Napaka pri inštalaciji GCCja na Debianu...
darh ::
Kaj mi storiti ?
# apt-get install gcc Reading Package Lists... Done Building Dependency Tree... Done The following extra packages will be installed: gcc-3.3 Suggested packages: make manpages-dev autoconf automake libtool flex bison gdb gcc-doc gcc-3.3-doc Recommended packages: libc-dev libc6-dev The following NEW packages will be installed: gcc gcc-3.3 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 0B/1613kB of archives. After unpacking 4252kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 12781 files and directories currently installed.) Unpacking gcc-3.3 (from .../gcc-3.3_1%3a3.3.4-6sarge1.1_i386.deb) ... dpkg: error processing /var/cache/apt/archives/gcc-3.3_1%3a3.3.4-6sarge1.1_i386.deb (--unpack): trying to overwrite `/usr/share/doc/gcc-3.3-base/changelog.Debian.gz', which is also in package gcc-3.3-base dpkg-deb: subprocess paste killed by signal (Broken pipe) Selecting previously deselected package gcc. Unpacking gcc (from .../gcc_4%3a3.3.4-2_i386.deb) ... Errors were encountered while processing: /var/cache/apt/archives/gcc-3.3_1%3a3.3.4-6sarge1.1_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Excuses are useless! Results are priceless!
BigWhale ::
A ti je diska zmanjkal?
darh ::
nope...še 8 giga... kar je pomoje za en gcc dovolj, da ? :)
moj_nick ::
May the --force be with you ;)
110111001001010001010000
roscha ::
@ moj_nick: kar pa sploh ni nujno da bo pomagalo.
dpkg je precej močnejši od apt-a
man dpkg...
darh ::
očitno bo to to...
zdej vleče dol 40 mega.. bomo vidli...
Gandalfar ::
in je pomagalo?
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
Oddelek: Operacijski sistemi
1960128062 (43736) RedDrake
K3B problem
71692 (1570) theD3viL-
Gentoo kaj se dogaja?
462750 (2038) Pithlit
Kompajlanje kernela
141554 (1419) SasoS
unmergal sem gcc
422343 (2089) borchi
