Forum » Programska oprema » MS Excel 2007 - solver
eales ::
Živjo
Imam eno težavo. Potreboval bi orodje "solver", ki bi se moralo nahajati v excelu 2007 pod zavihkom "Data". Na faksu je to orodje tam, pri meni ga pa sploh ni. A je možno, da je izklopljeno in ga jaz ne znam vklopiti?
Hvala že v naprej za pomoč
toxius ::
solver je potrebno najprej vklopiti:
Steps to add the Solver add-in in Excel 2007
1. Click the Microsoft Office Button , and then click Excel Options.
2. Click Add-Ins, and then in the Manage box, select Excel Add-ins.
3. Click Go.
4. In the Add-Ins available box, select the Solver Add-in check box, and then click OK.
Tip: If Solver Add-in is not listed in the Add-Ins available box, click Browse to locate the add-in.
If you get prompted that the Solver Add-in is not currently installed on your computer, click Yes to install it.
5. After you load the Solver Add-in, the Solver command is available in the Analysis group on the Data tab.
3. Click Go.
| » | ms office excel 2003, ctrl+s ne dela kot bi moralOddelek: Pomoč in nasveti | 1443 (1363) | Duhec |
| » | Kako naložiti podatke ob odpiranju Excel(VBA)Oddelek: Programiranje | 1063 (926) | darkkk |
| » | težava po odstranitvi google desktopOddelek: Pomoč in nasveti | 884 (812) | ne_kdo |
| » | [C#] ClickOnce online installOddelek: Programiranje | 1659 (1502) | 2g00d4u |
| » | RA2 preko dveh modemov?!Oddelek: Igre | 1786 (1681) | bastadu |
