Forum » Pomoč in nasveti » Optiarc DVD RW AD-5170A
joze24 ::
DVD mi kar naenkrat noče več zapisovati DVD-jev ( CD-je pa ), pa tudi bere mi samo originalne DVD-je, zapečenih mojih od prej in od kolegov pa ne.
Kaj bi bilo narobe ?
Sem že probal tole pa nič ne pomaga :
Optical drives never require a driver when used in any Windows os from Win95 up. Windows XP provides native support that allows this drive to read a data or music disk and to burrn a cd-r disk. No support for playing dvd disks or for burning dvd disks. For that task, compatible 3rd party recording & dvd decoding software is required.
If problem is non-detection by the os, read on....
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
And here's another method that will do this automatically for you if you're afraid to edit the registry manually.
Code:
http://forums.driverguide.com/showthrea... (automatic fix, post #7, download file: CdGone.zip)
Simple solution:
Situation
Solution
Code:
bluefish ::
Lahko poskusiš nadgraditi firmware, vendar je po vsej verjetnosti pogon fuč - nič nenavadnega za Optiarc.
oldguy ::
Pozabi na trike in ne izgubljaj časa, če je v garanciji, ga nesi nazaj, drugače kupi novega. V petnajstih letih se je namreč kvaliteta dramatično znižala (cena pa tudi). Kot primer, doma imam še vedno cca. 15 let starega Plextorja, ki še vedno deluje, optiarcov pa na firmi gotovo zamenjamo vsaj 5 na leto. Pogoni so dandanes pač potrošna roba...
joze24 ::
V garanciji ni več, vendar še ni star 3 leta.
Kako pa to da CD-je še vedno peče, če je crknil ?
Pa tudi originalne DVD-je bere...
- spremenil: joze24 ()
oldguy ::
Da, že, lahko sicer še naprej uporabljaš funkcije, ki delujejo, vendar ne pričakuj, da bodo še dolgo delale, niti da ga boš uspel popraviti. Resno, delni crkot optiarcov ni nič posebnega, sploh če je preživel tako "dolgo". Vrzi stran, kupi novega... Ni vredno zgubljat časa s popravili...
- spremenil: oldguy ()
Han ::
CD-je peče z drugim laserjem. Slabša moč laserja in zaprašena leča sta najbolj verjetni vzrok. Originalni DVD-ji precej bolje odbijajo svetlobo...
- spremenil: Han ()
| » | registerOddelek: Programska oprema | 1865 (1352) | Aleš Ocepek |
| » | Dvd Enota Izginila Iz Sistema!?!Oddelek: Strojna oprema | 2080 (1487) | Xserces |
| » | winxp, safe mode ne dela, problem z registromOddelek: Pomoč in nasveti | 2555 (2487) | SkIDiver |
| » | med win updatom resetiral compOddelek: Operacijski sistemi | 1928 (1756) | pack |
| » | Virus uniču cd-rom!! nujnoOddelek: Pomoč in nasveti | 2687 (2115) | alesrosina |
