 2411 (2196) | Cveto |
| » | winsxs težave...Oddelek: Operacijski sistemi | 1736 (1428) | GTX970 |
| » | WinSXS tezave in krizi ter kako ga "stisniti"Oddelek: Operacijski sistemi | 1506 (1112) | Alen T 1978 |
| » | Windows 7 - filanje diska C:Oddelek: Operacijski sistemi | 2911 (2507) | amigo_no1 |
| » | Windows 7 beta ušla (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 14040 (8276) | Pesimist |
