Duron 1300 oc.
Duron 1300 oc.
Murja ::
Mogoče veste na koliko se da naviti Duron 1300 Mhz. Nekje
sem zasledil, da se množilnika ne da odkleniti, tako da je
možen overclock samo preko FSB.
Mogoče kdo ve kako je s tem? Imate kakšne izkušnje z
navijanjem tega procesorja?
LapD ::
Murja ::
V bistvu sm mel v mislih tole:
http://www.tomshardware.com/cpu/02q1/02...
Overclocking: AMD Puts A Clamp On The Multiplier?
In the routine overclocking tests, we noticed that the
multiplier of the Duron 1300 was locked. Even after bridging
the L1 contacts, we still weren't able to release the multiplier.
We investigated the Duron 1300 together with many of the
latest motherboards with the VIA KT266A chipset as well as
the SiS 735 chipset. However, the results were always the
same: adjusting the multiplier to below 13.0 hampered the
bootup process, while CPU settings of 14.0 or 15.0
(pseudo-multipliers) were promptly ignored. In any case,
we couldn't tell if this had to do with a hand-picked CPU, or
if AMD has begun using a multiplier lock starting with the
Duron 1300. So the only way to overclock was to increase
the FSB clock speed. In the test, the AMD Duron 1300 ran
stably at a maximum of 1438 MHz, using traditional air-cooling.
Zaklenjen duron
Oddelek: Navijanje
241565 (1427) SodVina
Po moje mu je prevroče - help!!!
51127 (1016) Surfer_D
Kako se bodo navijali bartoni?
Oddelek: Navijanje
211510 (1250) Fury
Asus A7S333 -> voltaža
91513 (1434) m.i.h.a.
Vaše iskušnje z 1G duronom
Oddelek: Navijanje
221693 (1302) AtaStrumf
