Forum » Strojna oprema » POMOC PROSIM Sapphire ATI Radeon VAPOR-X HD 5770
IvoJan ::
ker je asrock??
Xserces ::
ja peshkeer zdej se bomo kregal zard Biosa:D
pa se zmer mi ni jasn kako grafa ni kompatibilna iz plato....... =.=
- spremenil: Xserces ()
IvoJan ::
zato ker je asrock :P
Xserces ::
pa sej asrock ni zdej slaba tko...:S
sam tale chipset od intla je mau tko...
IvoJan ::
ja so kr porazne no.. skor nikol ne dela use tko k more.. jih mamo v soli in so bl za en kurac...
Vanadium ::
Evo link od plate:
link
pa še spec:
Idi v bios in se po celem biosu sprehodi in preglej če imaš kje opcijo on board vga ali kar koli podobnega. To daj na disable, pa preklopi potem kabel na ati pa bi moralo delat
link
pa še spec:
1. LGA 775 for Intel(R) Dual Core Core™ 2 Extreme / Core™ 2 Duo / Pentium(R) Dual Core / Celeron(R), supporting Dual Core Wolfdale processors
2. Intel(R) 945GC A2 Chipset
* Compatible with all FSB1333/1066/800/533MHz CPUs except Quad Core
* Supports Dual Channel DDR2 667/533 x 2 DIMM slots with max. capacity up to 4GB
* Intel(R) Graphics Media Accelerator 950, DirectX 9.0 and Max. shared memory 224MB
* 1 x PCI Express x16 slot
* Hybrid Booster - Safe Overclocking Technology
* Untied Overclocking : During overclocking, FSB enjoys better margin due to fixed PCIE/ PCI Buses
* 4 x SATAII 3.0 Gb/s connectors, 10/100 Ethernet LAN
* Windows(R) Vista™ Premium 2007 Logo Ready
Xserces ::
madpanter :) smo ze obdelal to...
Internal Graphics Mode Select
If you select [Auto], the onboard VGA will be automatically disabled when
you install VGA card; the onboard VGA will be enabled without the installation
of any add-on VGA card. If you select [Enabled, 8MB] or [Enabled,
1MB], the onboard VGA will be enabled.
| » | Grafična kartica - AGP ! (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 17458 (15830) | ThomasSGS |
| » | Video onboard + agp vga ne delujeta hkratiOddelek: Strojna oprema | 2239 (1998) | ender |
| » | Disable VGAOddelek: Zvok in slika | 1514 (1514) | d3n!5 |
| » | problem z asrockomOddelek: Strojna oprema | 1917 (1586) | Good Guy |
| » | Težave z grafično kartico Radeon 9800 ProOddelek: Pomoč in nasveti | 2024 (1906) | DominusSLO |
