Plata pa procesor
Plata pa procesor
Storm ::
Zanima me če se da na plato Abit KT7 Raid dodat procesor XP 1700-ko. Zdej mam durona 600.
Hvala;((
pozzo ::
aaaaa sssssiiiiiiii noooooooorrrrrrrr?????????!!!!!!!!!
:P
Ne znam tipkat brez tipkovnice...
iration ::
AMD 1.4GHz(133)CPU je največ kar lahko daš gor.
Tudi jaz bi imel kakšno pravico rad v življenju. Npr. pravico do tega, da delam
12 ur na dan in sem za to nagrajen s strani delujočega ekonomskega prostora, ne
pa kaznovan s strani Salmoneličevih gremlinov. - NavadniNimda
kuglvinkl ::
In glej da dobiš verzijo (B), ki ima FSB 100MHz, ker s KT7 čez 113 MHz FSB ne boš prišel. Če ga ne dobiš, in stakneš C, potem boš moral odklent in dvignit multipl.. Skratka np.
pozzo ::
KT7/KT7-RAID: 100MHz (200MHz DDR) FSB processors only. Fastest processor supported is the Athlon 1400(100) - but it must have locked (disconnected) L1 bridges. AthlonXP processors are not and will not be supported. All Duron and Duron (Morgan core) processors are supported.
KT7A/KT7A-RAID versions 1.3: All Duron, Duron (Morgan core), Athlon (Thunderbird) and AthlonXP processors to 2100+ are supported. AthlonXP processors at 2200+ are not supported.
:O
ABIT KT7A + Duron 1800 = unknown CPU
161899 (1765) Dr_M
Neuradno kateri max CPU podpira ABIT KT7A?
252022 (1755) jest10
KT7A + Athlon XP
222542 (2076) Jure2k
Abit KT7A + TB 1,4........
Oddelek: Navijanje
292014 (1660) kuglvinkl
AMD XP proci,...
432665 (1821) SlaveMaster
