Forum » Pomoč in nasveti » Čistilec registra
Čistilec registra
Maverick33 ::
Lep pozdrav jaz bi pa mel rad nekaj za register čisti pa, da je program tak, da ga nod ne blokira.
Npr: so mi rekl ti dj advanced system care nalož sm reku da probam kok je tole "care" pa kuj nod blocked nevem no kaj vi kej priporočate?
Zaenkrat mam TuneUp pa tam čistim samo to pomoje ni dovolj? Včas sem mel Ccleaner.
HVALA
HVALA
advanced systemcare 3
vbohinc ::
Human nature is not a machine to be built after a model, and set to
do exactly the work prescribed for it, but a tree, which requires to grow
and develop itself on all sides...
Čiščenje registra je precej nesmiselno.
Iz Wikipedije:
O.
Iz Wikipedije:
... the difference in speed due to the use of a registry cleaner is negligible: rarely do they remove more than a few kilobytes from the total size of the registry. In fact, technology journalist Ed Bott has claimed that no-one has ever successfully managed to measure any significant performance increase from the use of a registry cleaner. Any potential user of a registry cleaner must thus balance a probably negligible performance increase against the possibility of system instability. A safer and more measurable approach to Registry performance is to defragment the Registry files using a Microsoft-supported tool such as PageDefrag.
O.
bluefish ::
Defrag velikokrat res naredi veliko več kot pa vsako orodje za čiščenje registra. Kljub vsemu pa CCleaner poleg registra očisti še neželene datoteke,... kar pa se že pozna.
Je pa vsaj po namestitvi več programov fino, če se uporabi tako orodje. Učinki morda niso izmerljivi, občutek je pa dober
| » | Brezplačni delujoč registry cleaner za XpOddelek: Programska oprema | 4365 (3620) | bluefish |
| » | Verjetno napaka v registruOddelek: Pomoč in nasveti | 1816 (1691) | Omelo |
| » | programi za optimizirano delovanje računalnikaOddelek: Programska oprema | 8004 (7654) | zee |
| » | Program za čiščenje kompaOddelek: Programska oprema | 4943 (4203) | opeter |
| » | Kako "očistiti" comp?Oddelek: Pomoč in nasveti | 3475 (3160) | bluefish |
