Forum » Programska oprema » Opera in clean install
thejohny ::
Pozdravljeni
Mam eno težavico, ki mi ne da miru in sicer Opera (10.10) mi noče odpirat določenih strani... tiste z certifikati (skb net, gmail...), če kdo ve kako rešim to mi prosim...
... ja pa poizkušal sem z clean instalom pa mi hudič nekje potegne prejšnje nastavitve in bukmarke... tako da sem zopet na začetku.(kaj vse moram spucat da se losam vsega kar je v zvezi z opero??? register, documents, program files...???)
aha pa nekaj na ta način mi meče pri omenjenem problemu...
Error!
Unable to complete secure transaction
You tried to access the address https://www.skb.net/, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Secure connection: fatal error (592)
All encryption methods are disabled in Preferences.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
Need help?
Open the Opera Help.
Go to Opera's online support desk.
Hvala za pomoč že v naprej!!!
Janez
Error!
Need help?
Janez
- premaknil iz Pomoč in nasveti: bluefish ()
darkolord ::
Tools -> Preferences -> Advanced -> Security -> Security Protocols
Imaš vse tri obkljukane?
thejohny ::
... he rtfm a ne... kaj vse nism probal in tud tle sm probaval z vsemi kombinacijami... res da z prejšnjo verzijo opere, ampak zdaj mi zadeva špila, samo certifikate potrdim pa zalaufa...
Najlepša hvala za pomoč!!!
| » | [Opera] Unable to complete secure transactionOddelek: Slo-Tech | 3445 (2189) | pegasus |
| » | Arduino in luči (strani: 1 2 )Oddelek: Elektrotehnika in elektronika | 14741 (12367) | FX6300B |
| » | Slo-Tech bug: Napačen error codeOddelek: Slo-Tech | 1453 (1285) | Tilen |
| » | ST-kaj se dogajaOddelek: Slo-Tech | 2291 (1497) | Urc |
| » | Posrednik zavrača povezaveOddelek: Pomoč in nasveti | 3803 (3694) | amigo_no1 |
