Forum » Zvok in slika » Media Coder konventiranje
johanblond ::
Hocem konvertirat video posnet z Canon A540 v DivX .avi.
Dobim error - no file outputed.
Ce pa pod istimi nastavitvami nastavim Container namseto na .avi na .mp4 pa dobim pod istimi nastavitvami (Video: DivX, Audio: mp3) konvertiran film (relativno slabe kvalite!)
Kje je problem?. Kaksne nastavitve naj uporabim.
Spodaj prilagam podatke o izvornem in konvertiranem filmu.
Izvorni film:
General
Complete name : 096.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 12.1 MiB
Duration : 6s 800ms
Overall bit rate : 14.9 Mbps
Mastered date : THU MAY 24 15:45:11 2007
Writing application : CanonMVI02
Video
Format : M-JPEG
Codec ID : MJPG
Duration : 6s 800ms
Bit rate : 14.8 Mbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 30.000 fps
Resolution : 24 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1.608
Stream size : 12.0 MiB (99%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 6s 800ms
Bit rate mode : Constant
Bit rate : 88.2 Kbps
Channel(s) : 1 channel
Sampling rate : 11.024 KHz
Resolution : 8 bits
Stream size : 73.2 KiB (1%)
Interleave, duration : 971 ms (29.14 video frames)
Interleave, preload duration : 1000 ms
Konvertiran film - mp4
General
Complete name : 096.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 838 KiB
Duration : 6s 948ms
Overall bit rate : 988 Kbps
Encoded date : UTC 2009-07-30 10:07:39
Tagged date : UTC 2009-07-30 10:07:39
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 6s 766ms
Bit rate mode : Variable
Bit rate : 945 Kbps
Maximum bit rate : 1 670 Kbps
Width : 640 pixels
Height : 480 pixels
Frame rate mode : Constant
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.103
Stream size : 781 KiB (93%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 2.5
Format profile : Layer 3
Codec ID : 69
Duration : 6s 948ms
Bit rate : 64.0 Kbps
Maximum bit rate : 70.2 Kbps
Channel(s) : 2 channels
Sampling rate : 11.025 KHz
Resolution : 16 bits
Stream size : 54.3 KiB (6%)
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 2 -lowpass 5.5 -b 64
Izvorni film:
General
Format : AVI
Duration : 6s 800ms
Video
Format : M-JPEG
Codec ID : MJPG
Duration : 6s 800ms
Width : 640 pixels
Height : 480 pixels
Audio
Format : PCM
Codec ID : 1
Duration : 6s 800ms
Resolution : 8 bits
General
Format : MPEG-4
Codec ID : isom
File size : 838 KiB
Duration : 6s 948ms
Video
Codec ID : 20
Duration : 6s 766ms
Bit rate : 945 Kbps
Width : 640 pixels
Height : 480 pixels
Colorimetry : 4:2:0
Audio
Format : MPEG Audio
Codec ID : 69
Duration : 6s 948ms
- premaknil iz Pomoč in nasveti: gkovac ()
johanblond ::
A lahko kdo priporoči kakšen drug program za konvertiranje ?
| » | YouTube nativni video formatOddelek: Pomoč in nasveti | 2412 (2041) | Ijus |
| » | Občasno štekanje pri predvajanju preko HDMIOddelek: Zvok in slika | 4248 (3204) | sejmon |
| » | HD ali FULL HD KAMERAOddelek: Zvok in slika | 6419 (5443) | JOKER |
| » | Kupil bi Satelitsko. (strani: 1 2 )Oddelek: Zvok in slika | 19048 (17508) | mumbo |
| » | wmv - video in zvok nista usklajenaOddelek: Zvok in slika | 1516 (1461) | #000000 |
