acpi problem
acpi problem
bigbada ::
No danes ko sem hotu formatirat, se mi je pojavil sledeci problem
grem pac v bios nastelam za boot cd
restartam...
in ko se zacne nalagat on setup za xp.. ko ti spodaj pise press f6 for blabla pa te fore pa plavi screen je,
mi javi neki error z napisom:
"The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed--it will silently disable ACPI and allow you to continue your installation."
STOP: 0x000000A5
prej mi to nikoli ni delalo, sem normalno lahko formatiral, instaliral ponovno windowse, zdaj pa kar neke
nevem kaj je narobe
.. pol sem poskusil ono foro da stisnem F7 pa sem lahko normlano isntaliral pa vse, pol pa ko sem ponovno zagnal windows mi ni slo dalje kot do boot menuja....
kaj naj naredim, prosim pomoč
boogie_xlr ::
Lahka probaš bios updejtat. Poglej v manual od tvoje matične plošče.
Just-1n ::
V biosu izber load fail safe, al pa default bios settings. Pa poskusi če dela. Če ša zafrkava probi dat na off (acpi). Koko maš pa kaj z ramom a maš slučajno različne.
Tle je en mel tud tak problem:
Don't have floppy first in boot order, set cdrom first.
Disable APM in bios.Possible to enable it after driver/windows updates.
Disable Legacy USB Support in bios.
Change the jumper setting to CS on your HDD
Enable ACPI in BIOS
LAhko probaš tud z updatingom biosa.
Problem instalacije XP - SATA disk
162835 (1841) Duhec
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820058 (16898) arrigo
Instalacija XP ne najde diska
Oddelek: Operacijski sistemi
416585 (5448) fredyjetle
RAM problem
252227 (2004) drLinux
Linux / net
222029 (1702) roscha
