MS Excel 2007 - solver
eales ::
Živjo
Imam eno težavo. Potreboval bi orodje "solver", ki bi se moralo nahajati v excelu 2007 pod zavihkom "Data". Na faksu je to orodje tam, pri meni ga pa sploh ni. A je možno, da je izklopljeno in ga jaz ne znam vklopiti?
Hvala že v naprej za pomoč
toxius ::
solver je potrebno najprej vklopiti:
Steps to add the Solver add-in in Excel 2007
1. Click the Microsoft Office Button , and then click Excel Options.
2. Click Add-Ins, and then in the Manage box, select Excel Add-ins.
3. Click Go.
4. In the Add-Ins available box, select the Solver Add-in check box, and then click OK.
Tip: If Solver Add-in is not listed in the Add-Ins available box, click Browse to locate the add-in.
If you get prompted that the Solver Add-in is not currently installed on your computer, click Yes to install it.
5. After you load the Solver Add-in, the Solver command is available in the Analysis group on the Data tab.
eales ::
O najlepša hvala =)
Dela
ms office excel 2003, ctrl+s ne dela kot bi moral
71454 (1374) Duhec
Kako naložiti podatke ob odpiranju Excel(VBA)
Oddelek: Programiranje
81075 (938) darkkk
težava po odstranitvi google desktop
6899 (827) ne_kdo
[C#] ClickOnce online install
81673 (1516) 2g00d4u
RA2 preko dveh modemov?!
Oddelek: Igre
101801 (1696) bastadu
