Forum » Loža » Hoja po vodi
Hoja po vodi
tx-z ::
Torej če maš ti neko hitrost k se premikaš na vodi, se ne boš potopil (primer, smučanje na vodi). Zakaj pravzaprav pride do tega, da se ne potopiš ? (v mislih mam še eno vprašanje ampak dokler tega ne zvem raj ne bom vprašu k zna zelo debilno izpadt
tx-z
koyotee ::
sila vzgona je večja od sile teže
Rear DVD collector!
JTD power!
JTD power!
- spremenil: koyotee ()
DimmniBurek ::
There Is No Stronger Drug Than Reality
- zavarovalo slike: WarpedGone ()
Vice ::
verjetno je bilo tvoje drugo vprašanje zakaj se polž takoj potopi, če šprint čez vodo udari.
@Vice od kod jih pobiraš nevem ne
Drugo vprašanje bo če je možno tak hitro šprintat da lahko letiš čez vodo.
Good Guy ::
jp ;)
poglej posnetke mačkov in psov k laufajo čez vodo(red da majo manjšo maso sam če boš dost hitr ti rata
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
telexdell ::
Odgovor je, da je možno. Tega sicer še ni zmožen noben človek. V Amazoniji pa živijo kuščarji, kateri po dveh nogah tečejo preko vode in tako pobegnejo plenilcem.
Rippy ::
Darwin Award
Se popolnoma strinjam s komentarjem :)
(24 November 1999, California) One particular group of Christians attempted to follow in Jesus' footsteps more literally than most. They worked to master the secret of walking on water. Diligently, day by day, the group tried to be closer to God by making a sincere effort to walk on water. These Christians continued their unorthodox practices until the leader of this small Los Angeles group unexpectedly died while practicing in his bathtub. His wife said James spent many hours trying to perfect the technique of walking on water, but had not yet mastered the ability. He apparently drowned after slipping on a bar of soap.
Note from Giles Read -- "These people obviously haven't realised that anyone can walk on water. I've done it myself. Just wait until the lake freezes..."
Good Guy ::
tuki se govori po vodi ne po ledu.. beri malo
Loki ::
pri premikanju je sila vzgona (stopala oz. smuci) vecja od sile teze, ce pa hoces hoditi, moras biti ZELOO lahek in imeti velika stopala, da je pritisk na gladino manjsi od tiste povrsinske napetosti vode.
kaj je pa tisto drugo vprasanje?
I left my wallet in El Segundo
madmitch ::
Hahaha, molekularna napetost pa to, bemu, kakšne noge bi moral imeti. Temu bi se res reklo življenje na veliki nogi.
bluefish ::
tuki se govori po vodi ne po ledu.. beri maloLed je le agregatno stanje vode, če gremo že v detajle.
Drugače pa ja, z dovolj veliko hitrostjo lahko hodiš po vodi.
tsh2 ::
ja ampak hoja po vodi in hoja po ledu je čisto druga zgodba, a ne?
sem kar siguren da se smučar na vodi ne potopi zaradi istega razloga kot trhel les, ki lebdi na vodi (ali pa čoln). trhel les pa se ne potopi zaradi istega razloga kot zakaj se ne potopi tekočina, ki jo zliješ v vodo, ki ima manjšo gostoto kot voda. na kratko: tisto kar ima višjo gostoto izpodrine ("zleze pod") tisto, kar ima nižjo gostoto. to je glavni zakon.
BALAST ::
darkolord, izjema je smučar ki ima smuči z večjim vzgonom, kot je sam težak skupaj z smučmi. Naprimer stiroporne smuči.
Rippy ::
a res?
Res je, tekočina zelo podobna plinu. Določeno telo lahko plava v primeru, da izpodrine več mase od svoje teže, recimo ladja. Naprimer balon napolnjen s helijem v optimalnih pogojih lahko poleti le tako visoki dokler se njegova masa ne izenači s gostoto plina, ki ga izpodrine. Podobno je s podmornicami, one uravnavajo globino s balasti.
Edit:
Imam občutek, da je ta izbrisani stavek 3/4 butast :).
- spremenil: Rippy ()
tx-z ::
Kaj bi blo v primeru če bi mel take čevle k bi svoj podplat premikal naprej pa nazaj z zelo velko hitrostjo? A bi obstal na vodi?
tx-z
Loki ::
a res?
ce ne, zakaj se pa potem ljudje utopijo? ziga dvomim, poglej si, kaj je definicija vzgona. pravzaprav mi sploh ni jasno, kako bi to zgledalo IRL.
koyotee ::
Ne, potonil bi. Stupid question.
Rear DVD collector!
JTD power!
JTD power!
Kaj pa če si umisilmo kake čevlje z večjim stopalom, enega lahkega človeka izberemo za poiskus in hitrega pa naj leti...sliši se nemogoče ja.
Naj kdo izračuna kaka hitrost bi bla potrebna da bi obstal na vodi.
CleanPower ::
majhne živali izkoriščajo površinsko napetost vode. če bi pa npr en bolt hotu tečt po vodi, nebi mogu ker je pretežek pa sploh bi zgubu hitrost ker se nebi mogu odrivat.
kopriwa ::
Če lahko ljudje "smučajo" na vodi bosi, potem ni problema s čevlji različnih velikosti, a primernih oblik se ve.
edit:bluzim, vidm da govorite o hoji na vodi :P
- spremenilo: kopriwa ()
BigWhale ::
Po mojem je pa precej razlike v tem a se ti od vode odrivas (torej teces po njej) ali pa te nekdo vlece in se dvignes 'nad vodo' zaradi vzgona.
Bi moral kar hitro tect se preden bi stopil na vodo, da bi potem tvoje korakanje po vodi ustvarjalo dovolj vzgona, da bi te drzalo nad vodo.
... mogoce ce bi imel smucko na eni nogi z drugo bi se pa odrival od vode ...
Samo to se ne da, ze Marty McFly failed at it. :P
kopriwa ::
Predstavlam si, da bi mogu z zlo veliko hitrostjo (frekvenco) udarjat s stopali po vodi, upor v navpični smeri naj bi poskrbel za to, da se ne bi potopu, hitrost stopal v vodoravni smeri pa za odriv. Po mojem je največja ovira teža in fizična moč človeka za kej tazga.
koyotee ::
ja, Z čevlji je problem smučat.
Rear DVD collector!
JTD power!
JTD power!
Good Guy ::
niti ne tut brez se da, če je hitrost dovolj velika
dzinks63 ::
Hoja po vodi je seveda možna, vendar tega ne zmore človek, niti Bolt ne, nekatere živali pa lahko, kot npr. : kuščar z vzdevkom Jesus Christ Lizard. Možno pa je tudi v kakšni risanki, npr: The Incredibles (2004), ali pa npr. : Extreme Barefooting
- spremenil: dzinks63 ()
M-XXXX ::
Če bi dovolj hitro premikal noge in se odrival od vode je hoja možna, vendar ni možno da bi dovolj hitro tekel. Prav tako se da po vodi voziti z vozili (ki imajo navadne gume (seveda večje, širše) ter z snežnimi sankami. Vendar v obeh primerih rabiš veliko hitrost. Zdi se mi da so v fifth gear imeli del oddaje posvečene temu.
tx-z ::
Lih pač učeri sm gledu uno od Myth Busterjev, k sta dala nek prašk v vodo in pol sta pač lah hodla..Kr je bla stvar tok gosta al kaj(nism celga gledu) da je pač za tist trenutk k je laufu čez, ga še zadržal nad vodo. Zto sm začeu ramzišlat zakaj prauzaprau ne potonš k greš smučat po vodi...Pa še zj mi je to ful čudn vseskp
tx-z
mojca ::
Če dovolj hitro stopicljaš, seveda lahko tečeš po vodi, vendar je to ravno toliko utopično kot ideja, da bi mahal z rokami in poletel kot žuželke. Če si dovolj hiter, se voda zdi kot beton (poskusi skočiti na ploh z velike višine).
Tole se splača pogledati (lahko opazuješ detajle pri smučanju na vodi, ki se zdi pri hitrem prehodu kot "beton"):
En neuspešen poskus hitrega "mahanja" po vodi:
Neuspešen poskus tekanja z velikimi čevlji (2 poskusa):
(1/5) http://video.google.com/videoplay?docid...
(2/5) http://video.google.com/videoplay?docid...
(3/5) http://video.google.com/videoplay?docid...
(4/5) http://video.google.com/videoplay?docid...
(5/5) http://video.google.com/videoplay?docid...
Uspešen poskus tekanja po "vodi" (če dovolj hitro tečeš, sicer se potopiš):
Na vodi lahko obstaneš zaradi različnih efektov:
1.) površinska napetost: izkoriščajo jo "drsalci"(?) oziroma tiste male žuželke, zaradi nje lahko vodo naliješ preko roba kozarca (človek je pretežak, da bi imel kaj od tega)
2.) vzgon (biti moraš specifično lažji od vode): zaradi njega na vodi plava les ali barka (s stiropornimi čevlji ali z "barčicami" na nogah bi to šlo, še lažje v živem srebru)
3.) z zelo hitrim premikanjem (vleko ali čofotanjem) po vodi; ne vem, kakšno točno je strokovno ime, ima pa vezo z Reynoldsovim številom in tem, da se voda zdi kot beton, če nanjo udariš z veliko hitrostjo (morda se motim); predstavljaš si lahko nekako tako: če zamahneš tako hitro, da se ti vodne molekule nimajo časa umaknit, se lahko "brez težav" odrineš od vode; človek sam je prepočasen
bosmla ::
Vsi nekaj fizikalno nabijate (ste pa v Lozi
) nihce se pa ne spomni, da je enemu ze pred 2k leti to ratalo... stvari treba v sebi porihtat pa gre!
| » | Reklame ki najedajo (strani: 1 2 )Oddelek: Loža | 9841 (8314) | Matev |
| » | zakaj kamen odskakuje po vodi (strani: 1 2 )Oddelek: Loža | 8218 (6688) | Thomas |
| » | Hoja po vodiOddelek: Novice / Znanost in tehnologija | 4490 (3614) | marvin42 |
| » | zakaj lesen čoln potoneOddelek: Loža | 8541 (7880) | ferdo |
| » | Robot po poteh JezusaOddelek: Novice / Znanost in tehnologija | 3865 (3865) | Izi |
