Forum » Programska oprema » Exchange 5.5 na Exchange 2k
Ali obstaja kakšna elegantna rešitev za prenos mailboxov iz exchnage 5.5 na W2k.
Težava je v tem da imam X400 konektorju tisti Pm DOT , pa ne morem nadgraditi na Exchange 2k.
Da bi ročno premetaval mailboxe pa se mi ne da.
andrej ::
obstaja kar nekaj podjetij, ki se s tem ukvarja. Recimo Aelita je ena izmed njih. Google v roke pa je
Drugace pa mas tudi Active Directory connector od MS-ja
Microsoft Active Directory™ Connector (ADC) is included in both Exchange 2000 and Microsoft WindowsŽ 2000. It allows administrators to replicate a hierarchy of directory objects between a Microsoft Exchange Server 5.5 directory and Windows 2000 Server Active Directory. It is an essential tool for companies migrating from Exchange 5.5 to Exchange 2000.
Active Directory Connector is a key element of the flexible upgrade and migration strategies from Microsoft Windows NTŽ 4.0 to Windows 2000 and from Exchange Server 5.5 to Exchange 2000. Features of the Active Directory include the following:
Fast, one-stop population of Active Directory with the directory information stored in the Exchange 5.5 directory.
Bi-directional replication between Exchange and Active Directory. Only changes are replicated between the directories, reducing network bandwidth utilization.
Bulk import and export from Active Directory using a text file format.
Flexible object matching rules for connecting objects in the Exchange 5.5 directory and Active Directory, resulting in fewer conflicts and enabling more flexibility in how Active Directory is populated using Exchange.
Use of connection agreements that allow administrators to fine tune the replication schedule, the authentication parameters, and the format of the replication schema.
Bom preveril , ampak to je mišljeno bolj če imaš Win2k in Exchange 5.5. Tu rabiš ADC.
Ker same userje sem jaz že dobil , sem naredil mix mode itd. sedja brad prišel iz Exchange 5.5 na 2k kar pa mi ravno zaradi X.400 konektorja ki ima za site tisto prokleto piko notri , kar pa Exchange 2k ne podpira in direktne nadgradje ni.
| » | workgroup -> domenaOddelek: Omrežja in internet | 5760 (4578) | bastadu |
| » | [Exchange 2003] Fornt-end/Back-end in smart host v obe smeriOddelek: Operacijski sistemi | 2268 (2105) | Microsoft |
| » | Starejše aplikacije ne bodo tekle na Windows Server 2003Oddelek: Novice / Operacijski sistemi | 2658 (2658) | Narcos Satanicos |
| » | Windows Domain - kaj je bolš od navadnih sharovOddelek: Pomoč in nasveti | 1390 (1276) | andrej |
| » | Program s adresarjemOddelek: Programska oprema | 2499 (2418) | andrej |
