[Kubuntu] Problem z apt (python?)
The B ::
Pozdravljeni!
KPackageKit je poskusil namestiti popravke in je bil pri tem neuspešen. Po ročnem zagonu apt-get update && apt-get dist-upgrade me čaka tole:
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these.
The following packages have unmet dependencies:
python-newt: Depends: libnewt0.52 (= 0.52.2-11.3ubuntu3) but 0.52.2-11.3ubuntu3.1 is installed
E: Unmet dependencies. Try using -f.
Zaženem sudo apt-get -f install in rezultat je tole:
Preparing to replace python-newt 0.52.2-11.3ubuntu3 (using .../python-newt_0.52.2-11.3ubuntu3.1_amd64.deb) ...
pycentral: pycentral pkgremove: package python-newt is not installed
dpkg: warning - old pre-removal script returned error exit status 1
dpkg - trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/python-newt_0.52.2-11.3ubuntu3.1_amd64.deb (--unpack):
subprocess new pre-removal script returned error exit status 1
pycentral: pycentral pkginstall: package python-newt is not installed
dpkg: error while cleaning up:
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Vse sem že poskusil (med drugim sem odprl tudi tole povezavo) pa ni rešitve na vidiku.
Imel sem tudi probleme z diskom (slabi sektorji, morda?), pa ne vem če je problem povezan. Res bo vsak nasvet dobrodošel. Tudi boljše mesto za tole vprašanje, če ne odgovora...
B
The End Is The Beginning Is The End...
http://blaze.sopca.com/
[UBUNTU 10.04] GRUB se ne postavi
Oddelek: Operacijski sistemi
338230 (8014) matijaz74
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
1960128095 (43769) RedDrake
[Debian] Po dveh dneh uporabe sem ga sesul :S
102437 (2184) Ice-Heki
Ubuntu 5.10 tezave!!
91071 (966) |Luka|
Napaka pri inštalaciji GCCja na Debianu...
61491 (1455) Gandalfar
